Topic: More MATLAB Trouble (Read 3618 times) previous topic - next topic
fayadAli
Mar 29, 2012, 10:12 am Last Edit: Mar 29, 2012, 10:01 pm by fayadAli Reason: 1
Hello i am new to this forums and I couldn't post a new post So I am asking my question here
I wrote this code to get the 3 string values ( I will use strtod later) reading serially from matlab but I am not sure know why its not working.
The output from the serial port is
Arduino heard you saying I am not getting any values
here is the code
Code: [Select]
void setup ()
} /////////////////////////////////////////////////////////////////////////////end of setup
////////////////////////////////////////////////////////////////////////////// here to process incoming serial data after a terminator received
char input_line [50];
char datas[10];
unsigned int input_pos = 0;
if (Serial.available() >0){
     Serial.print("Arduino heard you say: ");
 while (Serial.available () > 0)
   char inByte = Serial.read ();
   while(inByte != '\n')
     input_line[input_pos] = input_line[input_pos] + inByte;
     if (inByte ==',')
     input_pos++;
   Serial.print(input_line[1]);
Serial.print("I reached here: ");
Serial.print(input_line[0]);
Serial.print(input_line[2]);
Moderator edit: [code] [/code] tags added.
Coding Badly
#1
Mar 29, 2012, 10:16 am Last Edit: Mar 29, 2012, 10:18 am by Coding Badly Reason: 1
Anymore cross-posting and you will get a time-out.
nuttracy
Try to use some simply code at first, such as using MATLAB to control a LED through Arduino.
PaulS
Code: [Select]
This is novel. I don't think I've ever seen anyone ADD the byte read to the existing value in the array.
Code: [Select]
It's a local variable, so it is not initialized to anything meaningful, and yet you add the new data to the existing garbage in the array. Like I said, novel.
Code: [Select]
      if (inByte ==',')
      input_pos++;
Suppose you read an 'A' from the serial port. That's not a '\n', so you enter the while loop. What will allow you to exit that loop? As written, as soon as you read something other than a carriage return from the serial port, you enter an infinite loop.
The reason for having a while loop there completely escapes me. An if statement would make sense. A while statement does not.
Assuming that you change the while to if, you'll have this:
Code: [Select]
    // Do something with the character
So, as long as there is serial data available, print the character in the second position of the array.
Exactly how useful is that?
Quote
And, now you know why.
fayadAli
Sorry for cross posting.
thanks Pauls for replying. Well so do you mean that this novel won't work " input_line[input_pos] = input_line[input_pos] + inByte;"
whats wrong with it? I am adding the incoming ascii character to a string stored in an array instead of adding it to an array of characters.
I tried the other way I received the charaters and stored it to a char array. then in another method I parsed the character array to strings. It worked but the code seems too complicated to use. This one is much simpler
PaulS
Quote
Yes. I mean that there is a big difference between
Code: [Select]
and
Code: [Select]
input_line[input_pos] = inByte;
Quote
input_line is an array of characters, not an array of strings.
Quote
But it's complete nonsense.
fayadAli
#6
Mar 29, 2012, 05:45 pm Last Edit: Mar 29, 2012, 08:04 pm by Coding Badly Reason: 1
Ok I will keep then the complex way but I need help too
how to pass three obtained Strings from my parse_data  function to the loop is my main concern
then how to change those string values to double values
my code is :
Code: [Select]
void setup ()
void process_data (char * data)
 // for now just display it
 Serial.println (data);
 }  // end of process_data
/////////////////////////////////////////////////////////////////////////process data serially
void parse_data(char * data)
 int s = 1;
     int j = 0;
     char value[15];
     for(int k =0 ; k<15;k++){value[k]=0;}
     String servo;
     String pwm;
     String pressure;
     for(int i = 0; i <100;i++)
       if(data[i] == ',')
          switch(s){
            case 1:
              servo = value;
              s = 2;
            case 2:
             pwm = value;
             s = 3;
            case 3:
             pressure = value;
             s= 4;
         j = 0;
       else{
         value[j] = data[i];
         j++;
    Serial.print(servo);
    Serial.print(pwm);
    Serial.print(pressure);
 int i= 0;
static char input_line [50];
char datas[10];
static unsigned int input_pos = 0;
 if (Serial.available () > 0)
   switch (inByte)
     case '\n':   // end of text
       input_line [input_pos] = 0;  // terminating null byte
       // terminator reached! process input_line here ...
       process_data (input_line);
       parse_data(input_line);
       // reset buffer for next time
       input_pos = 0;
     case '\r':   // discard carriage return
     default:
       // keep adding if not full ... allow for terminating null byte
       if (input_pos < (50))
         input_line [input_pos++] = inByte;
     }  // end of switch
 }  // end of incoming data
 ////////////////////////////////////////////////////////////////////////////////////////////string received and saved to input_line
  ////////////////////////////////////////////////////////////////////////////////////////Parsing the string'
Here is the output I got through the serial port
7.9669,60,40.6355,   (this is the array of characters obtained from the serial port)
7.9669   (these are each string parsed and saved to a variable) I need to pass these to the  loop
60
40.6355
fayadAli
I appreciate all the help from you guys especially Pauls
PaulS
Several comments. First, you are collecting the data into a char array. Then, you are wrapping that char array in a String. Why?
There is no reason for hiding the character data in a String object, especially as the atof() function has no idea how to deal with a String.
Second, it is clear that you do not understand the relationship between a char array and a string (with a lower case s). Functions like atof() and the String constructor expect strings. A string is a NULL terminated array of chars. value is an array of chars, but it is not a string, because it is not NULL terminated.
Until you NULL terminate the array of chars, you can not pass the char array to functions like atof() or the String constructor and expect correct things to happen.
If you did understand this relationship, you would know that functions that expect strings stop reading the character data at the NULL, so
Code: [Select]
is unnecessary. Simply set value[0] to NULL ('\0').
Your parse_data() function declaration should look something like this:
Code: [Select]
void parse_data(char *data, float &servo, float &pwm, float &pressure)
fayadAli
#9
Mar 29, 2012, 07:01 pm Last Edit: Mar 29, 2012, 08:05 pm by Coding Badly Reason: 1
Paul   for(int k =0 ; k<15;k++){value[k]=0;} this is to reset all the char in the array so when the next value is read old values doesn't exist. I tried setting the first value of the char array to 0 it didn't work i got the second number continued by the first number.
I was thinking of using strtod() to convert strings to double and then use it.
The code seems to complex to me so I switched to the one I started with i am working on both now.
I have a great improvement on the first one and my novel worked!
Code: [Select]
String input_line [50];
int input_pos = -1;
int x = 0;
 while ((Serial.available () > 0)&& ( x!= 1))
   switch (inByte)
      x= 1;
     case ',':
     input_pos++;
     default:
     }  // end of switch
if(x ==1)
though I am getting the last 2 values only the first one is not there  here is the output
Arduino heard you say: Arduino heard you say: Arduino heard you say: Arduino heard you say:
60
40.6355
PaulS
Quote
Because you are not adding data to the array correctly.
This is an example of how it should be done:
Code: [Select]
char inData[15];
byte index = 0;
inData[index] = '\0';
while(Serial.available() > 0)
   char aChar = Serial.read();
   if(aChar == ",")
      // Use the index characters in inData
      // Get ready for next value
      index = 0;
      inData[index++] = aChar; // Add the char to the array
      inData[index}; // Add a NULL after that character
Code: [Select]
Wow. Talk about a sledge-hammer solution...
fayadAli
#11
Mar 29, 2012, 09:15 pm Last Edit: Mar 29, 2012, 10:02 pm by fayadAli Reason: 1
 I changed the code to this and still i am not getting the values.
Code: [Select]
void setup ()
////////////////////////////////////////////////////////////////////////////// here to process incoming serial data after a terminator received [/c]
char inData[15];
int index,i = 0;
char servo[15], pwm[15], pressure[15];
servo[0], pwm[0], pressure[0] = '\0';
inData[i] = '\0';
int x = 0;
while((Serial.available() > 0) && (x !=1))
  if(aChar == ',')
      switch (index){
       case 0:
       for (int k =0; k <15; k++){servo[k] = inData[k];}
       index =1;
       inData[0] = '\0';
       i =0;
       case 1:
       for (int k =0; k <15; k++){pwm[k] = inData[k];}
       index = 2;
       inData[0] = '\0';
       i =0;
       case 2:
       inData[0] ='0';
       index =3;
       i = 0;
       if (aChar == '\n')
        x = 1;
  inData[i++] = aChar; // Add the char to the array
if(index ==3)
Serial.print("I passed here: ");
String xl= servo;
Serial.print(xl);
Serial.print(pwm);
index++;
PaulS
Code: [Select]
Tell me what you think this is doing?
Code: [Select]
int index
The variable index is a local variable, with no initial value. So, it contains some random garbage.
Code: [Select]
       switch (index){
So, you want to switch based on random garbage?
Code: [Select]
   if(aChar == ',')
<snip>
        if (aChar == '\n')
         x = 1;
So, under what circumstances is the value in aChar going to morph from a command to a carriage return?
fayadAli
Code: [Select]
I think it is setting the character array to null so no garbage is in it.
fayadAli
int index = 0;
its initial value is 0 not garbage I am switching from 0 to 1 thats what is written in there.
