« on: March 26, 2012, 07:18:09 am » |
What I am trying to do is with arduino get values from a web site, and from the values close or open a relay (turn a digital pin high or low). While at the same time host a simple HTML page that displays the current position of the relay and the values I am reading from the website.
I am using an arduino mega (ATmega1280) board and an Ethernet shield.
I have managed to set up a simple HTML page that can be viewed on the local network and externally over internet, using the web server example. In other words I have set up the port forwarding for the arduino.
I need help or suggestions (even feasibility) on how to get values from a web site and displaying them on the html page hosted by the arduino.
Thanks
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: March 26, 2012, 07:24:21 am » |
I need help or suggestions (even feasibility) on how to get values from a web site and displaying them on the html page hosted by the arduino. What web site do you want to get data from? Is the Arduino supposed to to get data mining in addition to serving up a page?
« Reply #2 on: March 26, 2012, 12:07:38 pm » |
The web site is http://80.85.104.41/ its a sunny webbox, say I would like to get the total yield value. Is the Arduino supposed to to get data mining in addition to serving up a page? I have no idea, that`s why I am posting here to see if anyone has done it before or if it is even possible. If its not possible, I would have to settle for getting the values and activating the relay only (would still need help to do this).
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: March 26, 2012, 02:22:48 pm » |
That site requires a password to access. What happens when you enter a password?
Making the Arduino-as-server serve up a web page that contains a form, and making the Arduino process the form when the submit button is pressed is a piece of cake, it you understand client/server/web programming.
If not, zoomkat will come along shortly and post some code. Mine's on my other computer.
« Reply #4 on: March 26, 2012, 05:51:38 pm » |
What I am trying to do is with arduino get values from a web site, and from the values close or open a relay (turn a digital pin high or low). While at the same time host a simple HTML page that displays the current position of the relay and the values I am reading from the website. Below is some combined server/client code you can experiment with. You will need to develop the code required to perform your specific needs. //zoomkat 12-08-11, combined client and server //simple button GET with iframe code //for use with IDE 1.0 //open serial monitor and send an g to test client and //see what the arduino client/server receives //web page buttons make pin 4 high/low //use the \ slash to escape the " in the html //address will look like http://192.168.1.102:84 when submited //for use with W5100 based ethernet shields
#include <SPI.h> #include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address IPAddress ip(192,168,1,102); // ip in lan IPAddress gateway(192,168,1,1); // internet access via router IPAddress subnet(255,255,255,0); //subnet mask IPAddress myserver(208,104,2,86); // zoomkat web page EthernetServer server(84); //server port EthernetClient client; String readString;
void setup(){
pinMode(4, OUTPUT); //pin selected to control Ethernet.begin(mac, ip, subnet, gateway); server.begin(); Serial.begin(9600); Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded Serial.println("Send an g in serial monitor to test client"); // what to do to test client }
void loop(){ // check for serial input if (Serial.available() > 0) { byte inChar; inChar = Serial.read(); if(inChar == 'g') { sendGET(); // call sendGET function } }
EthernetClient client = server.available(); if (client) { while (client.connected()) { if (client.available()) { char c = client.read();
//read char by char HTTP request if (readString.length() < 100) {
//store characters to string readString += c; //Serial.print(c); }
//if HTTP request has ended if (c == '\n') {
/////////////// Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header if(readString.indexOf('?') >=0) { //don't send new page client.println("HTTP/1.1 204 Zoomkat"); client.println(); client.println(); } else { client.println("HTTP/1.1 200 OK"); //send new page client.println("Content-Type: text/html"); client.println();
client.println("<HTML>"); client.println("<HEAD>"); client.println("<TITLE>Arduino GET test page</TITLE>"); client.println("</HEAD>"); client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>"); client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
//client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">"); client.println("<IFRAME name=inlineframe style=\"display:none\" >"); client.println("</IFRAME>");
client.println("</BODY>"); client.println("</HTML>"); }
delay(1); //stopping client client.stop();
///////////////////// control arduino pin if(readString.indexOf("on") >0)//checks for on { digitalWrite(4, HIGH); // set pin 4 high Serial.println("Led On"); } if(readString.indexOf("off") >0)//checks for off { digitalWrite(4, LOW); // set pin 4 low Serial.println("Led Off"); } //clearing string for next read readString="";
////////////////////////// void sendGET() //client function to send/receie GET request data. { if (client.connect(myserver, 80)) { Serial.println("connected"); client.println("GET /~shb/arduino.txt HTTP/1.0"); client.println(); } else { Serial.println("connection failed"); Serial.println(); }
while(client.connected() && !client.available()) delay(1); //waits for data while (client.connected() || client.available()) { //connected or data available char c = client.read(); Serial.print(c); }
Serial.println(); Serial.println("disconnecting."); Serial.println("=================="); Serial.println(); client.stop();
« Reply #5 on: March 31, 2012, 05:19:27 am » |
First of all thanks for the help. I have managed to get the code zoomkat posted working, thanks again it worked fine with minor alterations of the ip in lan and server port [I have set the sever to 80]. I have some questions regarding the code: Should the led (pin4) remain off(low) once the off button in the web page has been clicked? ....as it is only going off for a moment and back on, i.e one blink. what is this part of the code doing? //now output HTML data header if(readString.indexOf('?') >=0) { //don't send new page client.println("HTTP/1.1 204 Zoomkat"); client.println(); client.println(); Also this part of the code is confusing me, void sendGET() //client function to send/receie GET request data. { if (client.connect(myserver, 80)) { Serial.println("connected"); client.println("GET /~shb/arduino.txt HTTP/1.0"); client.println(); ....I am assuming the client.println("GET /~shb/arduino.txt HTTP/1.0") ; is calling something and this is returned and printed to the serial port as HTTP/1.1 200 OK Date: Sat, 31 Mar 2012 10:11:40 GMT Server: Apache Last-Modified: Sat, 13 Nov 2010 16:31:40 GMT Accept-Ranges: bytes Content-Length: 51 Connection: close Content-Type: text/plain; charset=UTF-8
Woohoo! Your arduino ethernet client works! zoomkat disconnecting. ==================
is that correct ?
« Reply #6 on: March 31, 2012, 06:08:04 am » |
@ PaulS That site requires a password to access. What happens when you enter a password? It directs you to a new page that gives a more detailed account of the Kwh production form a PV plant, i.e Current and Voltage measurement values are stored in this data base. I am trying set up the ardunio to get this values and show them on the web page and also use them to actuate the relay.
« Reply #7 on: March 31, 2012, 06:46:42 am » |
Does the target page have a RSS feed or does the website provide an API? Otherwise you need to look at scraping the value from the site/page, here's a Wikipedia article on web scraping. http://en.wikipedia.org/wiki/Web_scraping
« Reply #8 on: March 31, 2012, 11:00:36 am » |
Should the led (pin4) remain off(low) once the off button in the web page has been clicked? ....as it is only going off for a moment and back on, i.e one blink. Pin 4 should stay low until another request tells it to go high. There should be no blink (no pin state changeunless commanded). Do note that using your browser's back button will resend the previous command. what is this part of the code doing? This tells the browser to not expect a new page to be sent. I use this with a javascript video feed to prevent disruption of the feed. You can remove it if you don't need it. Also this part of the code is confusing me, This is the client part of the code. It sends a request to a server for the arduino.txt file.
« Reply #9 on: April 04, 2012, 06:55:10 am » |
This is the client part of the code. It sends a request to a server for the arduino.txt file. can you explain further the arduino.txt ! Does the target page have a RSS feed or does the website provide an API? Otherwise you need to look at scraping the value from the site/page no neither an RSS feed nor an API, so will look into scrapping the values.
« Reply #10 on: April 28, 2012, 10:07:17 am » |
I finally got some time to continue this project. Picking up where I left off, the following code is working fine. With one exception when I click the on or off button using google chrome as the browser it only blinks off the led and the turns the led back on. So if anyone knows why this is happening I would be happy to learn about it, but for now I will use explorer and safari as browser when communicating with arduino. Also if anyone know about a good tutorial on ethernet syntax would be much appreciated. //George-Xrik 31-03-12, updated //zoomkat 12-08-11, combined client and server //simple button GET with iframe code //for use with IDE 1.0 //open serial monitor and send an g to test client and //see what the arduino client/server receives //web page buttons make pin 4 high/low //use the \ slash to escape the " in the html //address will look like http://192.168.1.177 or http://88.203.15.76 when submited //for use with W5100 based ethernet shields
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address IPAddress ip(192,168,2,130); // ip in lan IPAddress gateway(192,168,2,1); // internet access via router IPAddress subnet(255,255,255,0); //subnet mask IPAddress myserver(208,104,2,86); // zoomkat web page EthernetServer server(80); //server port EthernetClient client; String readString;
void setup(){
pinMode(8, OUTPUT); //pin selected to control Ethernet.begin(mac, ip, subnet, gateway); server.begin(); Serial.begin(9600); Serial.println("server/client 1.0 test 31/03/12"); // keep track of what is loaded Serial.println("Send g in serial monitor to test client"); // what to do to test client }
//client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>"); client.println("<H1>George's simple Arduino 1.0 button</H1>");
///////////////////// control arduino pin if(readString.indexOf("on") >0)//checks for on { digitalWrite(8, HIGH); // set pin 4 high Serial.println("Led On"); } if(readString.indexOf("off") >0)//checks for off { digitalWrite(8, LOW); // set pin 4 low Serial.println("Led Off"); } //clearing string for next read readString="";
the following is the serial communication server/client 1.0 test 31/03/12 Send g in serial monitor to test client connected HTTP/1.1 200 OK Date: Sat, 28 Apr 2012 15:03:54 GMT Server: Apache Last-Modified: Sat, 13 Nov 2010 16:31:40 GMT Accept-Ranges: bytes Content-Length: 51 Connection: close Content-Type: text/plain; charset=UTF-8
GET /?on HTTP/1.1 >>> from Safari (iphone)
Led On GET /?off HTTP/1.1
Led Off GET /?on HTTP/1.1
Led On GET /favicon.ico HTTP/1.1
Led Off GET /favicon.ico HTTP/1.1
Led On
« Reply #11 on: April 28, 2012, 10:19:21 am » |
void setup(){
Led On >>> from Safari (iphone) GET /?off HTTP/1.1 >>> from Safari (iphone)
Led Off >>> from Safari (iphone) GET /?on HTTP/1.1 >>> from explorer
Led On >>> from explorer GET /?off HTTP/1.1 >>> from explorer
Led Off >>> from explorer GET /?on HTTP/1.1 >>> from chrome
Led On >>> from chrome GET /favicon.ico HTTP/1.1 >>> from chrome
Led On >>> from chrome GET /?off HTTP/1.1 >>> from chrome
Led Off >>> from chrome GET /favicon.ico HTTP/1.1 >>> from chrome
What should be noted is that i only click on and than off once on each browser, chrome acts strangely and turns the led back on.
« Reply #12 on: April 28, 2012, 12:47:17 pm » |
With one exception when I click the on or off button using google chrome as the browser it only blinks off the led and the turns the led back on. So if anyone knows why this is happening I would be happy to learn about it, but for now I will use explorer and safari as browser when communicating with arduino. Sounds like chrome is being non compliant with the returned 204 status code. 204 tells the browser to not refresh the currrent page. Looks like chrome is refreshing orreloading a prevous page instead of doing nothing. The below code refreshes the current page and doesn't have te 204 code included. //zoomkat 2-13-12 //DNS and DHCP-based web client test code //for use with IDE 1.0 //open serial monitor and send an e to test //and to see test result //for use with W5100 based ethernet shields //browser equivelant URL: // http://web.comporium.net/~shb/arduino.txt //note that the below bug fix may be required // http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h> #include <Ethernet.h> byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address char serverName[] = "www.ahaw.allalla.com"; // zoomkat's test web page server EthernetClient client;
void setup(){ Serial.begin(9600); Serial.println("DNS and DHCP-based web client test 2/13/12"); // so I can keep track of what is loaded Serial.println("Send an e in serial monitor to test"); // what to do to test // start the Ethernet connection: if (Ethernet.begin(mac) == 0) { Serial.println("Failed to configure Ethernet using DHCP"); // no point in carrying on, so do nothing forevermore: while(true); } // print your local IP address: Serial.print("Arduino IP address: "); for (byte thisByte = 0; thisByte < 4; thisByte++) { // print the value of each byte of the IP address: Serial.print(Ethernet.localIP()[thisByte], DEC); Serial.print("."); } Serial.println(); Serial.println(); }
void loop(){ // check for serial input if (Serial.available() > 0) //if something in serial buffer { byte inChar; // sets inChar as a byte inChar = Serial.read(); //gets byte from buffer if(inChar == 'e') // checks to see byte is an e { sendGET(); // call sendGET function below when byte is an e } } }
void sendGET() //client function to send/receive GET request data. { if (client.connect(serverName, 80)) { //starts client connection, checks for connection Serial.println("connected"); //test GET request client.println("GET /dataterima.xml HTTP/1.0"); //download text //client.println("GET /terimaphp.php?trua=0ff1001 HTTP/1.0"); //download text client.println("Host: www.ahaw.allalla.com"); client.println(); //end of get request } else { Serial.println("connection failed"); //error message if no client connect Serial.println(); }
while(client.connected() && !client.available()) delay(1); //waits for data while (client.connected() || client.available()) { //connected or data available char c = client.read(); //gets byte from ethernet buffer Serial.print(c); //prints byte to serial monitor }
Serial.println(); Serial.println("disconnecting."); Serial.println("=================="); Serial.println(); client.stop(); //stop client
« Last Edit: April 28, 2012, 05:12:39 pm by zoomkat »
« Reply #13 on: April 28, 2012, 01:42:49 pm » |
thanks for the reply The below code refreshes the current page and doesn't have te 204 code included. which part would be the 204 code, that I have to eliminate ?
« Reply #14 on: April 28, 2012, 05:18:52 pm » |
thanks for the reply The below code refreshes the current page and doesn't have te 204 code included. which part would be the 204 code, that I have to eliminate ? Perhaps the part that is not included.
