Loading...
Pages: [1]   Go Down
Author Topic: Where to store array of doubles  (Read 467 times)
Offline Offline
Newbie
View Profile
Hei,
In my library im writing im generating a array what has ~120 double elements. This generation is called  from setup() part of a sketch.
Now i was wondering is it possible to store this array in PROGMEM or do the array must be there allready at compile time to store it in PROGMEM?
What would be other options storing this array?
Priit.
« Last Edit: March 24, 2012, 07:24:39 am by soend » Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You can't write to PROGMEM at run time.
Will the array always be the same?  If so, you can put the constants into PROGMEM.
Logged
Offline Offline
Newbie
View Profile
Heres the main consept how this will work:
I have couple of "input values" what are used to generate data what is stored hold in the array. There is no actual need to generate the array every time arduino starts, only when these "input values" are changed. So, no, the array will not be always the same but it will be the same most of the times since the "input values" are not changed so often.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
120 doubles or floats take ~500 bytes, that can be in RAM if the rest of your application is not too RAM hungry.
If the changes are rare you could place the doubles in EEPROM, optionally an I2C EEPROM
Or store them in a file on an SD card
So far the storage alternatives, but there are more alternatives:
You said you calculate the doubles during setup(). that means that it is technically possible to calculate the floats if you need them. That probably means less RAM but extra time.
Another option might be finding the function that generates these 120 doubles given the inouts 0..120 (it is more difficult than you think but easier if you think)
And of course, why an array of doubles? Can the info not be stored in integers?
Finally there is interpolation, if the values can be interpolated you could use the map() or the multimap() functions.
In short:
Can you tell more about your doubles, how they are generated and how they are used?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
In short:
Im not calculating the values when i need them because this gives me option to move the calculation off the arduino and just send the values to arduino.
Array itself is basically a lookup table. Its holding hue values and the position in array represent temperature. So if the current temperature is 37 then i get matching hue for that:
Code:
double hue = _colors[temp];
and then il use this hue to set rgb led color.
What i realise  now is that my HsvToRgb method doesn't care anyway if its a double it uses it as a int anyway.  So yes, i can hold them as int-s.
Im not familiar with interpolation (had to even look it up on google) so not sure i could use map() or the multimap() functions.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
That saves you a factor 2 !
About interpolation:
Interpolation is often linear. Supose you have an input value between 0 and 1023 (analogRead) and you want to controll a servo with it which uses 0..179 degrees. You know that 0 maps on 0 and 1023 maps on 179. Than you can derive a formula
float val = 1.0 * analogRead(A0) * 179 /1023;    This function interpolates the ouutput for every value of analogRead().
The function becomes a bit complexer if e.g. 17..876 must be mapped upon 423..56 and that is where the map() function comes in. Google Arduino map.
If the interpolation is not linear you can use multimap() which approaches the nonlinear function with linear intervals.
Suppose your project range has the following {temp, hue} pairs :
0,0   10,20   20,30   30,50   40, 80   50, 90   60,110   70,115   80, 120   90, 140   100, 160
Definitely not linear, so multimap could be used, see - http://arduino.cc/playground/Main/MultiMap -
Give it a read smiley-wink
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Ok, but when using multimap then i would need 2 arrays - temperatures and hues:
Code:
int hues[] = {150,140,130,120,110,100, 90, 80, 70, 60, 50, 40, 30, 20};
int temps[]  = { 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33};
val = getTemp();
hue = multiMap(val, temps, hues, 14);
This way i would double the space used.
Here's the method how im mapping the values now:
Code:
void LedDriverClass::CalcHues(byte startTemp, byte endTemp, int startHue, int endHue)
double difference = (double)(startHue - endHue);
if (difference < 0)
difference = difference + 360;
double multiplier = difference/(endTemp - startTemp);
for(int i = tempStart; i<= tempEnd; ++i)
int hue = startHue - ((int) (i - startTemp)*multiplier);
if (hue < 0)
hue = hue + 360;
_colors[i] = hue;
Now when i call this method and give it for example startTemp 0 and endTemp 10, startHue 20 and endHue 0 then the result array would be:
_colors[] = {20, 18, 16, 14, 12, 10, 8, 6, 4, 2, 0, ...}
All the rest values in the array would be 0 (thats is also intentional). Now when i get temperature something like 5 i would just do _colors[5] and i will get the hue value what is 10 in this example.
But as i said before, i might be moving this calculation off the arduino and just upload/send the pre calculated values to arduino. And the question is where would be the best place to store these values?
(Since i havent got the microSD shield working with my Wifly shield (see topic: http://arduino.cc/forum/index.php/topic,98025.0.html)) then storing the values on SD card is out of options)
« Last Edit: March 24, 2012, 02:46:35 pm by soend » Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
val = getTemp();
If these are the real values it a 100% linear mapping that can be expressed in a formula which is far simpler than multiMapping.
float temp = getTempC();
float hue  =  150 - (temp-20) *10;
Please try the formula.
You would need multiMap() if there was no linear relation e.g. like below.
Code:
int hues[] = {255,240,220,200,190,160, 140, 110, 90, 80, 75, 40, 25, 20};
val = getTemp();
On the other hand you could use multimap and replace the hue array for different colormaps, just read 14 ints from somewhere or use another array.
Logged
Rob Tillaart
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
There's no so much calculation there that the Arduino can't do it on-the-fly:
Code:
int LedDriverClass::getHue(byte temperature, byte startTemp, byte endTemp, int startHue, int endHue)
    if (temperature < startTemp || temperature > endTemp)
        return 0;
    if (endHue <= startHue)
        endHue += 360;
    return map(temperature, startTemp, endTemp, startHue, endHue) % 360;
Logged
Offline Offline
Newbie
View Profile
Code:
        return 0;
        endHue += 360;
The problem i see there is that i need to support changing hue both ways - up or down. Basically if i want the color to change from blue to red then the hue value must start decreasing when temperature is rising.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Just add a parameter for clockwise (increasing hue) or counterclockwise (decreasing hue).
Code:
int LedDriverClass::getHue(byte temperature, byte startTemp, byte endTemp, int startHue, int endHue, bool clockwise)
        return 0;
    if (clockwise && endHue <= startHue)
        endHue += 360;
    if (!clockwise && startHue <= endHue)
        startHue += 360;
Logged
Pages: [1]   Go Up
Print
Jump to:
