Topic: Duemilanove or Uno? (Read 970 times) previous topic - next topic
trenmost
Hi!
I used an ATMega128 based board at the university, but i would like to buy my own arduino.
Initially i preferred the Uno, because it is newer, but some of the uno users (on the internet) said that Duemilanove is more reliable, and its easier to program. Is this true?
Can you describe whats the difference between them and help me which one should i buy?
robtillaart
The boards are quite identical with only a small differences (check the hardware section for the details). If you want reliability you should use the IDE 0.22 / 0.23  iso the IDE 1.0 as not all libs are ported to 1.0 yet.
As you are a student you may go for the cheaper of the two, will probably be the Duemilanove.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
retrolefty
Hi!
No, they are basically the same from a reliability and ease of programming point. The uno uses a small, faster baudrate bootloader, so uploads happen faster and there is a little more sketch memory space then the older board.
Different bootloader, different USB serial converter chip.
trenmost
Thank you very much for the answers, i'll go with the Uno probably then :)
