Author Topic: What is Arduino exactly?  (Read 530 times)
I've seen C++ and C mixed together while coding in Arduino.
So is Arduino the IDE? and the language is C part C++
meanwhile check out my crappy weather station  I've just finished writing, i use a BOSH BMP085 sensor with Wiznet to deliver a basic weather station
http://110.175.97.110:1234
(South Australia, Adelaide, Clearview)
http://www.weatherzone.com.au/sa/adelaide/clearview   (official info to compare to)
So what am i coding in? hybrid C/C++ ?
« Last Edit: April 04, 2012, 12:57:24 am by cjdelphi » Logged
Smithfield, Rhode Island
C++ is a superset of C. The language of Arduino is C++.
West Des Moines, Iowa USA
Craig - It's working. Consider adding a location; weather info for 'noplace in particular' isn't very useful. smiley
Unless you cause it to behave differently, the Arduino IDE compiles your code as C++.
There's always a better way!
lol, the location is my bedroom, um South Australia (Adelaide) smiley-razz - but...
the question was, and you've answered it, C++ - i'll be honest i hate C++ as long as i get away with C (on the whole) looking code i'll be happy, my first program i wrote
was written in C when i was 8 (22 years ago) and i like C, not C++ i used Object Pascal (for objects) maybe i need to write a Pascal compiler lol..
anyway so it's C++ huh - thanks.
Melbourne, Australia
Shannon Member
Lua rocks!
Somewhere in South Australia, I am guessing. Based on the 240V and the IP address.
Oh, and the temperature. It's 29C in Adelaide apparently, whereas it's a bit cooler where I am.
Look for the house with the bedroom light off.
(edit) ninja'd!  But I worked it out before he posted.
lol, the bedroom light is a Cree 3 watt LED underdriven via a PNP 2222a transistor smiley  and a 5v linear regulated supply smiley-razz
Yeah well, it is 3:39pm light will be off smiley  lol - so can i say i code in C++ even though it looks identical to C? lol
Shannon Member
Lua rocks!
You can say that if you want to.
A reasonably simple program in C++ will look the same as one in C. Well, put it this way, with some restrictions the same code will compile in C and C++.
But if you are doing this, for example:
Serial.println ("hello");
Then you are using C++.
Serial is an instance of the class HardwareSerial, and you are calling a member function of that instance.
And classes are a C++ thing. smiley
Sorry to disappoint you.
awwww, yeah you're right Serial. <<object smiley-sad
grrrrr lol
SF Bay Area (USA)
Strongly opinionated, but not official!
I am capable of writing C programs in several languages.  C, C++, Java, Perl, ...  :-)
I've grown up on a diet of Pascal and Object Pascal, C++ (objects look scary) but C i can handle, PHP i can handle, C++ and objects that look like object::fsdfsdf scare me smiley-razz
Begin
  Writeln('Please no C++');
End.
lol
or
<?php
  echo "Please no C++ \n";
or
printf(" Really no!");
lol, it's not that i don't like C++ just that i've been spoilt with objectpascal
EG.
Var
 S: String;
 Key,B: Byte;
 N: Integer;
begin
 S:=Edit1.Text;
 Key:=55;
 For N:=1 to Length(S) do
  Begin
    B:=Ord(S[N]);
    B:=B Xor Key;
    S[N]:=Chr(B);
  End;
  LoadLibrary
 Edit1.Text:=S;
for (n=0; n<StrLen; n++)
  int b = 0;
  int key = 55;
 //  B:=Ord(S[N]);  //ord is the Decicmal of Ascci value, eg, A = 65; so abcde becomes 65 66 67...
  //  B:=B Xor Key;  // xor 55 with 65 (A or whatever)
   // S[N]:=Chr(B);  //replace string back with the XOR'ed version
how would you do that in C/C++ ?
The 'English' descriptions  Begin End; XOR, it's all pretty much explained to you as you code, where as with C++ you have to remember so very specific info - i'm spoilt lol
« Last Edit: April 04, 2012, 02:19:05 am by cjdelphi » Logged
Shannon Member
Lua rocks!
I know exactly what you mean. I spent 10+ years programming in Turbo Pascal. C seemed really strange at first. But, you adjust ...
If you can handle C as you say, then what makes C++ so scary? Its not as bad as you think. I don't think its bad at all.
Boston area, metrowest
Almost seems like BASIC with semicolons & { }s at this point.
