Topic: Arduino installation INCOMPLETE (Read 516 times) previous topic - next topic
donitel
I run my Arduino Uno on Windows 8, thanks to the forum help I was able to install the driver and bypass the digital file info not accepted thing that kept blocking the driver installation.
Now I have the Arduino Uno showing on my device manager, but it doesn't work.
When I run the compiler nothing shows up in the Serial Port Menu. I'm tired of trying and trying again, it's been two day with my new arduino and I still can't get started!
Any help would be appreciated, many people are having trouble with similar issues.
Sincerely,
donitel!
madworm
#1
Apr 07, 2012, 07:44 am Last Edit: Apr 07, 2012, 07:46 am by madworm Reason: 1
If nothing shows up in the serial port menu while the Arduino is connected to your computer can have several reasons:
* driver not installed / working
* the usb cable is broken
* the usb port on you computer is broken
* the arduino itself is at least partially broken
Try a different cable / usb port / computer / OS. The Arduino IDE works very well with XP, so if you have that running it in a virtual machine may help.
