Loading...
Pages: [1]   Go Down
Author Topic: Arduino Ethernet board and Telnet  (Read 536 times)
Offline Offline
Newbie
View Profile
I've been trying to talk to an Arduino Ethernet board (not shield)
with telnet, and have go nowhere; thanks to this forum I've got
ping running, but the telnet or udp or web stuff I want to add
simply hangs.  Below is the sketch I've been trying - it runs ok
(without handling telnet) until the EthernetClient line is added,
and then it hangs - no response to ping, nothing on the serial port.
I'm using arduino-1.0.1 and avr-gcc-4.5.3 (on Linux).  It looks as
if the Ethernet library is blocking somewhere, but following through
a maze of C++ class initialisations isn't easy.  Can anyone see
where I might be going wrong, or suggest a working library?
Thanks - Will
Code:
// Test of Arduino Telnet.
#include <SPI.h>
#include <Ethernet.h>
// Undefine this to get a working program.
#undef TELNET
// the media access control (ethernet hardware) address for the Arduino:
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x92, 0x34 };
// the IP address for the Arduino:
byte ip[] = { 192, 168, 1, 20 };
// telnet defaults to port 23
EthernetServer server(23);
  // Initialise the serial device.
  delay(2000);
  Serial.println("setup()");
  // Initialize the ethernet device
  Ethernet.begin(mac, ip);
  // start listening for clients
  server.begin();
  Serial.println("loop()");
  // Uncommenting this statement hangs the sketch.
  // The response from ICMP is "Destination Host Unreachable"
  // Read bytes from the incoming client and write them back
  // to any clients connected to the server.
#ifdef TELNET
  if (client) {
    char c = client.read();
    server.write(c);
#endif
// eof
« Last Edit: April 03, 2012, 04:02:16 pm by cwrose » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
please modify your post, select the code and press the # butto to get it proper tagged , makes it easier to read.
seen this thread on the old forum - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278686415 - ?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
