Topic: "Invalid device signature" (0x000000) since Arduino 1.0; works in 0022 (Read 3354 times) previous topic - next topic
Drmn4ea
I am (finally) patching my Arduino-derived project up to 1.0 and ran into an oddity; it seems 1.0 (or the version of avrdude that comes with it?) no longer recognizes the Arduino serial (Duemilanove and earlier) bootloader's protocol (stk500), or at least has altered its implementation in such a way that it no longer recognizes the chip. The Mosquino (Sanguino-based) board uses an ATmega644pa with the Sanguino's 'adaboot' bootloader. Its boards.txt file specifies the upload protocol as follows:
mosquino.upload.protocol=stk500
Randomly changing this from 'stk500' to 'arduino' (as mentioned in this thread) gets it working again, but for a published project, I'm wary of relying on what seems to be a 'voodoo' fix without understanding how or why it works, or what the problem was in the first place. Does anyone know more about this - e.g. is the underlying problem/solution/change documented anywhere, and is this a 'stable' fix that I can safely push out? What actually changed?
Thanks in advance!
More info:
With Arduino IDE versions up through 0022, uploading a sketch proceeds normally. Abridged verbose output:
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "J:\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM18
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 19200
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv:
################################################## | 100% 0.02s
avrdude: Device signature = 0x1e960a
But with 1.0, upload produces:
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "J:\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [00]
avrdude: Recv: . [10]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.05s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
It seems to use a different method to read the signature(?).
Coding Badly
I have no idea if the following paragraph is correct but it is what I recall from reading various tidbits... avrdude has been drifting towards more use of the "universal command" (that's the 'V' in the send data).  This moves more "intelligence" up into avrdude and allows the programmer to be become much "dumber".  In the extreme case, avrdude handles all the details and the programmer only has to support a single command.  The idea is that avrdude is much easier to change and fix than a programmer.
I don't think any of the Arduino STK500 bootloaders support the "universal command".  Optiboot definitely does not support it...
[font=Courier New]    else if(ch == STK_UNIVERSAL) {
      // UNIVERSAL command is ignored
      getNch(4);
      putch(0x00);
    }[/font]
Probably.  But I have no idea where.  That bit escapes my memory.
Yes.  There are too many boards that do not support the "universal command".  One way or another avrdude has to support STK500 as you used to know it.
Is the stuff above a good enough explanation?
Drmn4ea
I understand it's just hearsay, but this sounds plausible. What you're saying is most likely this is an issue with avrdude itself...i.e. that the official STK500v1 protocol has supported the "universal command" always, but older versions of avrdude didn't make use of it until now (causing problems since the Arduino "STK500" serial bootloaders don't support it). Is the 'arduino' entry then some "STK500-like" protocol definition (that all Arduino projects should have been using all along) that forces the non-use of the "universal" commands?
David Mellis himself (*genuflection*) posted the fix in the thread linked above, so I've replied there in case he's still watching that thread and can give the answer definitively. Figuring he knows a thing or two ;-)
Coding Badly
Probably not "all along" but the "arduino" protocol has been available at least since 2010-01-19 (the latest WinAVR release).
I believe the "arduino" protocol is just the old STK500 source code.
In fairness to the Arduino folks, the old STK500 (the new "arduino" protocol) is very likely much more efficient (i.e. faster uploads).
