arduino code:
// 0.1 by pmalmsten http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1176098434
// 0.2 by farkinga
// 0.3 by farkinga - adds cool behaviors
#define IR_BIT_LENGTH 12 // number of bits sent by IR remote
#define BIT_1 1000 // Binary 1 threshold (Microseconds)
#define BIT_0 400 // Binary 0 threshold (Microseconds)
#define BIT_START 2000 // Start bit threshold (Microseconds)
#define IR_PIN 7 // Sensor pin 1 wired through a 220 ohm resistor
#define LED_PIN 9 // first LED output
#define POWER_PIN 11 // second LED output, corresponds to power button
#define DEBUG 0 // Serial connection must be started to debug
int runtime_debug = 0; // flag to output raw IR pulse data
int output_key = 0; // flag to print decoded key integers
int power_button = 0; // flag to indicate if power LED is on
int power_level = 128; // value (0-255) for power LED intensity
pinMode(LED_PIN, OUTPUT); //This shows when we're ready to recieve
pinMode(POWER_PIN, OUTPUT); //This is the "power on" indicator
pinMode(IR_PIN, INPUT);
digitalWrite(LED_PIN, LOW);
Serial.println("ready to decode!!");
int key = get_ir_key();
Serial.println(key);
delay(200);
pinMode(8,OUTPUT);
digitalWrite(8,LOW);
pinMode(9,OUTPUT);
digitalWrite(9,HIGH); // short delay to cancel duplicate keypresses
wait for a keypress from the IR remote, and return the
integer mapping of that key (e.g. power button on remote returns
the integer 1429)
int get_ir_key()
int pulse[IR_BIT_LENGTH];
int bits[IR_BIT_LENGTH];
do {} //Wait for a start bit
while(pulseIn(IR_PIN, LOW) < BIT_START);
read_pulse(pulse, IR_BIT_LENGTH);
pulse_to_bits(pulse, bits, IR_BIT_LENGTH);
return bits_to_int(bits, IR_BIT_LENGTH);
respond to specific remote-control keys with different behaviors
use pulseIn to receive IR pulses from the remote.
Record the length of these pulses (in ms) in an array
void read_pulse(int pulse[], int num_bits)
for (int i = 0; i < num_bits; i++)
pulse[i] = pulseIn(IR_PIN, LOW);
IR pulses encode binary "0" as a short pulse, and binary "1"
as a long pulse. Given an array containing pulse lengths,
convert this to an array containing binary values
void pulse_to_bits(int pulse[], int bits[], int num_bits)
if (DEBUG || runtime_debug) { Serial.println("-----"); }
for(int i = 0; i < num_bits ; i++)
if (DEBUG || runtime_debug) { Serial.println(pulse[i]); }
if(pulse[i] > BIT_1) //is it a 1?
bits[i] = 1;
else if(pulse[i] > BIT_0) //is it a 0?
bits[i] = 0;
else //data is invalid...
Serial.println("Error");
convert an array of binary values to a single base-10 integer
int bits_to_int(int bits[], int num_bits)
int result = 0;
int seed = 1;
//Convert bits to integer
for(int i = 0 ; i < num_bits ; i++)
if(bits[i] == 1)
result += seed;
seed *= 2;
return result;
processing code:
import processing.serial.*;
Serial serial;
void setup(){
serial = new Serial(this, "COM8", 9600);
void draw(){
if ( serial.read() > 0) {
println(serial.read());
actually,what i dont know is what conversion to perform.
