Topic: AVRProjectIDE with version of Arduino 1.0 (Read 1 time) previous topic - next topic
tasosstr
Hi to all,
Can some one has success using the perfect editor AVRProjectIDE with the new Arduino 1.0
I have go to Tools --> Editor Settings --> and i select for the Core files: C:\arduino-1.0\hardware\arduino\cores\arduino
and for the libraries:  C:\arduino-1.0\libraries
but when i compile i got errors the first of that is:
file                   line  Where           Message
wiring_digital.c   138  'digitalWrite'  undefined reference to 'port_to_output_PGM'
Can some one please help me ?
Thank you in advance.
johnwasser
Did you include Arduino.h like the Arduinbo IDE does?
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
tasosstr
Hello Dear johnwasser,
Thank you very much for the reply and sorry for the delay on my reply.
I was try to add on top the #include "Arduino.h"
But no working   :(
johnwasser
Did you include the appropriate pins_arduino.h like from hardware/arduino/variants/standard/pins_arduino.h?
tasosstr
Thank you very much for the reply.
I was try again today with you're tip, i copy the file pins_arduino.h in Core folder and i was try to compile the bellow code:
#include <Arduino.h>
//#include <pins_arduino.h>
int power;
float sensor=0;
float input=0;//voltage read on pin 2
float celsius=0;
float fahrenheit=0;
void setup(){
pinMode(3,INPUT);
void loop(){
  power= digitalRead(3);
  if (power==HIGH){
  sensor = analogRead(A0);
input = (sensor*5000)/1024; // convert raw sensor value to millivolts
celsius = input/10;         // convert millivolts to Celsius
fahrenheit = ((celsius * 1.8)+32); // convert celsius to fahrenheit
Serial.println(" sensor read");
Serial.println(sensor);
Serial.println(" --------------------------");
Serial.print("Temperature: ");
Serial.print(celsius,2);
Serial.println(" degrees C");
Serial.print(fahrenheit,2);
Serial.println(" degrees F");
Serial.println("_ _ _ _ _ _ _ _ _ _ _ _ _ _  ");
delay (2000); // wait a second, otherwise the serial monitor box will be too difficult to read
Without luck :(
The only good it was the errors it is only 3 from many it was before :-)
Look the error if you can please, maybe you can understend more than me. ( I am sure for this :-) )
johnwasser
Looks like you have to add:
int main()
    setup();
    while (1)
        loop();
Not sure why it's complaining about pulseIn().  Looks like it might be declared twice.
