A straight linear search isn't that slow, for the number of items you can fit into memory. For example, worst-case:
const int MAX_ITEMS = 800;
int array [MAX_ITEMS];
void setup ()
array [MAX_ITEMS - 1] = 42;
Serial.begin (115200);
unsigned long start = micros ();
boolean found = false;
for (int i = 0; i < MAX_ITEMS; i++)
if (array [i] == 42)
found = true;
break;
unsigned long finish = micros ();
Serial.print ("Time taken = ");
Serial.print (finish - start);
Serial.println (" uS");
Serial.print ("Found = ");
Serial.println (found);
} // end of setup
void loop () {}
Output:
Time taken = 752 uS
Found = 1
That's under a millisecond. But if you want to better that,
and the data is in sequence, you could use a binary search...
#include <iterator>
#include <algorithm>
void setup ()
unsigned long longest = 0;
// each array element is its own position (this puts them in sequence)
array [i] = i;
// try each one, see which is longest
bool found = std::binary_search(array, &array [MAX_ITEMS], i);
if (!found)
Serial.print ("At position ");
Serial.print (i);
Serial.println (", not found, strange.");
longest = max (longest, finish - start);
Serial.print (longest);
} // end of setup
void loop () {}
Output:
Time taken = 28 uS
That's somewhat faster. That algorithm is in the STL (Standard Template Library) although you could no doubt find your own by a Google search if you didn't want all of the STL.
