Pages: [1]   Go Down
Author Topic: ir sensor for raindrops  (Read 733 times)
East Coast
Offline Offline
Newbie
View Profile
Hi everybody,
I've been posting around a lot for a rainfall measuring project. Right now I'm trying to use IR detector / emitters to detect a drop.
This is the setup I'm using:
http://imgur.com/mhLtm
and I've got these detectors / emitters, courtesy of sparkfun:
http://www.sparkfun.com/products/241
right now, I can't seem to catch a drop. If I drop something big through the PVC pipe, the values change (I'm just reading through the analog port).
I'm not sure if the problem is time-related (I've changed around the internal clock so that my analogRead is fast, at least 10kHz but maybe up to 50kHz), or if these sensors are just picking up infrared from all directions, and it won't work until I add baffles or something to redirect their signals.
Ideas? Drops should be falling around 4-5m/s, and they are 3-5 mm in diameter (but not actually spherical when airborne, more hamburger-shaped). So the time window is probably between 0.1 to 1 ms. Seems like it should work. But I've got a goofy setup.
ideas?
Thanks
Logged
the land of sun+snow
Offline Offline
Faraday Member
View Profile
WWW
Raindrops are small and transparent. Somehow I doubt they will make much difference
to an IR light beam. In addition, from what I can tell, the IR sensor you have is just a
phototransistor without any gain, which means it's extremely insensitive to start with.
There seem to be a few ideas here:
http://search.yahoo.com/search;_ylt=A0oG7nphKfpNLmUAKzml87UF?p=raindrop+detector&fr=sfp&fr2=&iscqry=
Logged
Offline Offline
Newbie
View Profile
My car does a good job of sensing raindrops -
http://auto.howstuffworks.com/wiper4.htm
Logged
Offline Offline
Full Member
View Profile
WWW
here is some more great info on it:
http://static.ddmcdn.com/pdf/rain-sensor.pdf
Logged
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
Pages: [1]   Go Up
Jump to:
