Topic: Interfacing with a Navman B10 GPS (aka GPSlim236) (Read 6804 times) previous topic - next topic
nickgammon
What is the objection to connecting the GPS to the hardware serial port?
thoms
No objection at all!
For now I am tinkering with the GPS to see how I can use it. As I do not have any LCD or display available, the only way to see if it works with my Arduino Uno is to output data to the PC via the serial Port.
Now I know for sure that if I need to connect a GPS via a serial port I'll use hardware serial port :D
trunet
any of you map what that J1 pins are?
I will use the PCB alone to embed and I'd like to solder wires directly to get GND, 5V and TX.
thoms
#18
Apr 10, 2012, 09:46 am Last Edit: Apr 10, 2012, 11:02 am by thoms Reason: 1
Mike Cochrane has already documented that : http://mikenz.geek.nz/blog/gpslim236_arduino/
Initially I pulled it apart and found the 7 test points on the left of the board. These turned out to be a serial interface, from top to bottom:
   1. ?
   2. Ground
   3. RTS
   4. CTS
   5. TXD
   6. RXD
   7. ? - maybe power in?
To make easier to read, I gathered all usefull pieces of information in the first post of the topic.
