Topic: Cant upload to Nano (Read 631 times) previous topic - next topic
orty1982
Hi all,
I am brand-new to all this. I have the following error when trying to upload the Blink example to my Nano:
avrdude: stk500_getsync(): not in sync: resp=0x00
So i have vista 64-bit. the driver installed correctly as far as i am aware
i have the correct board selected (Nano w/ ATmega328) and correct port selected (COM3).
physically, the PWR led is constantly on and the L led is flashing on/off.
when i click Upload, the L led rapidly flashes 3 times and then the RX led does 3 small flashes, and then the L led goes back to the constant flashing, and then i get the above error.
i tried pressing the reset button at different points for different time intervals, but no luck.
any advice?
nickgammon
Did you read this?
http://www.arduino.cc/en/Guide/Troubleshooting#upload
More info:
orty1982
yes i have read that link:
- I am fairly sure ive selected the correct board and port.
- the driver installed itself (its a nano), and when i go to Device Manager under COM3, it says the latest driver is installed for that device.
- i have firewall turned off, no other active programs running.
- the nano is not connected to anything except the usb cable to pc and is sitting on my wooden desk.
- ive tried different usb cables.
- as i said above, ive tried the reset button trick, doesnt do anything.
legwinskij
Are you running Arduino 1.0 or older one ?
Verbose output could show more
on older Arduino software just hold shift while uploading
and on Arduino 1.0 go to file -> preferences -> show verbose output
nickgammon
I feel some sympathy because this happened to me yesterday with a Uno that had previously worked. Turned out I must have done something to the bootloader (not too surprising with what goes on here). That doesn't particularly help you, but if you have another programmer or an Arduino Uno you can set up as ArduinoISP, you might be able to work out a bit more. The verbose output might give a clue.
More info:
runaway_pancake
When you connect/disconnect the Nano does Windows do that USB 'bing-bong' sound?
All my Nanos come in at > COM10.
Once, I bought some that came with bad cables.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
orty1982
ok, so i tried connecting the nano to my laptop which is running XP and it works!! was able to successfully upload the blink example.
hmmm, maybe it is a driver issue or some other software conflict issue with my vista desktop?
well, i dont care, as long as it is working on the laptop, im happy to just work with it off that and not spend any more time troubleshooting.
thanks to all who provided their time of day to try to help me out. im sure ill be having lots of frustrating (but fun) moments which will require me to seek help here, but it seems people are genuinely helpful!
