Loading...
Pages: [1] 2 3   Go Down
Author Topic: 16x16 RGB LEDs with 96 register, good idea?  (Read 1260 times)
Offline Offline
Newbie
View Profile
First time poster, if I sound impolite, please smack me as needed. It is not intended.
My plan: 16x16 pixel of RGB LEDs, common cathode.
I have Arduino Mega 2560, excessive IO port usage is not a problem (for now).
I assume that most of the LED arrays use shift registers, turning on one row/column at a time, and depend on high refresh rate for persistent-like display.
So, I attempt to use 96  8-bit register / d latch to allow consistent display, and the arduino will only update the selected register as needed. I will update each register with 8 IO pin from Arduino, if it is actually worth the reduction of time delay, if any.
I know this will be expensive, as 96 8 bit  D Latch will cost almost as much as 256 RGB LEDs.
However, my question will be:
Will having register remembering each pixel color will have significant increase in performance (display to eyes)?
Will this worth the price for the max performance it can obtained compared to row-scanning method?
If there is anything worth mentioning, I will like to hear.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
It will be brighter because you don't need to multiplex it, but the unit will take more current.
Quote
It is not so easy to scale up electronics like that, for a start each logic output from the arduio can only drive 20 or so inputs, so you will need some buffer chips. It needs proper layout on strip board with lots of decoupling and a good power supply. Assuming each LED takes 20mA the a 16 X 16 matrix will take -> 16 * 16 * 3 * 0.02 = 15.36 Amps, that is quite a lot.
Also 96 X 8 is 768 arduino outputs, a touch more than a mega has free, and I am not sure you can drive 8 LEDs direct off the D-type latch.
Apart from that the plan is flawless.
Logged
Offline Offline
Newbie
View Profile
I have a 36A 5V power supply to power the LEDs. And I am planing to use up to 15 8-bit demux to access each register independently (and part of the plan is to update only the changing pixels/register selectively).
Also, all of 8 input of registers will share the same 8 output from Arduino.
 Other than the fact that it will get expensive, I still want to know if I can obtain "higher" framerate for smoother animation if I do it this way.
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Are you planning to do PWM as well, or is this just a 6 color + black variant?
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Offline Offline
Brattain Member
View Profile
WWW
Quote
Not particularly, you will have a big problem just working out what part of the image to update, it is much easier to refresh it all.
Quote
So just remember what I said about buffering.
Logged
Offline Offline
Newbie
View Profile
You can't really control the colors with those registers, you will only be able to make them red, yellow, green, blue, violet, cyan, white, and off.
You could however theoretically use 48 TLC5940's, but that will be expensive (100,- if you order them in china), and you will need a LOT of decoupling.
I'm currently building a big board with 256 warm white leds to light my room, and with only 4 TLC's I already had to decouple a lot, but it could be possible.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Well the data sheet says
Quote
The maximum number of cascading TLC5940 devices depends on the application system and is in the range of 40 devices.
So you are pushing it with 48.
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
If I were tasked to do this I would do either of two things, depending ob budget / performance demands:
A)
Make it modular with one controller per board and one more chip to distribute data. 8x8 RGB (PWM-ed) is known to work with shift registers (done that) and it certainly works very well with LED drivers. If you want to force everything into one micro it will be pretty busy and probably won't have much time left for other stuff (user interaction).
B)
Use a much beefier micro with lots of reserves (like xmos).
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
I think architecturally, I would run 12 groups of 8 shift registers in series, with each group having its own SlaveSelect line, and then update a group using
eight SPI.transfer commands. Cuts way down on the number of parts, your data could be stored as 96 bytes in an array, and just update the section that changed.
Or arrange other ways: 4 groups of 4x4 with 4 SS lines, update each group as something changed.
16 groups of 2x2. Whatever.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
I will do PWM if I can, but the best I can do is a quick switch of ON and OFF per refresh cycle. So, by design, I am not planing for it to have true PWM coming into the LEDs, unless there is an easy way to implement.
Quote
I might have the computer to tell the arduino exactly which part that will be changed, if needed. But this is just secondary objective.
Thank for providing me a new method, I am not sure how to control it for now, but my guess is that it will truly get messy when it comes to 256 RGB LEDs.  At this rate, I might as well already use 4 colorduino with the 8x8 RGB LEDs matrix.
You are probably right on the spot for that. I will need to concern about computer-arduino interaction part.
Do you think that using the shift registers will be "fast" enough to update for a 256 RGB LEDs? I am not experienced, but I just have a feeling that I will not get a good refresh rate (target at minimal 30 FPS). I believe that this method will share the same brightness as using d-latch register. Also, what is the relative price comparison between register and a shift register?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Ok, I  miscounted. 16 x 16 x 3 for RGB = 768 bytes.
SPI runs at 4 MHz.
4,000,000 / 8 = 500,000 bytes/second / 768 byte = 650 frames/second
Throw in loss for other stuff going on, you can still hit 30 frames/second easy.
Get a chip with more memory, '328 with 2K of memory and storing your image in 768 bytes of it could be an issue.
Like a '1284 with 16K of RAM.
16 x 16 x RGB is really more like 48 x 16, I'd go multiplexing route with 48 anode drivers and 16 cathode current sinks using >1A transistors (48 x 0.02A)
Logged
Offline Offline
Newbie
View Profile
SPI runs at 4 MHz.
I have Arduino 2560 , 8kb RAM should be sufficient?
Just a side note to the non-persistent light method, I am trying to get a combo of capacitor and resistor attached next to the LED for each anode, with the hope that it will be able to retain some brightness when it is disconnected. Have anyone ever experienced with this before?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I don't see how that works unless you add a diode as well to prevent the drive line from just discharging the cap as soon as the the charge line turns off.
Might as well go with a bank of 12 7219/7221's to control 64 LEDs each.
8 SPI.transfer()s to each to update the display.  Techone just bought 70 of them for 50 cents each.
Logged
Offline Offline
Newbie
View Profile
I am looking at this http://www.ebay.com/itm/10PCS-MAX7219CNG-DIP-24-MAX7219-MAXIM-LED-Display-Drive-/250905632143?pt=LH_DefaultDomain_0&hash=item3a6b241d8f#ht_2107wt_1163
The data sheet said that this is designed for common cathode design. I am right now will try to think of a way to link 3 of MAX7219CNG to synch  because the RGB leds are common cathode by itself.
Logged
Offline Offline
Brattain Member
View Profile
WWW
You are mixing up the use of the term common cathode to describe the way an RGB LED is wired with the term common cathode which describes the way a matrix is wired.
This page will explain the fundamentals of multiplexing:-
http://www.thebox.myzen.co.uk/Workshop/LED_Matrix.html
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
