Topic: MENWIZ: yet another character lcd menu wizard library (Read 176571 times) previous topic - next topic
backbone
Bruno,
Good to see the new 1.0 version and the new extra's.
I have to appologize for not creating yet a new bie manual.
Having heavy time issues on several projects.
Paco
Never to old to learn and I learn every day
brunialti
#121
Jul 30, 2012, 06:29 pm Last Edit: Jul 30, 2012, 06:32 pm by brunialti Reason: 1
@dannix
It is hard to say why. I would need to setup the analog buttons as yours, but I have not some of the components.
I'll try to make an old fashioned code inspection ... With the new lib v1.0.0 you do not need to apply the patch I sent.
Did you use the errorMessage  during debug after each instruction? Did you get some message?
I'm committed to solve it before holyday :-)
brunialti
@backbone
nice to read you again. If you had a practical application of Menwiz (and it works :-) ), it could be interesting share it with the communiy, even criticism,
brunialti
Paco, by the way, are you using custom buttons or devices using addUsrNav method?
You could help me to test/debug setBehaviour in such a condition!
dannix
@dannix
Hi,I'd not used errorMessage but have tried again using it, I get no errors. Code below and using latest library.
Code: [Select]
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_SR.h>
#include <buttons.h>
#include <EEPROM.h>
#include <MENWIZ.h>
//INTERRUPT BUTTONS
const int pin = 13;  // test for interrupt
const int buttonPin = A0; // buttons can be read here
volatile byte buttonAct = 0; // flag, follow button press
volatile int buttonValue = 0; // button pressed analog value
volatile byte buttonPressed = 0;  // which button was pressed
volatile byte lastButtonPressed = 0; // prev button pressed
volatile byte state = LOW; // state of led on pin 13
// DEFINE ARDUINO PINS FOR THE NAVIGATION BUTTONS
#define UP_BOTTON_PIN       9
#define DOWN_BOTTON_PIN     5
#define LEFT_BOTTON_PIN     7
#define RIGHT_BOTTON_PIN    8
#define CONFIRM_BOTTON_PIN  3
#define ESCAPE_BOTTON_PIN   4
menwiz tree; //create menwiz object
// create lcd obj using LiquidCrystal lib
LiquidCrystal_SR lcd(10, 11, 12); //Data,Clk,Enable.
int  list,sp=110;
void setup(){
  Serial.begin(19200);
  Serial.println(F("STARTED"));
  pinMode(pin, OUTPUT);
  attachInterrupt(0, readButtons, RISING);
  _menu *r,*s1,*s2;
  tree.begin(&lcd,20,4); //declare lcd object and screen size to menwiz lib
  tree.addUsrNav(navMenu);
  r=tree.addMenu(MW_ROOT,NULL,F("Root"));
  s1=tree.addMenu(MW_SUBMENU,r,F("SUBMENU"));
  s2=tree.addMenu(MW_VAR,s1,F("Node3"));
  s2->addVar(MW_LIST,&list);
  s2->addItem(MW_LIST,F("Option1"));
  s2->addItem(MW_LIST,F("Option2"));
  s2->addItem(MW_LIST,F("Option3"));
  s2=tree.addMenu(MW_VAR,s1,F("Node4"));
  s2->addVar(MW_AUTO_INT,&sp,0,120,10);
  s2=tree.addMenu(MW_VAR,s1,F("Exit"));
  s2->addVar(MW_ACTION,exitFunct);
  s2->setBehaviour(MW_ACTION_CONFIRM,false);
  //tree.navButtons(UP_BOTTON_PIN,DOWN_BOTTON_PIN,LEFT_BOTTON_PIN,RIGHT_BOTTON_PIN,ESCAPE_BOTTON_PIN,CONFIRM_BOTTON_PIN);
int i = 0;
void loop(){
  if(i > 1000){
    Serial.print(F("freeRam() reports "));
    Serial.println( tree.freeRam() );
    i = 0;
  else{
    i++;
  tree.draw();
  int err = tree.getErrorMessage(true);
  if(err){
    Serial.println(err);
void readButtons(){  //fired by interrupt 0
  state = !state;
  digitalWrite(pin, state);  // flip pin 13 led state
  /*   511 : none | 614 : up | 768 : down | 1023 : select   */
  lastButtonPressed = buttonPressed;
  buttonValue = analogRead(buttonPin);
  if(buttonValue >= 900) {
    buttonPressed = 3; // select
  else if(buttonValue >= 700){
    buttonPressed = 2;  // down
  else if(buttonValue >= 600){
    buttonPressed = 1;  // up
  buttonAct = 1;
  Serial.print(buttonPressed);
  Serial.print(" XX ");
  Serial.println(buttonValue);
void exitFunct(){
  Serial.println("EXIT Called");
  buttonAct = 1;
  buttonPressed = 4;  //simulate exit button press
int navMenu(){ //called by menwiz.draw()
  if(err){
  if(buttonAct){ //true if button press not processed
    buttonAct = 0; // run once per button press
    switch (buttonPressed){
    case 4: //simulated escape
      return MW_BTE;
    case 3: //select
      return MW_BTC;
    case 2: //down
      return MW_BTD;
    case 1: //up
      return MW_BTU;
  else{
    return MW_BTNULL;
brunialti
#125
Jul 30, 2012, 09:33 pm Last Edit: Jul 30, 2012, 09:34 pm by brunialti Reason: 1
The usernav function (same as the builtin scanNavButtons) is called just and only in one point in the code, at the beginning of draw() method:
Code: [Select]
 ret=usrNav.fl?usrNav.fi():scanNavButtons();     //internal method or user defined callback?
as you can see the builtin xor your function, internally coded as usrNav.f(), returns a button code that is therefore processed by the following code.
This imply that if your function returns the same code as the builtin one, the executed code after the call is *exactly* the same. There is no other code  that is performed by builtin function (no initialization, no global or local variables assignment). This is the reason why I cannot understand why the behaviour is different, provided the two functions return the same values for equivalent actions.
So, in a pure deductive way  8) ... you need to check if the value returned by your function (the value of ret variable) is the one you expected (e.g. is equal to MW_BTC after pushing Confirm button). Try to put a Serial.println trace after that. Of course as the call to draw() are many in the loop you must quickly unplug the usb cable (or put a conditional printing checking for the expected code).
Regarding the  use of tree.getErrorMessage(true),  if no error occourred in the *last* executed MENWIZ method call, it does not print to Serial. If an error occourret it print to Serial both the error code and an error message.
I suggest to use it in the menu structure declarations in such a way:
Code: [Select]
if no message is printed out in the serial terminal, it means no error occourred.
I hope this can help
backbone
Do not know exactly what you mean.
I burned up my project shield and Mega.
Currently rebuilding the set up with shield and a new Mega.
Used 4 pushbuttons on the digital ports. Do not know if you call that custom buttons.
My code does not use any addUsrNav methods as far as CTRL+f can find......... :-)
Let me know how I can assist in current situation.
If you need the bare code of the MENWIZ I currently use no problem.
Paco
dannix
Hi
I've added the trace calls and It returns as expected. This is without setBehaviour declared, so run confirm expected. my funct passed MW_BTC but isn't followed by "EXIT called" as if my custom function ins't called.
Code: [Select]
STARTED
3 XX 1016
SELECT
2 XX 762
DOWN
freeRam() reports 898
2 XX 763
DOWN
3 XX 1016
SELECT
3 XX 1017
SELECT   <---- my funct passed MW_BTC
This is with s2->setBehaviour(MW_ACTION_CONFIRM,false);
Code: [Select]
STARTED
3 XX 1017
SELECT
2 XX 763
DOWN
2 XX 764
DOWN
3 XX 1015
SELECT
EXIT Called
ESCAPE
yet this time it works, when select (MW_BTC) is passed, my function returns EXIT Called as expected sets the button values and MW_BTE is passed as can be seen by the ESCAPE. menwiz goes back a level, except in the new version of the library the line below isn't cleared. It was before.
When I press a button the interrupt fires "3 XX 1015" then I see its corresponding value sent to menwiz SELECT/MW_BTC if it was an exit i see the simulated escape being passed ESCAPE.
dannix
I have some buttons, What i'll do is hook them up to digital pins thereby removing the custom button function and see if the same thing happens. I'm certain it's not my button implementation though.
Thanks for your help
brunialti
I'll do the same, using digital button with your code!
thanks for your patience.
dannix
#130
Jul 31, 2012, 01:11 pm Last Edit: Jul 31, 2012, 01:14 pm by dannix Reason: 1
Hi, I've tried using 4 digital buttons. Its exactly the same. Confirm to run does not actually run the custom function. If confirm disabled it runs the custom function once selected.
Using the digital escape button goes back a level but line 3 of the lcd isn't cleared (Node4) and can't be selected. Again, it didn't do this in the previous library version, this is a regression in the latest code.
Here is the code I ran with little changes, buttons defined and addUsrNav commented out
Code: [Select]
#include <Wire.h>
#include <LCD.h>
#include <EEPROM.h>
#include <MENWIZ.h>
//INTERRUPT BUTTONS
#define UP_BOTTON_PIN       8
#define DOWN_BOTTON_PIN     7
#define CONFIRM_BOTTON_PIN  4
#define ESCAPE_BOTTON_PIN   3
int  list,sp=110;
void setup(){
 _menu *r,*s1,*s2;
anyErrors();
 anyErrors();
 //tree.addUsrNav(navMenu);
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 anyErrors();
 //s2->setBehaviour(MW_ACTION_CONFIRM,false);
anyErrors();
Serial.print(MW_BTNULL);Serial.print(MW_BTU);Serial.print(MW_BTD);
Serial.print(MW_BTC);Serial.println(MW_BTE);
 tree.navButtons(UP_BOTTON_PIN,DOWN_BOTTON_PIN,ESCAPE_BOTTON_PIN,CONFIRM_BOTTON_PIN);
int i = 0;
void loop(){
 if(i > 1000){
   i = 0;
 else{
   i++;
 tree.draw();
 anyErrors();
 state = !state;
 buttonAct = 1;
anyErrors();
void exitFunct(){
 buttonAct = 1;
//tree.draw();
void anyErrors(){
 if(err){
     Serial.println(F("ESCAPE"));
     return MW_BTE;
   case 3: //select
     Serial.println(F("SELECT"));
     return MW_BTC;
   case 2: //down
   Serial.println(F("DOWN"));
     return MW_BTD;
   case 1: //up
   Serial.println(F("UP"));
     return MW_BTU;
 else{
   return MW_BTNULL;
brunialti
ok. Now I can replicate the problem.
I confirm the regression :-(
brunialti
#132
Jul 31, 2012, 10:17 pm Last Edit: Jul 31, 2012, 10:19 pm by brunialti Reason: 1
-FIXED
-FIXED
-FIXED
Dannix, can I ask you to test the fixed code before to deliver a new version?
Please find here attached the file to replace the existing ones.
dannix
It works as expected both with digital buttons or with the custom button function! This library will save me alot of time in my project, I can start fleshing it out now. Thank you for all your work brunialti this could be the default Arduino IDE menu library
brunialti
Nice to read the problems are over.
I inserted the new lib v 1.0.1 in git hub at https://github.com/brunialti/MENWIZ/downloads
I think it is unfair for me as author to promote the lib. It is up to the community to signal if there is something new and interesting on the net :-)
