Topic: Glitching TLC5940 (Read 9227 times) previous topic - next topic
Grumpy_Mike
Quote
No one ever told me you can't just use meter long wires for everything.
Did you ask?
Quote
From where to where exactly did you place those?
From the end of the run to ground. But the whole situation was monitored on a scope as I did it to make sure the wave form edges were not too affected.
Quote
I guess there isn't a simple/relatively cheap alternative for it? (
No not for chasing this.
Inevitableavoidance
I can get my hands on a 15Mhz scope, will that be sufficient? Or will I need something faster?
Grumpy_Mike
That might just about do.
Inevitableavoidance
I'll buy it then. :)
How am I supposed to measure with it when it's here?
Or can anyone point me a good tutorial?
Grumpy_Mike
Just google:- using an oscilloscope
There are lots.
The trick is not so much making the measurements but understanding what the display is showing you. But you can't begin to start that until you have got one.
Good luck.
nickgammon
The trick with oscilloscopes is to have a pretty good idea of what "normal" is, then you can spot "abnormal".
Also put aside a few hours to getting the hang of it. Otherwise you might just be measuring line hum and thinking that it is part of your project.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Inevitableavoidance
#51
Apr 05, 2012, 12:34 pm Last Edit: Apr 05, 2012, 12:40 pm by Inevitableavoidance Reason: 1
I re-soldered all the LED's in blocks instead of rows, and hooked up the newly wired breadboards, and everything was fine! No glitching or bugs of whatever..
But then I was trying to hook up the spectrum-shield I have, to make a graphic equalizer, and I accidentally shorted my power supply. Then I replaced all the molten wires, and all the TLC's (just to be sure, they were pretty warm) and hooked everything back up to how it was, and the glitching is back!
I however found that when i tightly grip my 7805, the glitching will be gone. My oscilloscope will arrive somewhere today..
Edit:
Also, before shorting the power supply, I hooked up an arduino to the TLC's without connecting the ground, that's probably what caused the TLC's to become very hot, and that's why I replaced them.
Edit:
The glitching seems to be gone for the moment now.. I moved the board from the ground to against the wall.
Grumpy_Mike
Quote
That implies the regulator has not got enough high frequency suppression. Put a 0.01uF across the input and output terminals as close to the regulator as you can get.
Inevitableavoidance
Quote
There are already .1uF caps there, should I replace those or add the .01uF?
cmiyc
Quote
Add.
High frequency noise is filtered out by lower value caps.  Having multiple caps in parallel improves the frequency response of the de-coupling.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Inevitableavoidance
It's completely working..! (I think)
Thanks a lot everyone! :)
Conclusion:
Wire everything as compact as possible, add a lot of the right capacitors, and try not to put your breadboards directly above a 100m of (changing) powered wire. :)
I made a simple snake game for the panel:
http://www.youtube.com/watch?v=HyxBAngBoI0
Grumpy_Mike
Well done. I must admit I would not have even attempted to do such a thing.
You must be well chuffed as we say in England.  :)
Inevitableavoidance
We're building a 16x8 LED panel now, as a reading light above a bed. But we'll be using 8 TLC's to control each LED individually instead of per 4. (as an extra test before we start the big one)
The big one will eventually use 20 TLC's and 1280 LED's, so i'm afraid we'll probably encounter more decoupling problems.
I'll keep posting about the process here. :)
Inevitableavoidance
I'm completely puzzled, I soldered everything together instead of using breadboards.
But it isn't working.
I'm 99% sure that everything is soldered correctly, but after 2 secs of powering the board the last two TLC's go out.
If I repower it imidiately, they stay out, but if I wait like half'n hour, and power the board again, the TLC's will again function for about 2 seconds.
Does anyone know what could possibly cause this?
Grumpy_Mike
I suspect it is that 1% of uncertamcy that is killing you.
Let's face it if it worked on bread board it should work on strip board.
