Pages: 1 [2] 3   Go Down
Author Topic: Inconsistent HTTP Connnection  (Read 2535 times)
Miramar Beach, Florida
That was my bad.
Which code are you using now? Are you still trying your original code? Or zoomkat's?
I haven't had a chance to work on this project for the past few days, but I tried using my original code (with a few modifications) as well as zoomkat's. Both seem to give me mixed results as far as connectivity. With zoomkat's, sometimes it connects and downloads a page immediately after I press 'e', other times it takes around 20 seconds before it says connection failed.
I originally had things set up in a for loop so that it would keep trying over and over again. This seemed to provide okay results, but also seemed like a work-around with addressing the actual problem.
This loads www.google.com every 10 seconds. Don't do that to Google too long. Besides, it is a big page and takes a while to display at 9600 baud. Change the server ip to yours.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,2);
IPAddress gateway(192, 168, 2, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress server(74,125,227,16); // Google
EthernetClient client;
int totalCount = 0;
int loopCount = 0;
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  Serial.println("Ready");
  if(loopCount < 10)
    loopCount = 0;
    if(!getPage(server,"/")) Serial.print("Fail ");
    else Serial.print("Pass ");
    totalCount++;
    Serial.println(totalCount,DEC);
  loopCount++;
byte getPage(IPAddress ipBuf,char *page)
  int inChar;
  char outBuf[64];
  Serial.print("connecting...");
  if(client.connect(ipBuf,80))
    Serial.println("connected");
    sprintf(outBuf,"GET %s HTTP/1.0\r\n\r\n",page);
    client.write(outBuf);
    Serial.println("failed");
    return 0;
  while(client.connected())
    while(client.available())
      inChar = client.read();
      Serial.write(inChar);
  Serial.println();
  Serial.println("disconnecting.");
  client.stop();
  return 1;
Hmmm, well that seems to work so far. I've only had a few minutes this morning to play, but I haven't gotten any failed attempts (except for when I forgot to change the IP).
So what's different? Why is this one connecting fine whereas the others weren't?
The others were not mine.  smiley
edit: There are some reasons mine works better. I know how tcp works. If you look at the getPage() function, you will notice the "while(client.connected()) while(client.available())" loops.
If you are downloading a big page (like Google's home page), you will get several packets. That loop will check client.available(), and for a while, it will be zero. Then it will be about 1400. Your goal is to empty that rx buffer as fast as you can. Get client.available() to zero. Then it may be zero again for a few checks, then it will be 1400 again (another packet).
The client.connected() will return true until you have emptied the rx buffer of the final packet, so as long as client.available() returns non-zero, you are connected.
« Last Edit: April 10, 2012, 03:31:08 pm by SurferTim » Logged
Yeah, that's exactly what I was thinking it did...  smiley-lol
Thanks so much! I'll keep you posted if I run into errors with this, but so far so good.
I can't beleve this code is yours! It doesn't contain the magic pixie dust (below) that makes all things work!  smiley  I notice the code does have a fat 2000ms delay that has been used in older code.
   // disable the SD SPI interface
   pinMode(4,OUTPUT);
   // rest of your setup
put in key search words,
   pinMode(4,OUTPUT);
You did not pay attention, because it does have the magic pixie dust!  smiley
Oh, my bad! Just as a test, I removed the pixie dust from your code like below, and ate some salted peanuts instead. The code made 17 successful passes, so salted peanuts work too!  smiley
#include <SPI.h>
int totalCount = 0;
int loopCount = 0;
  //pinMode(4,OUTPUT);
  //digitalWrite(4,HIGH);
  Ethernet.begin(mac);
  delay(2000);
« Last Edit: April 10, 2012, 11:21:30 pm by zoomkat » Logged
I used to think that too. Here is an old thread that we both were involved in. Read reply #28.
http://arduino.cc/forum/index.php/topic,75324.0.html
I don't think salted peanuts would have helped there. The magic pixie dust did.
The OP's question was why mine was working and the others weren't. This is part of the reason why.
edit: If you want to read the posts where I was being you and eating salted peanuts, read replies 7,20,and 26.
« Last Edit: April 11, 2012, 06:50:02 am by SurferTim » Logged
italy
Muuuuu
One question? How can we be sure that the program will never stop on the line
If the client connection does not end we will never go out of the while loop
Good question. There is the possibility of a lockup there if the connection breaks. Here is the thread with the discussion and the patch for a 10 second timeout.
http://arduino.cc/forum/index.php/topic,102879.msg778413.html#msg778413
italy
Muuuuu
thanks
#include <SPI.h>
int totalCount = 0;
int loopCount = 0;
  pinMode(4,OUTPUT);
  delay(2000);
  if(loopCount < 10)
    loopCount = 0;
    totalCount++;
  loopCount++;
  int inChar;
  char outBuf[64];
    return 0;
  Serial.println();
  client.stop();
  return 1;
The server I'm trying to reach is in a virtual hosting environment so in addition to the ip address, I need to specify the host I want to connect to. Do you have any advice on where that would be included if one wanted to make that tweak?
It is sent on a line by itself after the GET, followed by a double CR-LF.
    // Insert it here.
    sprintf(outBuf,"GET %s HTTP/1.0\r\nHost: www.mydomain.com\r\n\r\n",page);
edit: Insure outBuf has sufficient memory allocated to hold all that.
« Last Edit: May 28, 2012, 04:01:48 pm by SurferTim » Logged
Pages: 1 [2] 3   Go Up
