Topic: Change Power Level Xbee (series1) (Read 4383 times) previous topic - next topic
acintra
Hello guys I want to change the power level of my xbees through source code to my college project.
I have 2 XBee 1mW Chip Antenna - Series 1 (802.15.4), one XBee Explorer USB and one arduino duemilanove connected to a XBee Shield.
I already now how to set the power level using the X-CTU software, but I want to change that through source code because my project is about power consumption of a wirelles network. So I want to now if there is a library or a function in one of the standard libraries that do the power level change.
I had found some old libraries that don't have the function that I'm looking for.
Thanks.
PaulS
You can send AT commands to the XBee, just like X-CTU does, to change settings.
acintra
But there's a way to send this AT command through source code?
Because I'm trying to do something autonomous, that don't need my interaction with serial communication.
PaulS
Yes.
How is the XBee communicating with the Arduino? Semaphore flags waving around?
acintra
One of the Xbees is connected to the USB Xplorer that's connected to the computer. The second Xbee is connected to one Xbee Shield that's connected to one arduino duemilanove,being powered trough a external power supply (VIN/GND).
I want that the xbee that's connected to arduino/xbee shield could change your power level on an autonomous way to save power, decreasing the power level when signal is strong and increasing when signal is weak.
PaulS
You didn't answer this question. I'll tell you - the communication is via Serial.print(), Serial.write(), Serial.println(), Serial.read(), and Serial.available().
So, yes, you can send +++ to the XBee, to put it into command mode, and then send it AT commands, using Serial.print().
acintra
Thanks PaulS
I will try this:
Serial.print(+++);
Serial.print(ATPL);
Serial.print(x); //4,3,2,1
I will tell you if it works.
If that's
PaulS
I will try this:
Serial.print(+++);
Serial.print(ATPL);
It may be necessary to play with delay() times, to give the XBee time to enter command mode.
It definitely will be necessary to read what the XBee is responding with, to assure, for instance, that it entered command mode, before sending it an AT command.
acintra
I'll do a test within the code using the Serial.read(), to see if the command was received correctly, and I will put the delay too.
And I'll do it on Wednesday because tomorrow I have a lot of classes.
But thanks PaulS, you were very helpful, helped me a lot.
acintra
#9
Mar 28, 2012, 04:58 pm Last Edit: Mar 28, 2012, 05:05 pm by acintra Reason: 1
  I'm using the following code just to do some tests:
void setup ()
void loop ()
 Serial.print("+++");
 delay(4000);
 Serial.println("ATPL");
 Serial.println("ATPL 2");
 exit(1);
  But that isn't working, because after I did the upload to arduino board and connected the xbee shield with the xbee and I open the X-CTU serial terminal to see if that's working.
  The terminal shows me the code but don't return me the "OK" after the "+++", the ATPL command is typed autonomous by arduino but doesn't work.
  Do you guys nows what's wrong with the code?
  Thanks
"Sorry for me english, is not my native language"
PaulS
That code should be in setup(), or a function that gets called only as needed, not in loop().
The code talks to the XBee, but doesn't listen to the XBee. Why not?
acintra
The code isn't listening to xbee because this is only a prototype code, I'm using that just to learn how to use the AT commands in the source code. After I will do a complete code to my project
But thanks PaulS like always you helped me a lot.
PaulS
In the production version, you might be able to get away with not reading the reply. In the prototype/development phase it is crucial to read the reply, to make sure that it is what you think are getting.
acintra
Ok that's still not working...
This is the code that I'm using now:
void setup ()
  delay(3000);
  if(Serial.read()=='OK'){
  if(Serial.read()>=3){
void loop ()
But I'm still note receiving the "OK" from the command "+++", and not receiving too the return of ATPL.
I listened to the returns too like you said. I really don't now what to do to this works.
PaulS
Serial.read() returns one byte. That one byte is almost certainly not equal to the multibyte constant 'OK'.
