Topic: Read values from webpage to control relay (Ethernet Shield) (Read 10074 times) previous topic - next topic
George-Xrik
What I am trying to do is with arduino get values from a web site, and from the values close or open a relay (turn a digital pin high or low). While at the same time host a simple HTML page that displays the current position of the relay and the values I am reading from the website.
I am using an arduino mega (ATmega1280) board and an Ethernet shield.
I have managed to set up a simple HTML page that can be viewed on the local network and externally over internet, using the web server example. In other words I have set up the port forwarding for the arduino.
I need help or suggestions (even feasibility) on how to get values from a web site and displaying them on the html page hosted by the arduino.
Thanks
PaulS
Quote
What web site do you want to get data from? Is the Arduino supposed to to get data mining in addition to serving up a page?
George-Xrik
The web site is http://80.85.104.41/ its a sunny webbox, say I would like to get the total yield value.
Quote
I have no idea, that`s why I am posting here to see if anyone has done it before or if it is even possible. If its not possible, I would have to settle for getting the values and activating the relay only (would still need help to do this).
PaulS
That site requires a password to access. What happens when you enter a password?
Making the Arduino-as-server serve up a web page that contains a form, and making the Arduino process the form when the submit button is pressed is a piece of cake, it you understand client/server/web programming.
If not, zoomkat will come along shortly and post some code. Mine's on my other computer.
zoomkat
Quote
Below is some combined server/client code you can experiment with. You will need to develop the code required to perform your specific needs.
Code: [Select]
//zoomkat 12-08-11, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 4 high/low
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,1,102); // ip in lan
IPAddress gateway(192,168,1,1); // internet access via router
IPAddress subnet(255,255,255,0); //subnet mask
IPAddress myserver(208,104,2,86); // zoomkat web page
EthernetServer server(84); //server port
EthernetClient client;
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  Ethernet.begin(mac, ip, subnet, gateway);
  server.begin();
  Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded
  Serial.println("Send an g in serial monitor to test client"); // what to do to test client
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call sendGET function
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println("HTTP/1.1 204 Zoomkat");
            client.println();
            client.println();
          else {
            client.println("HTTP/1.1 200 OK"); //send new page
            client.println("Content-Type: text/html");
            client.println();
            client.println("<HTML>");
            client.println("<HEAD>");
            client.println("<TITLE>Arduino GET test page</TITLE>");
            client.println("</HEAD>");
            client.println("<BODY>");
            client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
            client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
            client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
            //client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
            client.println("<IFRAME name=inlineframe style=\"display:none\" >");
            client.println("</IFRAME>");
            client.println("</BODY>");
            client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
void sendGET() //client function to send/receie GET request data.
  if (client.connect(myserver, 80)) {
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
  else {
    Serial.println("connection failed");
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    Serial.print(c);
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop();
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
George-Xrik
First of all thanks for the help.
I have managed to get the code zoomkat posted working, thanks again it worked fine with minor alterations of the ip in lan and server port [I have set the sever to 80].
I have some questions regarding the code:
Should the led (pin4) remain off(low) once the off button in the web page has been clicked?
....as it is only going off for a moment and back on, i.e one blink.
what is this part of the code doing?
Code: [Select]
            client.println();
            client.println();
Also this part of the code is confusing me,
Code: [Select]
    client.println();
....I am assuming the
Code: [Select]
client.println("GET /~shb/arduino.txt HTTP/1.0"); is calling something and this is returned and printed to the serial port as
Code: [Select]
HTTP/1.1 200 OK
Date: Sat, 31 Mar 2012 10:11:40 GMT
Server: Apache
Last-Modified: Sat, 13 Nov 2010 16:31:40 GMT
Accept-Ranges: bytes
Content-Length: 51
Connection: close
Content-Type: text/plain; charset=UTF-8
Woohoo! Your arduino ethernet client works!
zoomkat
disconnecting.
is that correct ?
George-Xrik
@ PaulS
Quote
It directs you to a new page that gives a more detailed account of the Kwh production form a PV plant, i.e Current and Voltage measurement values are stored in this data base.
I am trying set up the ardunio to get this values and show them on the web page and also use them to actuate the relay.
lafontas
Does the target page have a RSS feed or does the website provide an API? Otherwise you need to look at scraping the value from the site/page, here's a Wikipedia article on web scraping. http://en.wikipedia.org/wiki/Web_scraping
zoomkat
Quote
Pin 4 should stay low until another request tells it to go high. There should be no blink (no pin state changeunless commanded). Do note that using your browser's back button will resend the previous command.
Quote
This tells the browser to not expect a new page to be sent. I use this with a javascript video feed to prevent disruption of the feed. You can remove it if you don't need it.
Quote
This is the client part of the code. It sends a request to a server for the arduino.txt file.
George-Xrik
Quote
can you explain further the arduino.txt !
Quote
no neither an RSS feed nor an API, so will look into scrapping the values.
George-Xrik
I finally got some time to continue this project.
Picking up where I left off, the following code is working fine. With one exception when I click the on or off button using google chrome as the browser it only blinks off the led and the turns the led back on. So if anyone knows why this is happening I would be happy to learn about it, but for now I will use explorer and safari as browser when communicating with arduino.
Also if anyone know about a good tutorial on ethernet syntax would be much appreciated.
Code: [Select]
//George-Xrik 31-03-12, updated
//address will look like http://192.168.1.177 or http://88.203.15.76 when submited
#include <SPI.h>
IPAddress ip(192,168,2,130); // ip in lan
IPAddress gateway(192,168,2,1); // internet access via router
EthernetServer server(80); //server port
String readString;
void setup(){
  pinMode(8, OUTPUT); //pin selected to control
  server.begin();
  Serial.println("server/client 1.0 test 31/03/12"); // keep track of what is loaded
  Serial.println("Send g in serial monitor to test client"); // what to do to test client
void loop(){
    byte inChar;
    if(inChar == 'g')
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
            client.println();
            client.println();
          else {
            client.println();
            //client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
            client.println("<H1>George's simple Arduino 1.0 button</H1>");
          delay(1);
          //stopping client
          client.stop();
            digitalWrite(8, HIGH);    // set pin 4 high
            digitalWrite(8, LOW);    // set pin 4 low
          readString="";
    client.println();
  else {
    Serial.print(c);
  client.stop();
the following is the serial communication
connected
HTTP/1.1 200 OK
Date: Sat, 28 Apr 2012 15:03:54 GMT
Server: Apache
Content-Length: 51
Connection: close
zoomkat
disconnecting.
GET /?on HTTP/1.1 >>> from Safari (iphone)
Led On
GET /?off HTTP/1.1
Led Off
GET /?on HTTP/1.1
Led On
GET /?off HTTP/1.1
Led Off
GET /?on HTTP/1.1
Led On
GET /favicon.ico HTTP/1.1
Led On
GET /?off HTTP/1.1
Led Off
Led On
George-Xrik
Code: [Select]
#include <SPI.h>
String readString;
void setup(){
  server.begin();
void loop(){
    byte inChar;
    if(inChar == 'g')
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
            client.println();
            client.println();
          else {
            client.println();
          delay(1);
          //stopping client
          client.stop();
          readString="";
    client.println();
  else {
    Serial.print(c);
  client.stop();
connected
HTTP/1.1 200 OK
Server: Apache
Content-Length: 51
Connection: close
zoomkat
disconnecting.
Led On                                  >>> from Safari (iphone)
GET /?off HTTP/1.1                >>> from Safari (iphone)
Led Off                                 >>> from Safari (iphone)
GET /?on HTTP/1.1                 >>> from explorer
Led On                                  >>> from explorer
GET /?off HTTP/1.1                >>> from explorer
Led Off                                 >>> from explorer
GET /?on HTTP/1.1                 >>> from chrome
Led On                                 >>> from chrome
GET /favicon.ico HTTP/1.1     >>> from chrome
GET /?off HTTP/1.1              >>> from chrome
Led Off                               >>> from chrome
What should be noted is that i only click on and than off once on each browser, chrome acts strangely and turns the led back on.
zoomkat
#12
Apr 28, 2012, 07:47 pm Last Edit: Apr 29, 2012, 12:12 am by zoomkat Reason: 1
Quote
Sounds like chrome is being non compliant with the returned 204 status code. 204 tells the browser to not refresh the currrent page. Looks like chrome is refreshing orreloading a prevous page instead of doing nothing. The below code refreshes the current page and doesn't have te 204 code included.
Code: [Select]
//zoomkat 2-13-12
//DNS and DHCP-based web client test code
//open serial monitor and send an e to test
//and to see test result
//browser equivelant URL:
// http://web.comporium.net/~shb/arduino.txt
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
char serverName[] = "www.ahaw.allalla.com"; // zoomkat's test web page server
void setup(){
  Serial.println("DNS and DHCP-based web client test 2/13/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  // print your local IP address:
  Serial.print("Arduino IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
void loop(){
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    //test GET request
    client.println("GET /dataterima.xml HTTP/1.0"); //download text
    //client.println("GET /terimaphp.php?trua=0ff1001 HTTP/1.0"); //download text
    client.println("Host: www.ahaw.allalla.com");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  client.stop(); //stop client
George-Xrik
thanks for the reply
Quote
which part would be the 204 code, that I have to eliminate ?
zoomkat
Quote
Perhaps the part that is not included.  8)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
