Loading...
Pages: [1] 2   Go Down
Author Topic: Problem Opening Arduino  (Read 829 times)
Tennessee
Offline Offline
Newbie
View Profile
Hi all, I am new to these forums but have  been using arduino for about a year.  Most of the work I do Is on the lab computers at my university.  I recently tried to install arduino on my laptop so that I could work on my next project from home.  After downloading the file I tried to open the arduino.exe file.  The program acted like it was going to open up  but it stayed frozen on the blue arduino loading screen until a launch4j error message came up saying "an error occurred while starting the application".  I'm running windows 64 bit vista.  Is arduino not compatible with 64 bit vista or is something else going on?
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
Here is a link to a thread that discusses the same symptoms you are seeing:
http://arduino.cc/forum/index.php/topic,95016.msg713629.html#msg713629
It seems like there are several different causes for this issue, so I would suggest following the troubleshooting steps suggested in the thread to narrow down the cause for your particular issue.
Post back to this thread will any of your results and log files, so we can help solve your problem.
Logged
Tennessee
Offline Offline
Newbie
View Profile
Thanks for the reply.  Well I tried updating java and that did not fix the problem.   I tried finding the preferences folder but I do not have an arduino file under appdata.  When i downloaded arduino i just extracted the whole  file to my desktop.
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
There are several other troubleshooting steps to perform from that thread...
Quote
If that does not work, from a command line, launch arduino.exe with the following command:
arduino.exe --l4j-debug
Then send us the launch4j.log file in the Arduino folder to see if that tells us anything.
You can also try running the arduino.exe as an administrator. That worked for some other people.
Move the Arduino folder to the root directory; C:\Arduino\ for example.
Logged
Tennessee
Offline Offline
Newbie
View Profile
I set up the folder in my c drive.  Now arduino is under the directory C:\Arduino\arduino-1.0  I right clicked on the exe file and hit run as administrator and I had the same results.
I would like to try the command line thing but I do not know how to launch it through command line.
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
1. Press the Windows key + R
2. The Run dialog should pop up.
3. Enter or copy and paste the following text into the Open line:
    C:\Arduino\arduino-1.0\arduino.exe --l4j-debug
4. Select the OK button.
5. Now browse to the Arduino folder and send the launch4j.log file in that folder.
Logged
Tennessee
Offline Offline
Newbie
View Profile
Thanks I learned something new today.
Ok this is what the file says
CmdLine:   C:\Arduino\arduino-1.0\arduino.exe --l4j-debug
WOW64:      yes
Working dir:   C:\Arduino\arduino-1.0\.
Bundled JRE:   java
Check launcher:   C:\Arduino\arduino-1.0\java\bin\javaw.exe (OK)
Add classpath:   lib\pde.jar
Add classpath:   lib\core.jar
Add classpath:   lib\jna.jar
Add classpath:   lib\ecj.jar
Add classpath:   lib\RXTXcomm.jar
Launcher:   C:\Arduino\arduino-1.0\java\bin\javaw.exe
Launcher args:   -Xms128m -Xmx128m -classpath "lib;C:\Arduino\arduino-1.0\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
Args length:   162/32768 chars
Logged
Tennessee
Offline Offline
Newbie
View Profile
I ran it again and it came up with a new error at the end.
WOW64:      yes
Bundled JRE:   java
Error:      Invalid window handle.
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
Try launching with one of these commands, to see if this solves the problem.
C:\Arduino\arduino-1.0\arduino.exe --l4j-no-splash
C:\Arduino\arduino-1.0\arduino.exe --l4j-no-splash-err
Logged
Tennessee
Offline Offline
Newbie
View Profile
Tried both and nothing happened.  Not even an error message.
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
Now try executing this command: (this is one continuous command line entry)
C:\Arduino\arduino-1.0\java\bin\javaw.exe -Xms128m -Xmx128m -classpath "lib;C:\Arduino\arduino-1.0\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
This is the command that the launcher executes in the background. This will help determine if the problem is with the launcher or with the Java application.
Logged
Tennessee
Offline Offline
Newbie
View Profile
Thanks again for the  quick reply.  Just ran it and got a java virtual machine launcher error "could not find the main class: processing.app.Base. Program will exit."
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
That was my mistake. You need to execute that command within the Arduino directory.
1. Windows key + R.
2. Enter: cmd.exe
3. Press OK button.
4. Now type: cd \arduino\arduino-1.0
5. Press Enter key
6. You should see a command prompt that looks like this: C:\arduino\arduino-1.0>
7. Copy this command to the clip board: C:\Arduino\arduino-1.0\java\bin\javaw.exe -Xms128m -Xmx128m -classpath "lib;C:\Arduino\arduino-1.0\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
8. Now click the C:\ icon in the upper left corner of the command prompt window. You should get a menu.
9. Select the Edit -> Paste menu option to paste the command you copied to the command prompt.
10. Now press Enter.
Logged
Tennessee
Offline Offline
Newbie
View Profile
I did all of that and nothing happened
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
Replace the following command with step 7:
C:\Arduino\arduino-1.0\java\bin\java.exe -verbose -Xms128m -Xmx128m -classpath "lib;C:\Arduino\arduino-1.0\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base > output.txt
This will send all the verbose Java output to the file output.txt
Reply with the output.txt as an attachment. Hopefully this will indicate the problem.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
