Topic: More MATLAB Trouble (Read 2959 times) previous topic - next topic
PaulS
nt index = 0;
its initial value is 0 not garbage I am switching from 0 to 1 thats what is written in there.
Where? Here?
int index,i = 0;
That is creating two variables, index and i, and assigning i an initial value of 0. index does NOT get assigned an initial value.
I think it is setting the character array to null so no garbage is in it.
No. It is assigning only pressure[0] a value.
Comma does NOT mean "do this to all these variables...".
fayadAli
Still doesn't working Pauls. I ve done all the things I am really desparate
the output is : I passed here
void setup ()
} /////////////////////////////////////////////////////////////////////////////end of setup
////////////////////////////////////////////////////////////////////////////// here to process incoming serial data after a terminator received
char inData[15];
inData[0] ='\0';
int index = 0;
int i =0;
char servo[15], pwm[15], pressure[15];
servo[0] = '\0';
pwm[0] = '\0';
pressure[0] = '\0';
int x = 0;
while((Serial.available() > 0) && (x== 0))
   char aChar = Serial.read();
   if (aChar == '\n'){x = 1;}
   if(aChar == ',')
       switch (index){
        case 0: for (int k =0; k <15; k++){servo[k] = inData[k];}
                index =1;
                inData[0] = '\0';
                i =0;
        case 1: for (int k =0; k <15; k++){pwm[k] = inData[k];}
                index = 2;
                inData[0] = '\0';
                i =0;
        case 2: for (int k =0; k <15; k++){servo[k] = inData[k];}
                inData[0] ='\0';
                index =3;
                i = 0;
        default:  inData[0] = '\0';
                  i = 0;
   inData[i++] = aChar; // Add the char to the array
if(x == 1)
Serial.print("I passed here: ");
Serial.println();
Serial.print(servo);
Serial.println();
Serial.print(pwm);
Serial.println();
Serial.print(pressure);
Serial.println();
[\code]
PaulS
Serial.print("Hey, lookee here. I got a [");
Serial.print(aChar);
Serial.println("]");
should give you whole lot more output, and a clue.
Before posting any more code, PLEASE!!! use Tools + Auto Format. I'm tired of guess which } goes with which {.
fayadAli
Here is the code with better Format. it is receiving the characters as needed when I tried print serial
void setup ()
  char inData[15];
  inData[0] ='\0';
  int index = 0;
  int i =0;
  servo[0] = '\0';
  pwm[0] = '\0';
  pressure[0] = '\0';
  int x = 0;
    if (aChar == '\n'){
      x = 1;
    if(aChar == ',')
      switch (index){
      case 0:
        index =1;
        inData[0] = '\0';
        i =0;
      case 1:
          pwm[k] = inData[k];
        index = 2;
        inData[0] = '\0';
        i =0;
      case 2:
        inData[0] ='\0';
        index =3;
        i = 0;
      default:
        inData[0] = '\0';
        i = 0;
    if(x == 1)
      Serial.println();
      Serial.println();
      Serial.print(pwm);
      Serial.println();
      Serial.println();
[\code]
the output is
7.9669,60,40.6355
I passed here:
I passed here:
PaulS
And? What are you seeing?
fayadAli
I can receive the characters but its not separating them in servo, pwm and pressure I knew it received them
I am seeing
[Here look at this: characters]
I passed here
"the values should be separated here but nothing
"second value"
"third value"
I passed here
fayadAli
Here is the output after I try it
Hey, lookee here. I got a [7]
Hey, lookee here. I got a [.]
Hey, lookee here. I got a [9]
Hey, lookee here. I got a [6]
Hey, lookee here. I got a [,]
  • Hey, lookee here. I got a [,]
    Hey, lookee here. I got a [4]
  • Hey, lookee here. I got a [.]
    Hey, lookee here. I got a [3]
    Hey, lookee here. I got a [5]
    I passed here:
    I passed here:
fayadAli
I tried printing right after each variable I got this
I am here9I am here96I am here966I am here9669I am here9669«I am here9669«I am here9669««I am here9669««I am here9669««I am here9669««I am here9669««I am here9669««I am here9669««I am here9669««I am here9669««This is PWMThis is PWMThis is PWMThis is
The servo starts to save the values after the second charachter received. PWM and pressure never get assigned any values
PaulS
OK. So, we have learned a great deal from this. We know that data is properly being sent to the Arduino, and we know that the Arduino is properly reading the data. We can see that the input stream does contain commas and a carriage return and a line feed.
I am seeing
I passed here
"second value"
"third value"
I passed here
So, you made a code change to learn this. I can't see what the code looks like, now.
More changes. No code posted.
Please post the code you have now. You are very close to getting this to work.
fayadAli
#24
Mar 31, 2012, 12:28 am Last Edit: Mar 31, 2012, 12:30 am by fayadAli Reason: 1
void setup ()
 servo[0] = '\0';
 pwm[0] = '\0';
 pressure[0] = '\0';
 char inData[15];
 inData[0] = '/0';
 int index = 0;
 int i =0;
 int x = 0;
   if (aChar == '\n'){
     x = 1;
   if(aChar == ',')
     switch (index){
     case 0:
       for (int k =0; k <15; k++){ ///copy indata to servo
         Serial.print("I am here");
       index =1;
       inData[0] = '\0';
       i =0;
     case 1:
         pwm[k] = inData[k];
          Serial.print("This is PWM");
         Serial.print(pwm);
       index = 2;
       inData[0] = '\0';
       i =0;
     case 2:
           Serial.print(" Pressure");
         Serial.print(pwm);
       inData[0] ='\0';
       index =3;
       i = 0;
     default:
       inData[0] = '\0';
       i = 0;
   if(x == 1)
     Serial.println();
     Serial.println();
     Serial.print(pwm);
     Serial.println();
     Serial.println();
[\code]
fayadAli
I gave up on that and I am using
This one it works fine and I am able to receive and separate the values. all I need to now is how to pass the float values to the void loop
I am trying to put them in a float array and return that but I couldn't
[code]
float servoInt = 0;
 float pwmInt = 0;
 float pressureInt =0;
void setup ()
void process_data (char * data)
 Serial.println();
 Serial.println (data);
void parse_data(char * data)
 int s = 1;
 int j = 0;
 char value[15];
 for(int k =0 ; k<15;k++){
   value[k]=0;
 String servo;
 String pwm;
 String pressure;
 for(int i = 0; i <100;i++)
   if(data[i] == ',')
     switch(s){
     case 1:
       servo = value;
       servoInt = atof(value);
         Serial.print("servoInt is:");
         Serial.print(servoInt);
         value[k]=0;
       s = 2;
       break;
     case 2:
     pwmInt = atof(value);
     Serial.print(" the actuator angle received in float is ");
     Serial.print(pwmInt);
       pwm = value;
         value[k]=0;
       s = 3;
       break;
     case 3:
       pressureInt = atof(value);
       pressure = value;
         value[k]=0;
       s= 4;
       break;
     j = 0;
   else{
     value[j] = data[i];
     j++;
 Serial.println("I got the final values");
 Serial.println();
 Serial.print("Servo Angle:");
 Serial.println();
 Serial.print(" the actuator angle received in float is: ");
 Serial.println();
 Serial.print("the presssure received:");
 Serial.print(pressureInt);
 int i= 0;
 static char input_line [50];
 char datas[10];
 static unsigned int input_pos = 0;
 if (Serial.available () > 0)
   char inByte = Serial.read ();
   switch (inByte)
   case '\n':
     input_line [input_pos] = 0;
     process_data (input_line);
     parse_data(input_line);
     input_pos = 0;
     break;
   case '\r':
     break;
   default:
     if (input_pos < (50))
       input_line [input_pos++] = inByte;
     break;
   }  // end of switch
[\code]
[/code]
PaulS
What? Perhaps you need to try
int pwmFloat = some nonsense.
fayadAli
#27
Mar 31, 2012, 01:15 am Last Edit: Mar 31, 2012, 08:48 am by fayadAli Reason: 1
Do you think this is better.
I am thinking of changing the whole thing to this algorithm
send firstValue , SecondValue;ThirdValue: /n
read serial
switch inByte
case ,
firstValue = atof(arraychar);
reset (arraychar);
case ';' :
secondValue = atof(arraychar);
reset value;
case ':' :
thirdValue = atof(arrayChar);
default:
inData[pos++] += inByte;
fayadAli
Well I was using Int earlier thats why the name is pwmInt
PaulS
It's not an int now. You can, and should, change the name.
