Topic: I can't burn the bootloader on Paperduino (Read 1 time) previous topic - next topic
aldebaran
Hi there!
I'm really noob! (and the search box didn't help me, so forgive me!)
My problem is the following: I can't burn the bootloader on a Paperduino with the parallel programmer.
When I'm going to burn the bootloader I receive the following message:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA8 is 1E 93 07
***failed;
avrdude: verification error, first mismatch at byte 0x0000
         0xca != 0xff
avrdude: verification error; content mismatch
I have one idea about what's wrong: I'm using the parallel port for burning (but in the arduino software all the ports are serial - COM1 to N), but I'm a little bit confused about this situation.
Could you please help me? Thanks!
spycatcher2k
What Chip do you have on your paperduino?
http://www.uk-pcb.co.uk - UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. Arduino & C# PC programming.
aldebaran
ATMEGA 8
and I selected this from the menu ...
spycatcher2k
Hi - can you post the verbose output please(Shift+upload) maybe it can help us.
aldebaran
here you are:
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=22 -I
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\sketch_mar27a.cpp -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\sketch_mar27a.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=22 -I
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\pins_arduino.c -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\pins_arduino.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\WInterrupts.c -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\WInterrupts.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\wiring.c -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\wiring_analog.c -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_analog.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\wiring_digital.c -oC:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_digital.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\wiring_pulse.c -oC:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_pulse.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\wiring_shift.c -oC:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_shift.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\HardwareSerial.cpp -oC:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\HardwareSerial.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\main.cpp -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\main.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\Print.cpp -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\Print.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\Tone.cpp -oC:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\Tone.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\WMath.cpp -oC:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\WMath.cpp.o
aldebaran
part two:
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino\WString.cpp -o
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\WString.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\pins_arduino.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\WInterrupts.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_analog.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_digital.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_pulse.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\wiring_shift.c.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\HardwareSerial.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\main.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\Print.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\Tone.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\WMath.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-ar rcs C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\WString.cpp.o
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\tools\avr\bin\avr-gcc -Os -Wl,--gc-sections -mmcu=atmega8 -o C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\sketch_mar27a.cpp.elf C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\sketch_mar27a.cpp.o C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a -L
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp -lm
C:\DOCUME~1\ADMINI~1\IMPOST~1\Temp\build4270235012515341313.tmp\core.a(main.cpp.o): In function `main':
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino/main.cpp:7: undefined reference to `setup'
C:\Documents and Settings\Administrator\Desktop\arduino-0023\hardware\arduino\cores\arduino/main.cpp:10: undefined reference to `loop'java.io.FileNotFoundException:
C:\Documents and Settings\Administrator\Desktop\arduino-0023\reference (Accesso negato)
   at java.io.FileInputStream.open(Native Method)
   at java.io.FileInputStream.<init>(FileInputStream.java:106)
   at processing.app.Base.copyFile(Base.java:2126)
   at processing.app.Sketch.addFile(Sketch.java:1014)
   at processing.app.Editor$FileDropHandler.importData(Editor.java:341)
   at javax.swing.TransferHandler.importData(TransferHandler.java:745)
   at javax.swing.TransferHandler$DropHandler.drop(TransferHandler.java:1468)
   at java.awt.dnd.DropTarget.drop(DropTarget.java:434)
   at javax.swing.TransferHandler$SwingDropTarget.drop(TransferHandler.java:1193)
   at sun.awt.dnd.SunDropTargetContextPeer.processDropMessage(SunDropTargetContextPeer.java:500)
   at sun.awt.dnd.SunDropTargetContextPeer$EventDispatcher.dispatchDropEvent(SunDropTargetContextPeer.java:812)
   at sun.awt.dnd.SunDropTargetContextPeer$EventDispatcher.dispatchEvent(SunDropTargetContextPeer.java:736)
   at sun.awt.dnd.SunDropTargetEvent.dispatch(SunDropTargetEvent.java:30)
   at java.awt.Component.dispatchEventImpl(Component.java:4487)
   at java.awt.Container.dispatchEventImpl(Container.java:2099)
   at java.awt.Component.dispatchEvent(Component.java:4460)
   at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
   at java.awt.LightweightDispatcher.processDropTargetEvent(Container.java:4309)
   at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4163)
   at java.awt.Container.dispatchEventImpl(Container.java:2085)
   at java.awt.Window.dispatchEventImpl(Window.java:2475)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
aldebaran
OK.
I rebuild the circuit and the parallel cable and I tried once again.
Same result! It means that either the cable I used is wrong or I did mistakes in the circuit.
So I started looking around, trying to understand what's wrong.
If I look at the avrdude config file I see that the "dapa" programmer (paralle programmer) uses MISO, MOSI, SCK, RESET and pin3 (VCC) connections but the cable [url]http://arduino.cc/en/Hacking/ParallelProgrammer?from=Main.ParallelProgrammer/url] uses connections with MISO, MOSI, SCK, RESET and Ground. Is that correct?
Using avrdude which are the commands to test the board and to burn the bootloader?
Thanks for helping
aldebaran
Here you are the verbose mode
C:\Documents and Settings\Administrator\Desktop\avrdude-5.4-win>avrdude -p atmega8 -c dapa -F -v -v
avrdude: Version 5.4, compiled on Jul 15 2007 at 12:37:51
         System wide configuration file is "C:\Documents and Settings\Administrator\Desktop\avrdude-5.4-win\avrdude.conf"
         Using Port            : lpt1
         Using Programmer      : dapa
         AVR Part              : ATMEGA8
         Chip Erase delay      : 10000 us
         PAGEL                 : PD7
         BS2                   : PC2
         RESET disposition     : dedicated
         RETRY pulse           : SCK
         serial program mode   : yes
         parallel program mode : yes
         Timeout               : 200
         StabDelay             : 100
         CmdexeDelay           : 25
         SyncLoops             : 32
         ByteDelay             : 0
         PollIndex             : 3
         PollValue             : 0x53
         Memory Detail         :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    0      0  9000  9000 0xff 0xff
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : PPI
         Description     : Direct AVR Parallel Access cable
           VCC     = 3
           BUFF    =  (not used)
           RESET   = 16
           SCK     = 1
           MOSI    = 2
           MISO    = 11
           ERR LED = 0
           RDY LED = 0
           PGM LED = 0
           VFY LED = 0
bitbang_cmd(): [ AC 53 00 00 ] [ 00 00 00 00 ]
Reading |                                                    | 0% 0.00sbitbang_cmd(): [ 30 00 00 00 ] [ 00 00 00 00 ]
bitbang_cmd(): [ 30 00 01 00 ] [ 00 00 00 00 ]
Reading | #################                                  | 33% 0.05sbitbang_cmd(): [ 30 00 02 00 ] [ 00 00 00 00 ]
Reading | ################################################## | 100% 0.06s
avrdude: Device signature = 0x000000
bitbang_cmd(): [ 50 00 00 00 ] [ 00 00 00 00 ]
avrdude: safemode: lfuse reads as 0
bitbang_cmd(): [ 58 08 00 00 ] [ 00 00 00 00 ]
avrdude: safemode: hfuse reads as 0
bitbang_cmd(): [ A0 01 FC 00 ] [ 00 00 00 00 ]
bitbang_cmd(): [ A0 01 FD 00 ] [ 00 00 00 00 ]
bitbang_cmd(): [ A0 01 FE 00 ] [ 00 00 00 00 ]
bitbang_cmd(): [ A0 01 FF 00 ] [ 00 00 00 00 ]
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
