Topic: Potentiometer servo control through an XBee (Read 2562 times) previous topic - next topic
EnigmaCypher7
I want to make a wireless Arduino controller to control some servos positions.
In theory would it be possible to control a Servos position with a potentiometer, like in http://arduino.cc/en/Tutorial/Knob but have the potentiometer hooked to one Arduino and the servo connected to a different Arduino and have them communicate point-to-point through wireless with XBees?
Thanks,
Ec7
He who dares, Wins.
PaulS
Quote
In theory, it is possible.
I practice, it works, too. Provided, of course, that you get the right XBees (Series 1), configure them correctly (PAN ID, MY, and DL need to be set to non-zero values, and MY on one must match DL on the other), and write the proper code for both of the Arduinos.
floresta
Quote
... and write the proper code for both of the Arduinos.
You really can and should do this first - and get it working - before you consider implementing the XBees.
After you get it working with the two Arduinos and the two XBees you should be able to eliminate the Arduino at the potentiometer end.
Don
EnigmaCypher7
Why would I want to write code for a theory?
Oh, maybe I shouldn't have started with;
Quote
Oops.
Anyways, I was wondering in theory if is could be done on a very simple, small scale, an example:
Code: [Select]
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
This isn't something anywhere near the stage of implementation, I am merely trying to get a feel of capabilities of the hardware. Theoretically speaking, if I could physically control something on one Arduino (potentiometer), and then have it relayed somehow (XBee) to another Arduino (Again XBee) and control a device that is interfaced to it (Servo).
This is only an example,
The potentiometer could be replaced with a button or anything else physical.
The servo could be replaced with anything as well.
The reason I chose an example with a potentiometer and servo is that it would show more accurately the precision of these devices working together in unison.
So this is possible? Also would it sound like it would be [font=Verdana]reasonable[/font] to do with:
2x arduino,
2x XBee (Series 1 is fine)
and of course the proper code.
He who dares, Wins.
PeterH
There are various ways to establish a radio link between two Arduinos, using XBees is one solution. Which options available to you will depend on constraints such as range, cost, available power.
Given two Arduinos with communication between them, you can implement sketches that allow them to collaborate. For example, control inputs on one Arduino could cause actions on the other - but it is up to you to design the sketches and hardware correctly to achieve this. It's a little harder than putting all the functionality on one Arduino but not a lot harder, so it would be sensible for you to tackle the problem in small steps - get the functionality you want on a single Arduino; get radio comms working; split the functionality between the two Arduinos connected via radio.
I only provide help via the forum - please do not contact me for private consultancy.
PaulS
Quote
Agree that this should be the first step.
Quote
I disagree with this as the 2nd step. Wired communication between two Arduinos would be my next step.
Then, add the complexity of radios.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
