/* max 24 relay controller and pump pulser simulator
this program takes a serial string like this "12.900.14.14" and parses it up into variables
for relay count 1-12, number of pulses, pulse width, and delay beween pulses.
Then it prints that to the serial port like this "Relays 12 Pulses 900 Length 14ms Delay 14ms"
created 1/7/13
last edit 2/1/13
by Will Meyers
unsigned long counter =0; // set counter to 0
int pulse =52; // pin thats connected to the pulse simulator
int led = 13; // status led
int dly= 150; // delay between relay functions
int relay[]={
14, 15, 16, 17, 18, 19, 20, 21, 30, 31,\
32, 33, 34, 35, 36, 36, 38, 39, 40, 41, 42, 43, 44, 45}; // relay array with all 24 pins
int pinCount = 24; // the number index for the array
void setup() // setup arduino functions
pinMode (pulse, OUTPUT); // set pin 52 to an output
pinMode (led, OUTPUT); // set pin 13 to an output
Serial.begin(9600); // start serial connection
Serial.println("reset");
for(int n=0; n<pinCount;n++){ // for loop
pinMode(relay[n],OUTPUT); // set all relay pins as output
digitalWrite(relay[n], HIGH); // write all relay pins high SETS THEM TO OFF
void loop() // run main loop
if (Serial.available() > 0) // wait for data
int w = Serial.parseInt(); // this is the relay selection variable from 1 -12
unsigned long x = Serial.parseInt(); // this is for the pulse counter
int y = Serial.parseInt(); // this sets how long you want to hold the pulse high
int z = Serial.parseInt(); // delay between pulses
delay(1); // neccesary delay to use Serial.parseint() ;
Serial.print("relays "); // print "relays " to serial port
Serial.print (w * 2); // print the w x 2 or relay pins to the serial port
Serial.print(" Pulses "); // print "pulses "to the serial port
Serial.print(x); // print the var value of x to the serial port
Serial.print(" Length "); // print "length " to the serial port
Serial.print(y);
Serial.print( "ms"); // print the value of y then "ms" to the serial port
Serial.print(" delay " ); // print "delay" to the serial port
Serial.print(z); // print the value of z to the serial port
Serial.println("ms"); //print "ms" to the serial port
for(int n=0; n < (w * 2); n++){ // for loop relay counter * 2
digitalWrite(relay[n], LOW); // set all selected pins low or ON
delay(dly); // delay for variable
delay(dly * w ); // max delay needed to turn on all pumps the var dly * relay selection 1-12
while(counter<(x)) // while counter is less the x do this loop
PORTB = 0b10000010; // port adress of the pulse pin 52 pull it HIGH
delay(y) ; // delay by y or how long to hold the pin high
PORTB = 0b00000000; // pull everything on this port LOW
delay(z); // delay by z delay between pulses
counter++; // increment counter by 1
while(counter==(x)) // after counter equals x do this loop
delay(10); // delay by the value of 10ms
PORTB = 0b00000000; // set all pins in this port LOW
delay(1000); // delay by the value of 1 second
digitalWrite(relay[n], HIGH);// write n # of relay pins HIGH or OFF
delay(dly); // delay by variable dly
Serial.println("done"); // print "done" to the serial port on a new line
return; // fin
