Topic: More MATLAB Trouble (Read 2849 times) previous topic - next topic
fayadAli
Thank you Paul really thanks for all the guidance you provided
thanks to this forum its really helpful.
I got it with my new algorithm I will post my code for any one who get stuck
I am sending with 3 different delimiter values
the sent data as a string is: "servo,pwm;pressure:\n"
Code: [Select]
char servo[15], pwm[15], pressure[15];
char inData[15];
int i =0;
float servoFloat = 0;
float pwmFloat = 0;
float pressureFloat =0;
void setup ()
  inData[0] = '/0';
  servo[0] = '\0';
  pwm[0] = '\0';
  pressure[0] = '\0';
//****************************************************************************************************************end of setup
  int x = 0;
  while((Serial.available() > 0) && (x== 0))
    char aChar = Serial.read();
    switch (aChar){
    case ',':
        servoFloat =atof(inData);
      inData[0] = '\0';
      i =0;
    case ';':
      pwmFloat = atof(inData);
      inData[0] = '\0';
      i =0;
    case ':':
      pressureFloat = atof(inData);
      inData[0] ='\0';
      i = 0;
    case'\n':
      x=1;
    default:
      inData[i++] = aChar; // Add the char to the array
  if(x == 1)
    Serial.print("I passed here: ");
    Serial.print(servoFloat);
    Serial.print(pwmFloat);
    Serial.print(pressureFloat);
[\code]
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
