Topic: Tone() Function (Read 829 times) previous topic - next topic
Jon123
Hello All
How quickly can the tone function be turned on and off as I am looking to design a SSTV/FAX encoder for arduino
Any help is appreciated
Best regards  :)
Jon
Coding Badly
Welcome to the forum!
By leaving the timer running you can turn the output on and off using a single machine instruction (1/16 ?s).  Add in the fact that you will very likely be coding in C++ instead of assembly and that an interrupt may interfere it is reasonable to state that you will be able to control the tone within a few microseconds.
