Topic: How to send numbers from one Arduino to another using Serial (Read 12401 times) previous topic - next topic
matinzk
When I do it this way:
const char startOfNumberDelimiter = '<';
const char endOfNumberDelimiter   = '>';
long _rpm = 0;
void setup ()
  Serial.begin (115200);
  Serial2.begin (115200);
  Serial3.begin (115200);
   pinMode(8, INPUT);
  } // end of setup
void processNumber (const long n)
      Serial.println(n);
  }  // end of processNumber
void processInput ()
  static long receivedNumber = 0;
  static boolean negative = false;
  byte c = Serial2.read ();
  switch (c)
    case endOfNumberDelimiter:
      if (negative)
        processNumber (- receivedNumber);
        processNumber (receivedNumber);
    // fall through to start a new number
    case startOfNumberDelimiter:
      receivedNumber = 0;
      negative = false;
      break;
    case '0' ... '9':
      receivedNumber *= 10;
      receivedNumber += c - '0';
      break;
    case '-':
      negative = true;
      break;
    } // end of switch
  }  // end of processInput
void loop ()
        if (Serial2.available ())
          processInput ();
the output I get from the second Arduino on the Serial Monitor is correct. So when I send <8000> from the 1st Arduino I get 8000 on the Serial Monitor of the 2nd Arduino.
When I do send <8000> this way from the 1st Arduino however,
long _rpm = 0;
void setup ()
   pinMode(8, INPUT);
  } // end of setup
     _rpm = n;
  switch (c)
      if (negative)
      receivedNumber = 0;
      negative = false;
      break;
    case '0' ... '9':
      break;
    case '-':
      negative = true;
      break;
    } // end of switch
void loop ()
          processInput ();
       Serial.println(_rpm);
then I don't get the correct values, sometimes I get 800, sometimes 80 sometimes 8 etc.
Hope this is more clear.
nickgammon
void loop ()
          processInput ();
As PaulS said, you are printing _rpm before it arrives. That's why I made a function processNumber. You are supposed to print it from there, when it has totally arrived. Why are you changing a method that works, to one that doesn't?
PaulS
That's what I thought initially. But, in processNumber, he's copying the value to _rpm, rather than printing it. Since processNumber doesn't get called until the > arrives, copying the value in processNumber should be OK.
matinzk
Exactly, I print it after it has arrived and setting _rpm within processNumber.
nickgammon
You are printing _rpm every time through loop. The time taken to do that (which uses interrupts) is likely to make you miss incoming data.
BTW I wouldn't be using leading underscores in variables names if I were you.
nickgammon
Maybe:
long _rpm = -1;
    if (_rpm != -1)
      _rpm = -1;
matinzk
This works beautifully thanks.
However if I have a set of extra data to also send via another serial port (Serial 3) to a device using a Bluetooth module, then I get missing data again.
So I receive the _rpm from first Arduino to my second Arduino Mega, then I send _rpm with 3 more data to Serial3 and receive these on my phone, the _rpm data is sometimes missing as before
nickgammon
Why are you doing it that way? Why not do the serial print in the processNumber function, which is the way that works anyway?
Post this new code please.
matinzk
