Topic: Glitching TLC5940 (Read 9492 times) previous topic - next topic
nickgammon
but if I wait like half'n hour, and power the board again, the TLC's will again function for about 2 seconds.
Sounds like they are getting hot. I would measure the current in and see if it is what you expect.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Inevitableavoidance
I gave up on the old board and started to build a new one:
How would be best to wire the power/signal lines?
From one point to all 4 the TLC's? (and the arduino, if talking about power lines)
From the power source/signal source in series over al the TLC's?
Or a combination where i'd split the line and run it over 2 TLC's?
Inevitableavoidance
I found the problem!!
I was using a 7805 with heatsink, but with a metal screw, so the entire heatsing was connected to the ground of the 7805.
That explained why it would stop working when heating up! Fixed it now. :)
Inevitableavoidance
Okay nevermind, it's acting the same again, after 3 min.
