Loading...
Pages: 1 [2]   Go Down
Author Topic: Bootloader problem - Arduino Mega and Duemilanove  (Read 1524 times)
Offline Offline
Edison Member
Now, More Than Ever
View Profile
It's an ATmega328P-PU and not a ATmega328-PU?
And you have the Board selected = Duemilanove?
Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Offline Offline
Newbie
View Profile
Well,
I really really appreciate the help extended by all the friends here. Special thanks to Mr. Nick Gammon. Your solution worked like a charm sir.
It comes out that I was using wrong pins of Mega to connect to duemilanove. This should have been explained by arduino guys while explaining how to use Arduino as ISP. Thanks to Mr. Gammon, I used the mega pins as he explained and followed the instructions given at http://www.sparkfun.com/tutorials/247 religiously.
I was able to successfully program both the new Atmega328p and they are taking up sketches as they are supposed to.
A word of caution though, for newbies like me: Avrdude does not work properly with IDE 0018. while worked perfectly with IDE 1.0. Also, the bootloader for 328p that comes with "Arduino Optiboot Bootloader" ( which can be downloaded at the sparkfun page linked above) did not work for me. It burned the bootloader but then I was unable to upload sketches to 328p. Contrary to that, the bootloader that comes arduino IDE, works perfectly fine.
@CrossRoads: do we need to set fuses first for the new part for using optiloader to program directly through mega?
Regards
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
@drwaseem,
I don't know.   westfw could probably answer that.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: 1 [2]   Go Up
Print
Jump to:
