Topic: Printing special characters (Read 6238 times) previous topic - next topic
ninja2
Where can I find a list of all the special characters for char arrays and printing, like \n, \o and similar
Also how would I print the little superscripted 'o' symbol for degrees C or F, e.g. in 27<degrees symbol>C
TIA
mrdovey
From The C Programming Language:
\a   alert (bell) character
\b   backspace
\f   formfeed
\n   newline (linefeed)
\r   carriage return
\t   horizontal tab
\v   vertical tab
\\   backslash
\?   question mark
\'   single quote
\ddd octal constant
\xhh hexadecimal constant
The degree symbol (as in 27°C) is unknown to C and (I think) C++ and printing it will probably involve device dependencies.
Tumbleweed
Ninja2,
Try this page, you can even create your own custom character.
http://www.quinapalus.com/hd44780udg.html
TomJ
Einstein once said you don't really understand anything until you can explain it to your Grandmother
Tumbleweed
Ninja2,
Just read a way to print the degree symbol on another post.
It's at the  bottom of the alternative code for averaging.
http://arduino.cc/forum/index.php/topic,99557.0.html
TomJ
ninja2
#4
Apr 03, 2012, 12:35 pm Last Edit: Apr 03, 2012, 09:04 pm by ninja2 Reason: 1
excellent help, thanks all
I must use/learn that list of backslash codes ...
found the magic syntax too ...
lcd.print((char)223);    // degree
yeeha  :)  :)
... great forum, friendly players, top advice, fascinating topic(s) :)
ninja2
The degree symbol (as in 27°C) ...
Morris - how did you insert / type the degree symbol into your text above ?
mrdovey
On this keyboard the degree symbol is shift+option+8 (An * that's turned into a ° by the option key).
You can do the same thing on a Windows keyboard by holding down the Alt key and typing in a code on the numeric keypad - but I've already forgotten the code.  :-(
ninja2
º how about alt+0186 º  :)
ºXºXºXº
google is so amazing these days, I just googled "How to type degree symbol on PC" and bingo
liuzengqiang
ºXºXºXº
Next day Google will push books ad to you that features a whole chapter on "How to type degree symbol on PC"  ;)
mrdovey
If the Extended ASCII code is 233, then you should be able to embed it in a string as
   char *temperature = "Today's high temperature is 27\xE9""C"
But my wimpy bash terminal window displays it as a question mark.  :-/
oric_dan
from Morris:
\r   carriage return
I assume \r sends only a 13, but does \n send only a 10, or both 10 + 13?
PaulS
Depends on what is doing the sending, on what operating system.
oric_dan
How about this one: Serial.print("\n");
ninja2
LOL , and I'm a the perfect target for such :)
PaulS
Sends exactly one byte - the new line value, 10. to the serial port.
