Loading...
Pages: [1]   Go Down
Author Topic: Should connector sheilds be grounded?  (Read 885 times)
Smithfield, Rhode Island
Offline Offline
God Member
View Profile
Hi All...
I am using a few connector libraries, one for DB9 and one for a mini-USB connector with legs. I noticed that the EAGLE libraries don't seem to ground the vias that the thru hole parts of the connectors mount through. Is there a reason for that or is it okay to ground these vias?
Thanks...
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Okay to ground, but only at one end. Don't want to create ground loops.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Sr. Member
bluesmokelabs.com
View Profile
WWW
I dont believe ground looping is a problem with connectors as they are on the same circuit.  I could be wrong(most likely) but I thought ground looping was an issue with 2 different circuits sharing a common connection to ground.  Where the 2 circuits should only have 1 point of contact.
I ground all shields unless the datasheet advises otherwise.  It makes the solder connection much stronger(not just a single pad to tear up[I use ground planes]) but is a little harder to solder in the first place.
Phil
Logged
Offline Offline
God Member
View Profile
Thanks guys.
Logged
Pages: [1]   Go Up
Print
Jump to:
