Loading...
Pages: 1 [2]   Go Down
Author Topic: integer save into single bytes  (Read 775 times)
Switzerland
Offline Offline
Sr. Member
View Profile
WWW
Why do your buffer subscripts start at 1?
Since in the first ([0]) is the adress where the message came from...
is 1 << 0 not the same as pow(256,0).
Or how can I do it differently?
« Last Edit: March 23, 2012, 11:01:36 am by GekoCH » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
1 << 0 is exactly the same value as 2560
The problem lies with the progression
0, 8, 16 ... ?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Switzerland
Offline Offline
Sr. Member
View Profile
WWW
so maybe 24 hmmmm smiley
But still no success or is it still wrong (24)?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I'm posting this from my phone.
I can't see your results, and I'm miles from my Arduinos.
Logged
Offline Offline
Jr. Member
View Profile
if you are trying to convert from byte array to long integer, simply use the union in the opposite way:
Code:
   Number Out;
   Out.barray[0] = b0;
   Out.barray[1] = b1;
   Out.barray[2] = b2;
   Out.barray[3] = b3;
   unsigned long val = Out.num
Logged
Switzerland
Offline Offline
Sr. Member
View Profile
WWW
Code:
   Number Out;
   Out.barray[0] = b0;
   Out.barray[1] = b1;
   Out.barray[2] = b2;
   Out.barray[3] = b3;
Wow thx the union thing worked just great!
Finally I do need to send float numbers separated in a 4 byte array with the IEEE-754 Standard.
Converting form the bytes to float was easy but the other way round seems harder...
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Why? It's the same union, with a float added.
Logged
Switzerland
Offline Offline
Sr. Member
View Profile
WWW
wow you were right hmm this union thing is quite strong have to dig deeper what else it can deliver....
Thx
Andy
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
So I tryed this but it doesn't work...
Code:
long number = 115730;
data[0] = (byte)(number >> 24);
data[1] = (byte)(number >> 16);
data[2] = (byte)(number >> 8);
data[3] = (byte)(number);
I don't see anything wrong with the original construction (aside from the ':' vs ';', which I hope is a transcription error.)
In what was does it "not work"?
Logged
Switzerland
Offline Offline
Sr. Member
View Profile
WWW
the value returned was wrong compared to what was expected there fore I wrote it doesn't work...
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Could be that your expectations were wrong. No input, no output, no way for us to know whether the code is wrong or your expectations are wrong.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
