Pages: 1 2 3 [4] 5 6 ... 8   Go Down
Author Topic: how to create an array with both members and number of members undefined  (Read 2535 times)
took care of that array problem by making sure each recording begins at index 0
 smiley
Now I need be able to playback again and again without smoothing every time... Done!
here's the latest:
//    FILE: servoRecorder.pde
//  AUTHOR: Adi Soffer
//    DATE: 28-3-2012
// PUPROSE: servo recorder
#define IDLE 0
#define FREE 1
#define RECORD 2
#define PLAYBACK 3
#define STOP 4
#define REWIND 5
#define RECORDCONT 6
int mode;
int idx, lastidx, firstidx, newidx;
int maxidx = 800;
#include <Servo.h>
Servo myservo;                                         // create servo object to control a servo
char buffer [2];                                         //variable to hold keystrokes
int potpin = 0;                                           // analog pin used to connect the potentiometer
unsigned int val;                                        // variable to read the value from the analog pin
const unsigned int valNumber = 800;            //variable to contain number of array members
int incomingByte;                                      //declare variable to hold incoming letter
unsigned int servoPos[valNumber];              //create array of values for servo position
const int waitForServo = 15;                       //delay time to let servo get to position
int smooth;
const byte recordModeLed = 3;                  // defining pins for ui leds
const byte homeModeLed = 4;
const byte playModeLed = 5;
const byte freeModeLed = 6;
const byte freeSwitch = 7;                         //defining pins for switches
const byte recSwitch = 8;
const byte homeSwitch = 9;
const byte playSwitch = 10;
  Serial.flush();
  myservo.attach(2);                                             // attaches the servo on pin 2 to the servo object
  pinMode (freeModeLed, OUTPUT);                       //defining LED pins as output
  pinMode (recordModeLed, OUTPUT);
  pinMode (homeModeLed, OUTPUT);
  pinMode (playModeLed, OUTPUT);
  pinMode (freeSwitch, INPUT);                              //defining switch pins as input
  pinMode (recSwitch, INPUT);
  pinMode (homeSwitch, INPUT);
  pinMode (playSwitch, INPUT);
void loop ()
  digitalWrite (freeModeLed, LOW);
  digitalWrite (recordModeLed, LOW);
  digitalWrite (homeModeLed, LOW);
  digitalWrite (playModeLed, LOW);
  // HANDLE IO
  if (Serial.available( ) > 0)
    incomingByte = Serial.read ( );
    switch(incomingByte)
    case 'f':
      mode = FREE;
      Serial.println ("Free mode");
      break;
    case 'r':
      mode = RECORD;
      for (int c=6;c>3;c --)                                                      // three sec LED countdown to recording
        digitalWrite (recordModeLed, HIGH);
        digitalWrite (c, HIGH);
        delay (700);
        digitalWrite (c, LOW);
        delay(300);
      Serial.println ("Record");
      smooth = 1;        //"smoothing req."
      break;
    case 's' :
      mode = STOP;
      Serial.println ("STOP");
      break;
    case 'w' :
      mode = REWIND;
      digitalWrite (homeModeLed, HIGH);                    //turn on rewind LED
      Serial.println ("Rewind");
      break;
    case 'p':
      mode = PLAYBACK;
      digitalWrite (playModeLed, HIGH);                     //turn on playback LED
      Serial.println ("Playback");
      break;
  switch(mode)
  case STOP:
    for (int x=3;x>6;x++)
      digitalWrite (x, LOW);                                 //turn off all LEDs
    break;
  case FREE:
    digitalWrite (freeModeLed, HIGH);
    val = analogRead (potpin);
    val = map(val, 0, 1023, 0, 179);                    // val = val * 45/256; // <==> val * 180/1024
    myservo.write (val);
    Serial.println (val);                                      //print val for checking
    newidx == val;
    delay (waitForServo);                                  //  should be refactored away -> like blink without delay
    break;
  case RECORD:
    digitalWrite (recordModeLed, HIGH);           //keeps LED on
    Serial.println ("Record function");                 // if so - prints record
    val = analogRead(potpin);                            // reads the value of the potentiometer (value between 0 and 1023)
    val = map(val, 0, 1023, 0, 179);                    // scale it to use it with the servo (value between 0 and 180)
    myservo.write(val);                                    // sets the servo position according to the scaled value
    Serial.println (val);                                     // print values for checking
    idx = 0;                                                      //making sure array will start filling up from index 0
    servoPos [idx]=val;                                     // stores val in array "servoPos"
    firstidx = idx;
    idx ++;
    mode = RECORDCONT;
    break;
  case RECORDCONT:
    idx ++ ;
    lastidx = idx;
    if (idx == maxidx) mode = STOP;
    delay(waitForServo);                                     // waits for the servo to get there
    Serial.println(val);                                         // print values for checking
    break;
  case REWIND:                                                  //need to build rewind from new point in free mode
    //why first val is 0???
    for (int i=lastidx;i>firstidx;i--)
      val = servoPos [i];
      myservo.write (servoPos [i]);
    mode = STOP;
    break;
  case PLAYBACK:
    if (smooth == 1)        //if I just recorded "smoothing req."
      for (int x = 0;x<lastidx - 2; x++)                                              // smoothing values
        servoPos [x+1] = (servoPos [x]  + servoPos [x+2] ) /2;
      smooth = 0;        //change value back to "no smoothing req."
      for (int i=firstidx; i< lastidx; i++)
        myservo.write (servoPos[i]);
        val = servoPos [i];
      mode = STOP;
      for (int x=3;x>6;x++)                                                              //turn off all LEDs
      break;
    else        //if "no smoothing req."
        val = servoPos [i];
      mode = STOP;
      break;
« Last Edit: March 28, 2012, 01:37:05 pm by Soffer » Logged
Anchorage, AK
So, after all your corrections with the array index, is the smoothing working the way you want now?  Or are you still seeing bad starting values?
Now it seems to work perfectly, thank you.  smiley
Next I have to
1.find a way to rewind not from the recorded array's last value, but from wherever the servo is at the moment (if I use free mode and than wish to go back to the first recorded value, I shouldn't go through the lastidx...)
2. find a way to be able to "free mode" while counting down with LEDs for recording. (last minute adjustments)
When this is done  - replace serial input with real buttons!
Oh - and that probably means I'll be asking more questions... smiley-wink
Netherlands
latest version looks quite well!
Advice: start with one button and read the tutorial about debouncing.
Rob Tillaart
robtillaart - will do, thanks.
Do you guys think that I should change the structure of the code to "functions" instead of "case" because I'm switching from serial input to buttons?
I'm asking just to be on the safe side although I see no reason for doing that...
Netherlands
Not because you are switching but to give you oversight;
  handleInput();
  switch(mode)
  switch(mode)
  case STOP: stop(); break;
  case FREE: free(); break;
  case RECORD: record(); break;
  case RECORDCONT: recordcont(); break;
  case REWIND:  rewind(); break;
  case PLAYBACK: playback(); break;
void handleInput()
  handleButtons();
  handleSerial();
etc
the 6 recorder functions have lower level common parts. That can be functions too, like
void turnOffLeds()
Rob Tillaart
Aha!
You helped me figure the flow I think.
Thanks.
I will update and upload the next version naturally smiley-wink
Thank you.
Pittsburgh, PA, USA
I only know some basic electricity....
void turnOffLeds()
I think you have a typo there.  x>6 ?
Examples can be found at Learning in the Main Site and at the Playground
Netherlands
That was intentional as an exercise for the reader smiley
Rob Tillaart
Can I do something like
switch (digitalRead)
case = (pinNum1, HIGH):
mode = record;
break;
case = (pinNum2, HIGH):
mode = rewind;
break;
And so forth?
Gosport, UK
No, you can't.
Well than, in that case I do have to switch to functions...
 smiley-confuse
Not too good since the "switch case" structure helped me with a lot of things, one of which was the option to stop recording without being stuck in a loop...
 smiley-roll
Oh well, I'll figure something out...
Netherlands
build an if then else if ladder, take care that the most important one is tested first!
void HandlePins()
  if (digitalRead(stopPin) == HIGH) mode = STOP;
  else if (digitalRead(rewindPin) == HIGH) mode = REWIND;
void handleSerial()
  #include existing code ;)
Rob Tillaart
robtillaart - you're my hero!
Thank you (again and again and again...)
 smiley
Netherlands
You're welcome, one day you will be able to answer the questions asked here smiley-wink
Rob Tillaart
Pages: 1 2 3 [4] 5 6 ... 8   Go Up
