Topic: Picking the right photodiode (Read 762 times) previous topic - next topic
Dr_Freeman
I need to transfer data from my Windows Phone 7 to mC. The problem is that WP7 doesn't have any type of usb client control. So I was thinking, I could connect photodiode to mC, change in voltage will be used to represent data. I have already coded 32 characters using two voltage states, that should be enough. Light will be emited from WP7 screen, just flashing black/white when in sending mode. I would isolate external by building a stethoscope-like fraim for diode. My question is what model of photodiode should I use? Changes in screen light will be every 20 ms. Do I need some kind of amp for voltage from diode ?
Chagrin
I'd start with any IR phototransistor you can get your hands on; basically whatever is available at the local electronics store. A round/5mm instead of a rectangular one would probably be the best. If you can isolate it well and you're holding the phone closely you shouldn't have a problem.
If you can get your flash rate up to around 38khz then you could use an IR receiver and you'd have the amp built in.
Dr_Freeman
Thank you for replying. What kind of amp circuit should I build? Would something like 741 DIP OPAMP, 3-18V, 1MHz, GENERAL PURPOSE, DIP8 be useful?
