« on: March 28, 2012, 06:59:24 pm » |
Hello,
My son and I are doing a project that will require close to 50 inut / outputs, so the Mega 2560 looks like what we need.
If this works, we want to make more copies of this project. I know if a project is based on the uno, you can put just the chip on the PCB. Can we do this with the chip from a Mega, or would we be better off just buying more Megas?
If this is possible, could someone point me in the right direction on how to do this?
Thanks, Rob
Seattle, WA USA
Online
Seattle, WA USA
« Reply #1 on: March 28, 2012, 07:02:05 pm » |
You will have a much harder time removing the chip from the Mega that from the Duemilanove or UNO. Depending of your skills with a soldering iron, it might be easier to just buy more Megas.
Anchorage, AK
« Reply #2 on: March 28, 2012, 07:48:31 pm » |
Megas are surface-mount chips. Tiny, tiny pins to be soldering by hand. There are options available to have them fabricated by a production house, if you're ordering in quantity. Or, you can learn how to do SMD PCBs yourself. It's not trivial, but not impossible.
You might think about IO expansion on through-hole chips instead. Look into shift registers, for starters.
nr Bundaberg, Australia
« Reply #3 on: March 29, 2012, 01:58:07 am » |
It may depend on how many you intend to make, Megas are expensive so if this is to be a commercial product you really should build your own board, soldering those chips is not rocket science but you certainly have to hold your mouth right. I have a mate who just had a few (8 I think) boards loaded with the hard bits (including a 2560) for his invention, it wasn't real cheap but OK. See here http://arduino.cc/forum/index.php/topic,69358.0.htmlSo I think it depends on whether this is 100s for sale or 5 for the local sports club. ______ Rob
« Last Edit: March 29, 2012, 01:59:50 am by Graynomad »
Dallas
Online
Shannon Member
« Reply #4 on: March 29, 2012, 02:16:39 am » |
require close to 50 inut / outputs How close?
« Reply #5 on: March 29, 2012, 12:47:02 pm » |
Thanks for the responses. Confirms what I suspected. The project is for our own version of a guitar effects pedal controller. Originally inspired by this: http://www.geofex.com/article_folders/rmtswtch/rmtsw.htm, but after all of the changes / features we keep addining, it only has a slight resemblence to the original. Right now we are at 44 input / outputs (LCD, LEDs, Stomp buttons, relays, etc...). He is talking about some more features that could add up to 12 more IOs, so we are filling up the mega pretty fast. We have tested all of our needed programming and electrical proofs individually, and did a small scale test of all our programming concepts combined on the uno (used all the digital IOs). We now have a mega, and have ordered all of our parts, so hopefully in the next few months we will have our prototype up and running. We also made our first PCB (acid etched a copper clad board). So that is one more thing to check off our list of things we need to be able to do. There are a few friends who say they want one if it works like we think it should (plus my son has dreams of selling some - we will see about that way down the road). Thanks again for the help, Rob
Boston area, metrowest
« Reply #6 on: March 29, 2012, 02:57:18 pm » |
If you are doing any quantity, then order ten 100mm x 100mm boards (max) for $24.90 from iteadstudio.cop, much more reliable way to go. Solder masked, labeled, the works.
a, b = b, a+b
« Reply #7 on: March 29, 2012, 04:08:12 pm » |
you may also want to consider using multiplexers...
Anchorage, AK
« Reply #8 on: March 29, 2012, 05:27:12 pm » |
Yeah, dude... You could easily do this with through-hole parts if you use a couple shift registers. There's really no need to use a Mega unless you must have the UARTs or memory that you just can't get on the lower end chips.
I mean, if really want to, knock yourself out -- but absolutely consider the easier route first.
« Reply #9 on: March 30, 2012, 02:33:06 pm » |
I have been programming for years, but I am weak on the electronics side.
Could someone supply me with any good info on multiplexing?
Anchorage, AK
« Reply #10 on: March 30, 2012, 04:42:56 pm » |
Look at the ShiftIn and ShiftOut tutorials on arduino.cc. The 4021 and 595 chips are cheap and easy.
« Reply #11 on: March 30, 2012, 06:03:13 pm » |
Also look at the 4051 and 4067 to get extra analogue inputs.
______ Rob
« Reply #12 on: March 30, 2012, 06:06:50 pm » |
If you buy atmega2560 you will have to learn about bootloading and isp, I've soldered one tqfp chip before and its not so bad with the hot air method and solder paste, definetly needs a custom pcb tho,
« Reply #13 on: March 30, 2012, 06:40:09 pm » |
Could also try a '2560 on a Schmartboard, get access to all the IO pins.
« Reply #14 on: April 02, 2012, 09:35:28 am » |
Am I correct that with multiplexing, I can only have power to one output at a time?
This project will have around a dozen relays, plus LEDs as indicators where many could be on at that same time.
