Loading...
Pages: 1 [2] 3 4 5   Go Down
Author Topic: MIDI Xilophone (over serial) to Ableton  (Read 5714 times)
Offline Offline
Jr. Member
View Profile
Yes, you were right, i add the "old" version SMv2c. Now i have downloaded the SMv2d and i can run it on Processing.
But still when i set baud rates the same i get red light in the converter (running from Programing) and no signal at all in the Midi Monitor.
Like this:
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Do you get any sound from tapping the sensors generated in processing?
Logged
Offline Offline
Jr. Member
View Profile
no, i get no sound...
Logged
Offline Offline
Jr. Member
View Profile
This morning i was reading the code from the Converter (which i am opening in Processing) and i noticed that it sais that having mmj installed makes some kind of bug.
I went to uninstall it, restarted the computer, opened again Processing...
...and got still the same result!
When baud rates are at the same speed i get only red light and no signal in Midi Monitor!
Logged
Offline Offline
Brattain Member
View Profile
WWW
OK, try this. Can you replace the Extensions folder with this one attached and see if it makes any difference.
It is to be found at:-
Macontosh HD -> Library -> Java
What version of the OS are you on?
It might be worth searching for people who have had trouble with Serial <> MIDI with your version.
If this doesn't work then we might have to explore going directly into Ableton. I don't have it but I could download the trial version and see what can be done directly.
Logged
Offline Offline
Jr. Member
View Profile
i have osx 10.6.8
i have replaced the extension folder and it still doesn't work, but i got an error message from Processing:
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
RXTX Warning:  Removing stale lock file. /var/lock/LK.008.011.010
Bah...   =/
If i would add a MIDI out port to the setup, would it mean i had to change all the code?
Let me see if i am doing things right.
I plug the Arduino via USB.
Open Arduino software and upload the sketch.
"play" a couple of piezos to confirm i get the TX light in arduino board.
Open Processing and the SMv2d sketch.
Run the sketch.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
i have osx 10.6.8
Me too.
Quote
Run the sketch.
Sounds OK as well, as long as the arduino serial monitor window is not open.
When I run processing I just get:-
Quote
Stable Library
That error message :-
might mean you have to find that file and then delete it. Then restart processing, worth a try.
Logged
Offline Offline
Jr. Member
View Profile
i can't find that file. Not even the folder...
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Code:
Is just a warning. It's telling you that it removed the stale file, that's why you can't find it.
Logged
Offline Offline
Brattain Member
View Profile
WWW
I couldn't run the stand alone application on my machine until is set it to run in 32 bit mode.
Click on the Serial_MIDI_Converter_V2D icon. Then select information from the finder and click the open in 32 bit mode in the window.
Now it opens fine. It might be worth trying this and see if it improves things. You could also try running Processing in the 32 bit mode as well.
Logged
Offline Offline
Jr. Member
View Profile
The message
Quote
come when i chose the "Midi Out Port".
Then when i press any of the piezodisks the only thing i get is the Serial RX Light blinking RED!!
I now tried running the both the stand alone application and Processing in 32-bit mode. Everything goes exactly the same.
If the lights blink red, it means that at least some kind of information is getting to Processing (?). Is it possible to see WHAT is getting there?
I am getting king of crazy (sad, frustrated, desperate,..., curious,...) , so i am tried something that maybe is also not so smart...
should the Arduino code run on Processing also?
I copied it into Processing and i got an error saying :
Quote
unexpected token: unsigned
processing.app.SketchException: unexpected token: unsigned
   at processing.mode.java.JavaBuild.preprocess(JavaBuild.java:326)
   at processing.mode.java.JavaBuild.preprocess(JavaBuild.java:197)
   at processing.mode.java.JavaBuild.build(JavaBuild.java:156)
   at processing.mode.java.JavaBuild.build(JavaBuild.java:135)
   at processing.mode.java.JavaMode.handleRun(JavaMode.java:176)
   at processing.mode.java.JavaEditor$20.run(JavaEditor.java:481)
   at java.lang.Thread.run(Thread.java:680)
the error was refering to this line of the code:
Quote
unsigned char PadNote[8] = {60,62,64,65,67,69,71,72};
well, maybe that is supposed to happen...
« Last Edit: March 27, 2012, 11:48:09 pm by boguz » Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Yes it is understandable. I don't think there is a sympathy smilie.
Quote
No, while the syntax is similar it is the language C in the Arduino and Java in Processing, so it will not work.
Quote
You can add print statements to processing to look at any variables while it is running. That could give you an insight into what is happening.
I was asking a friend about this yesterday and he said he had trouble with this program at first and it was down to the way the MIDI configured using the Audio MIDI setup application. The website for the serial <> MIDI converter had a guide to setting this up have you gone through this?
Logged
Offline Offline
Jr. Member
View Profile
Yes, when installed the Serial <> MIDI i have followed the instruction in their website on how to set things up.
i will try to get some kind of Serial Port Monitor and see if i can get some info there also...
Logged
Offline Offline
Jr. Member
View Profile
i have just tried a Serial Monitor (Serial Tools) and i got the same. i got green light blinking and the same value as before with the "Midi information".
I guess this means the serial information is arriving ok?
When i got to the Audio MIDI Setup -> Preferences and then choose Information, i get this:
Can it be that i am missing something i should have? Can i have something outdated?
Logged
Offline Offline
Brattain Member
View Profile
WWW
It looks the same as mine, attached.
I think we need to find out where it is going wrong.
Can you run up a sketch that talks from the arduino into processing.
Just something on the arduino that prints a string every second, and the processing prints out what it receives.
That would check the serial path into processing.
There is a sketch in Examples -> Library -> Serial -> Simple read.
After the :-
Code:
val = myPort.read();
put a
Code:
println(val);
You should then be printing the ASCII value of the bytes you receive from the arduino.
Logged
Pages: 1 [2] 3 4 5   Go Up
Print
Jump to:
