Topic: error: invalid conversion from 'const char*' to 'int' (Read 3437 times) previous topic - next topic
Nivin37
when changing from...
Code: [Select]
void top_menu_function_5() //Replace this with the actual function of menu item #5
    int choice=yn_dialog("Start");
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print(choice); // Display the user choice one more time
    delay(user_input4);
    int motorspeed = 100;  // This sets up the speed the motor will turn
    motor2.step(user_input3, BACKWARD, SINGLE);  //Move the motor forward by the number of "Steps per frame
    motor2.release();  //  make sure the motor is at rest.
   wait_on_escape(4000);
to...
Code: [Select]
    int yn_dialog("Start");
    lcd.clear();
    lcd.setCursor(0,1);
    //lcd.print(choice); // Display the user choice one more time
    delay(user_input4);
I get this error...
Code: [Select]
My_Menu_2_0.cpp: In function 'void top_menu_function_5()':
menu:202: error: invalid conversion from 'const char*' to 'int'
If you need the full sketch, please ask.
Can someone point out what I'm doing wrong.
Thanks.
Steve...
Nick Gammon
What is the intention of this line?
Code: [Select]
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nivin37
Code: [Select]
I'm using phi_prompt as a menu for a sketch with a LCD.
This is an extract from the document on phi_prompt.
13) int yn_dialog(char msg[]);
Parameters:
This renders a YES/NO dialog so the user can choose YES or NO.
Return values:
1 for YES and 0 for NO so the program can decide what to do in case of YES and NO. The dialog auto scales to occupy the entire display so you don?t have to specify you have a 20X4 display or 16*2 display. See fig. 6-3 below.
Eg. int choice=yn_dialog("Engage death ray now?");
(a)
(b)
Figure 6-3. YES/NO dialog auto scales on 16X2 and 20X4 displays. (a) 16X2 display. (b) 20X4 display. Intended message was "Engage death ray now?". The text is automatically wrapped to occupy multiple lines. The message will be clipped if it doesn?t fit on a smaller display.
Steve...
Nick Gammon
Code: [Select]
Yes, so why did you get rid of the variable that holds the response? The way you have it you are calling the function but discarding the result.
More info:
Nick Gammon
Code: [Select]
to...
Code: [Select]
I get this error...
Put it another way. Why did you make this change in the first place?
More info:
Nivin37
Code: [Select]
My apologies I got it wrong in the second part of the code, my intention is to change from a yes/no to just a OK. the changed code should be...
Code: [Select]
    int ok_dialog("Start");
    lcd.clear();
    lcd.setCursor(0,1);
    delay(user_input4);
And the extract from the document...
12) int ok_dialog(char msg[]);
Parameters:
This renders an OK dialog. Primarily you want to show the user a message and the user needs to press a key to continue. Otherwise the function keeps waiting. It doesn?t actually return a value. The return value type is there to be consistent with the YES/NO dialog and any future dialog functions. The OK dialog just needs the char array that has the message to show to the user. The message will be truncated if there is not enough space. The dialog auto scales to occupy the entire display so you don?t have to specify you have a 20X4 display or 16*2 display. See fig. 6-2 below.
Eg. ok_dialog("Death ray was engaged. Annihilation in progress...");
Steve...
Nick Gammon
Code: [Select]
You are getting confused here. ok_dialog is a function. It returns something. That something needs to go somewhere. Then you can test the somewhere. Like:
Code: [Select]
  int proceed = ok_dialog("Start");
  if (proceed)
     // good to go
More info:
Nick Gammon
Or, more simply:
Code: [Select]
  if (ok_dialog("Start"))
     // good to go
Although judging by the description you posted, the return value doesn't mean anything. So it could just be:
Code: [Select]
  ok_dialog("Start");
More info:
Nivin37
Or, more simply:
Code: [Select]
     // good to go
Code: [Select]
  ok_dialog("Start");
Ok thanks Nick, changing to
Code: [Select]
  ok_dialog("Start");
Now has the menu working, I just need now to work out why My stepper is not moving.
Steve...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
