Pages: [1]   Go Down
Author Topic: Paid help needed with xbee/arduino setup  (Read 1158 times)
Los Angeles
Offline Offline
Full Member
View Profile
WWW
I have been struggling with creating an xbee setup and would like to hire someone to set it up for me so that I can keep moving forward in my project.
I need 2 arduino FIOs with xbees connected to accelerometers so that each fio is transmiting x and y analog data to a third arduino(UNO) with xbee shield.  The UNO just needs to receive the data, extract it from the data packets and assign it to variables (x1,x2,y1,y2)....  thats it...  I have all the parts including xbee series 1 but I would switch to series 2 if it would help.  The data sample rate does not need to be too fast...500ms max.. bad data is also OK as long as it is ignored by the receiver... range is only 10ft or less between xbees..Should not be too difficult but for some reason xbees turned into a big stumbling block for me.
I have been able to get communication between two xbees but havent had luck extracting the data or getting data from two arduinos.  I need to get past this step soon so if any of you xbee savy members could set this up for me send me a note and let me know what you would charge me and how soon you could get it done.
I am in the Los angeles area but would be ok working with someone out of state as long as they have the availability to start soon.
here is a pic of what I have done so far...(the accelerometer is wired beneath the xbee and above the FIO so its not visible.
« Last Edit: April 04, 2012, 01:37:53 am by fxmech » Logged
Pages: [1]   Go Up
Jump to:
