Topic: get the status of plx daq control (Read 4337 times) previous topic - next topic
frank_y
I've got an arduino uno and i am trying to read the status of one of the four checkboxes on the PLX-DAQ interface. The PLX Help says :
DEBUG "USER1,GET",CR                         ' Request checkbox value
DEBUGIN DEC check1                            ' Accept value into variable
so I thought it should look like Serial.println("GET,USER1");
and maybe  value = Serial.read(); to see if user1 is checked or not. But it's not working, any ideas ?
code:
void setup (){
void loop (){
if (value == '1')
       {Load = (analogRead(0)*0.45359;}
     {  Load = analogRead(0); }
    Serial.println(Load*0.005);     //
PaulS
The PLX Help says :
OK.
The Serial.println() function makes sense, as it sends the data and appends the carriage return. Switching the order of the tokens does not. Why did you?
Why do you expect a response in the few nanoseconds between sending the (apparently invalid) request and reading the response?
Why do you try to read a response without checking that one has arrived (or waiting for one to arrive)?
frank_y
I switched the GET and USER1 because the Arduino should probably begin with the control directive I want the macros in PLX-DAQ to run (DATA, LABEL, CLEARDATA, RESETTIMER, SET, GET, etc.). Changed it also back, made no difference. There seems to be no serial available.
Also I checked the response for several seconds.
And I tried to check the arrival of the response with serial.available(). Nothing.
So I guess the statement Serial.println("USER1,GET");/Serial.println("GET,USER1");  isn't working or something with the serial connection at all.
But how to get the status then ?
PaulS
You need to provide a lot more details. What is running on the PC? Is there something running that is connected to the serial port? Are you able to use other commands to talk to that something?
dxw00d
There is no Serial.begin() in your sketch.
frank_y
I downloaded the PLX-DAQ SW for Excel. I can make graphs, so sending data from an analog input to Excel is fine. I can send this data via the serial port to Excel but not get anything back. Basically, I'd like to read if one of the boxes is checked so I can evaluate this in my program to switch between weight units. But the whole if statement can not be done.
    int sample = 100;
    int row=0; //int USER1=0;
    float Load = 0;
    int metric = 0; //  0/1 eng/met units
// choose "PLX-DAQ Simple Test";
    // initialize the serial communication:
    Serial.begin(9600);           // baud rate/speed
    Serial.println("CLEARDATA");   // clear data in excel on reset
    Serial.println("LABEL,Time,,,LOAD/Newton"); // columnnames, Time, not TIME -> is instruction
    Serial.println("MSG,Set Metric for Newton - otherwise in Pound");
    Serial.println("USER1,LABEL,Metric");  // user1 new label
   //Serial.println("USER1,GET");    in all variants didn't work
   //USER1=Serial.read(); //
    // allows serial port to send data to Excel, first field always TIME, then fields of interest (val)
    Serial.print("DATA,TIME,,,");
    if (Serial.available() > 0){
    metric=Serial.read();
    if (metric == '1')
    {Serial.println("y");}
    if (metric == '0')
    {Serial.println("n");}
    else {Serial.println("no serial");}
    Serial.println(Load*0.005);     // read the analog input on pin 0, field of interest, and
    row++;  // next line
    // wait a bit for the analog-to-digital converter
    // to stabilize after the last reading:
    delay(sample);  // in milliseconds
PaulS
    if (metric == '1')
    if (metric == '0')
I want to know the value of the USER1 field, and I demand to know it NOW!!!!
I'm pretty sure that it takes more than a few nanoseconds for the request to get to the PC, get evaluated by the Excel plugin, and to get the answer back to the Arduino.
I'm also certain that you don't want to send the request on every pass through loop.
Finally, I'm pretty sure that Excel can do the conversion faster than the Arduino can. Just send data in one system of units, and let Excel, through the use of formulas, display the data however the viewer wants to see it.
frank_y
USER1 is one of the boxes in the control, 0 for unchecked, 1 for checked (or what do u mean?). If I try the if-statement in the setup() there is also no status coming back.
PaulS
Because you didn't wait for a reply. You expected the reply to be available a few nanoseconds later when the read method was called.
Try this:
    unsigned long sentTime = millis();
    while(millis() - sentTime < 60000UL) // Wait up to 60 seconds for a reply
       if(Serial.available() > 0)
          USER1 = Serial.read();
          digitalWrite(13, HIGH);
          break;
If, at the end of setup(), the LED is on, then you got some kind of response. Without an LCD or some means to show what that response was, I don't know how you can debug the issue.
frank_y
Ok, tried the prior example, led is working fine so serial communication and if-statement seems not to be the matter. Back to the status request which is not working. Anyone an idea how to talk to the directive and write DEBUG "USER1,GET",CR  in Arduino language ?
fazal_khan
hi..
you guys are discussing about getting the state of one of the checkbox at PLX Daq interface..
my question is can we get cell data from Excel if yes please post some example here..
thanks
miflama
#11
Dec 30, 2015, 06:56 pm Last Edit: Dec 30, 2015, 07:03 pm by miflama Reason: failure message
Hello,
I've made a program to check the value that returns
and the results are 48 (ascii 0) or 49 (ascii 1)and 13 (CR) changing each time the loop is executed
it takes a few loops to change
void setup(void)
void loop(void)
      int valor=Serial.read();
      Serial.println("LABEL,valor");
      Serial.print("DATA,");
      Serial.println(valor);
      Serial.flush();
      delay(250);
so I think your program does not work there
PaulS
Because you send the request on every pass through loop(). Stop doing that!
      Serial.flush();
      delay(250);
Block until all pending serial data has been sent, then stuff your head in the sand for another 1/4 second. Why?
