Loading...
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: Glitching TLC5940  (Read 1901 times)
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
but if I wait like half'n hour, and power the board again, the TLC's will again function for about 2 seconds.
Sounds like they are getting hot. I would measure the current in and see if it is what you expect.
Logged
Offline Offline
Newbie
View Profile
I gave up on the old board and started to build a new one:
How would be best to wire the power/signal lines?
From one point to all 4 the TLC's? (and the arduino, if talking about power lines)
From the power source/signal source in series over al the TLC's?
Or a combination where i'd split the line and run it over 2 TLC's?
Logged
Offline Offline
Newbie
View Profile
I found the problem!!
I was using a 7805 with heatsink, but with a metal screw, so the entire heatsing was connected to the ground of the 7805.
That explained why it would stop working when heating up! Fixed it now. smiley
Logged
Offline Offline
Newbie
View Profile
Okay nevermind, it's acting the same again, after 3 min.
Logged
Pages: 1 ... 3 4 [5]   Go Up
Print
Jump to:
