Topic: Virtual wire problem (Read 14209 times) previous topic - next topic
ddproject
hi...
My  VirtualWire examples gives de error again and again
In file included from transmitter.cpp:11:
C:\Users\Administrator\Desktop\my project\arduino-1.0-windows\arduino-1.0\libraries\VirtualWire/VirtualWire.h:15:20: error: wiring.h: No such file or directory
VirtualWire.h:60: error: variable or field 'vw_set_tx_pin' declared void
VirtualWire.h:60: error: 'uint8_t' was not declared in this scope
VirtualWire.h:64: error: variable or field 'vw_set_rx_pin' declared void
VirtualWire.h:64: error: 'uint8_t' was not declared in this scope
VirtualWire.h:68: error: variable or field 'vw_set_ptt_pin' declared void
VirtualWire.h:68: error: 'uint8_t' was not declared in this scope
CVirtualWire.h:72: error: variable or field 'vw_set_ptt_inverted' declared void
VirtualWire.h:72: error: 'uint8_t' was not declared in this scope
VirtualWire.h:77: error: variable or field 'vw_setup' declared void
VirtualWire.h:77: error: 'uint16_t' was not declared in this scope
VirtualWire.h:91: error: 'uint8_t' does not name a type
VirtualWire.h:99: error: 'uint8_t' does not name a type
VirtualWire.h:105: error: 'uint8_t' does not name a type
VirtualWire.h:108: error: 'uint8_t' does not name a type
VirtualWire.h:113: error: 'uint8_t' does not name a type
transmitter.cpp: In function 'void setup()':
transmitter:26: error: 'vw_set_tx_pin' was not declared in this scope
transmitter:27: error: 'vw_set_rx_pin' was not declared in this scope
transmitter:28: error: 'vw_set_ptt_pin' was not declared in this scope
transmitter:29: error: 'vw_set_ptt_inverted' was not declared in this scope
transmitter:30: error: 'vw_setup' was not declared in this scope
transmitter.cpp: In function 'void loop()':
transmitter:41: error: 'vw_send' was not declared in this scope
can anyone help??
skyjumper
Did you include the library header? Did you select the correct board?
Post a code example that causes the errors...
nickgammon
Near the start of the VirtualWire.h file you should see this:
#include <stdlib.h>
#if ARDUINO >= 100
  #include <Arduino.h>
#else
  #include <wiring.h>
#endif
If you only see:
#include <stdlib.h>
#include <wiring.h>
Then replace that by the lines above.
ddproject
thanks a lot..  wen i replaced with those lines it worked fine..
can u help me how to transmit bit by bit data that is available in my serial port to the transmitter??
i actually connected my webcam to arduino and got the digital output serially now gotta transmit through RF
ddproject
hii..
i used the following code to get digital output from my webcamera..now i need to transmit the data serially to an RF transmitter..
how to do it??
int ledPin=9;
int digPin=3;
int digiPin=10;
  pinMode(ledPin,OUTPUT);
  pinMode(digPin,INPUT);
  pinMode(digiPin,OUTPUT);
  int value;
  value= digitalRead(digPin);
  Serial.println(value);
  if(value==0)
  digitalWrite(ledPin,LOW);
  digitalWrite(ledPin,HIGH);
Grumpy_Mike
Do you!!
How does that work then?
ddproject
i am getting serial data output from my digital webam.. my prob is how to transmit it to an RF transmitter?
nickgammon
Topics merged. They seem to me to be on the same subject.
ddproject
may i know how to transmit digital data from one arduino to another via RF??
should i store the digital values in a buffer and transmit?
if so how to do it??
nickgammon
I don't understand that, sorry. Perhaps if you described your hardware...
winner10920
It would help to know what kind of rf module you are using, maybe with a datasheet link,
and what are you going to do with that data? It maybe a bit hard to do much with just two arduinos
ddproject
i am using RF433Mhz transmitter and receiver..
i dunno how to transmit integer values that appear in my serial port via RF..
there are many examples on how to transmit msgs only..
i think we have to store the integer values in an buffer and send it..
do we have to use a serial buffer?? if so how??
how to set the buffer size??
Nishant_Sood
one byte after byte transfer happens to whatever you write on Serial there is no special system about it.
for example when you type "Nishant" (N-i-s-h-a-n-t and not Nishant in one go)it goes through Serial RX/TX pins of your arduino to which the transmitter may be connected and if its there then information flows one by one.
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
hilukasz
so I was running into same problem and tried replacing said lines, however I get a new error:
error: WProgram.h: No such file or directory
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
aramonru
I followed these instructions:::::
#include <stdlib.h>
#if ARDUINO >= 100
#else
  #include <wiring.h>
#endif
If you only see:
#include <stdlib.h>
#include <wiring.h>
and replaced the library but it is still not working.
I found another 2 different VirtualWire libraries in the discussion thread on this tutorial
http://www.instructables.com/id/RF-315433-MHz-Transmitter-receiver-Module-and-Ardu/?ALLSTEPS
One of them contains already the additional instructions on the h file but I am still getting the same library error.
I already tried different codes that include this library so this must not be it. I have also previously added libraries to mi IDE folder so I know Im doing it right,
What else can it possibly be?
