For BMW 3 series 2004.
When I put ATZ, then ATSP0, then 0100 I get these:
0100
SEARCHING...
41 00 BF 9F F9 91
41 00 80 00 00 00
So we know it was the car, and not the board.
0100
SEARCHING...
41 00 BF 9F F9 91
41 00 80 00 00 00
And when I put these:
ATWS
ELM327 v1.3a
ATDPN
A3
0100
41 00 BF 9F F9 91
Looks like your Golf doesn't support the OBD-II standard. Maybe it just has the same connector but does not conform to the OBD-II standard.
BTW: The BMW uses ISO-9141 and does support most of the standard OBD-II PIDs in the first range (1-32).
Looks like it.
This will eventually go on a GM ls9 engine manufactured in 2010.
The code I provided at the start of this thread didn't work with the BMW though
I even changed the restart sequence to the last one you provided, but couldn't get any data back.
Any ideas?
Thanks.
Can you show what you've done? Code?
This is what I tested first:
#include <LiquidCrystal.h>
LiquidCrystal lcd(26,28,30,32,34,36);
//This is a character buffer that will store the data from the serial port
char rxData[20];
char rxIndex=0;
//Variables to hold the speed and RPM data.
int vehicleSpeed=0;
int vehicleRPM=0;
void setup(){
//Both the Serial LCD and the OBD-II-UART use 9600 bps.
lcd.begin(4, 20);
Serial1.begin(9600);
// Serial.begin(9600);
//Clear the old data from the LCD.
lcd.clear();
//Put the speed header on the first row.
lcd.print("Speed: ");
//Put the RPM header on the second row.
lcd.setCursor(0,1);
lcd.print("RPM: ");
//Wait for a little while before sending the reset command to the OBD-II-UART
delay(1500);
//Reset the OBD-II-UART
Serial1.print("ATZ\r");
//Wait for a bit before starting to send commands after the reset.
delay(2000);
//Delete any data that may be in the serial port before we begin.
Serial1.flush();
void loop(){
Serial1.flush();
//Set the cursor in the position where we want the speed data.
//Clear out the old speed data, and reset the cursor position.
// lcd.setCursor(10,0);
// lcd.print(" ");
//Query the OBD-II-UART for the Vehicle Speed
Serial1.print("010D\r");
//Get the response from the OBD-II-UART board. We get two responses
//because the OBD-II-UART echoes the command that is sent.
//We want the data in the second response.
getResponse();
getResponse();
//Convert the string data to an integer
vehicleSpeed = strtol(&rxData[6],0,16);
//Print the speed data to the lcd
lcd.print(vehicleSpeed);
lcd.setCursor(16,0);
lcd.print("km/h");
delay(100);
//Delete any data that may be left over in the serial port.
Serial1.flush();
//Query the OBD-II-UART for the Vehicle rpm
Serial1.print("010C\r");
getResponse();
getResponse();
//NOTE: RPM data is two bytes long, and delivered in 1/4 RPM from the OBD-II-UART
vehicleRPM = ((strtol(&rxData[6],0,16)*256)+strtol(&rxData[9],0,16))/4;
//Print the rpm data to the lcd
lcd.setCursor(10,1);
lcd.print(vehicleRPM);
//Give the OBD bus a rest
delay(100);
void getResponse(void){
char inChar=0;
//Keep reading characters until we get a carriage return
while(inChar != '\r'){
//If a character comes in on the serial port, we need to act on it.
if(Serial1.available() > 0){
//Start by checking if we've received the end of message character ('\r').
if(Serial1.peek() == '\r'){
//Clear the Serial buffer
inChar=Serial1.read();
//Put the end of string character on our data string
rxData[rxIndex]='\0';
//Reset the buffer index so that the next character goes back at the beginning of the string.
rxIndex=0;
//If we didn't get the end of message character, just add the new character to the string.
else{
//Get the new character from the Serial port.
inChar = Serial1.read();
//Add the new character to the string, and increment the index variable.
rxData[rxIndex++]=inChar;
This is what I tried next:
char rxData[20];
char rxIndex=0;
int vehicleSpeed=0;
int vehicleRPM=0;
void setup(){
lcd.begin(4, 20);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("RPM: ");
lcd.setCursor(0,2);
lcd.print("Coolant");
delay(1500);
Serial1.print("ATWS/r");
Serial1.print("ATDPN/r"); //Shows the protocol
Serial1.print("0100/r");
delay(2000);
Serial1.flush();
void loop(){
Serial1.flush();
// lcd.print(" ");
getResponse();
getResponse();
lcd.print("km/h");
delay(100);
Serial1.flush();
getResponse();
getResponse();
delay(100);
char inChar=0;
rxIndex=0;
else{
Insert debugging statements that put out everything you get on the Serial1 to the Serial. This way you see the raw data and you can distinguish between irregular data you get from the engine and errors in interpreting it. At least your BMW says it supports the speed and RPM PIDs (010D and 010C).
I won't be able to test until I find another car close to me, that's OBDII compatible.
Does the code look fine to you? Also will you be kind enough to test the code for me if you have access to the board/car? If not, don't worry.
Thanks.
If you change the code to put out to the PC serial instead of the LCD, I will test it for you. I have a graphical LCD on my OBD-Arduino, so your code will not work the way it currently is.
Also keep in mind, that different cars are different, especially in this regard. My car uses the CAN bus, your brother's BMW uses ISO 9141. Just reading the RPMs and speed values should work on most OBD-II compatible cars though.
Here it is, much appreciated. Just gonna test RPM and speed for now.
char rxData[20];
char rxIndex=0;
int vehicleSpeed=0;
int vehicleRPM=0;
void setup(){
Serial.begin(9600); //This is for the serial debug
delay(1500);
Serial1.print("ATWS\r");
Serial1.print("ATDPN\r"); //Shows the protocol
Serial1.print("0100\r");
delay(2000);
Serial1.flush();
void loop(){
Serial1.flush();
Serial1.print("010D\r"); //Query the OBD-II-UART for the Vehicle Speed
getResponse();
getResponse();
//Print the speed data to debug serial window
Serial.print("SPEED: ");
Serial.print(vehicleSpeed);
Serial.print(" km/h");
Serial.println(" ");
delay(20);
Serial1.flush();
Serial1.println("010C\r");
getResponse();
getResponse();
//Print the rpm data to debug serial window
Serial.print("RPM: ");
Serial.print(vehicleRPM);
delay(50);
char inChar=0;
rxIndex=0;
else{
Any luck with the testing? Thanks man.
I tested your code but before I inserted a bit more debugging output. I wrote every byte I received to the debugging serial and so I found several problems in your code. First of all: your interpreting a fixed protocol but the ELM 327 does communicate some errors too. The delays are absolutely no help, they just impose problems. But the good news are: the ECU responded to your code and from time to time it even got the correct speed and RPMs.
If you wanna go on with your car display you should definitely take a look at the OBDuino code. I took it as a base for my own code and got everything running in much less time than it would have needed if I wrote everything myself.
The debugging is not easy, I have to install my netbook in my car, connect everything together, start the car and see what's happening on the serial terminal. All this is taking place in the basement, four floors lower.
This is the log of the initialization and first value requests of the OBDuino code in my car:
elm_write: (ATWS^M)
elm_read: (ELM327 v1.3a)
elm_write: (ATE0^M)
elm_read: (ATE0OK)
elm_write: (0100^M)
elm_read: (SEARCHING...41 00 BE 3F A8 13 )
elm_write: (0100^M)
elm_read: (41 00 BE 3F A8 13 )
elm_write: (ATDPN^M)
elm_read: (A7) -> 4137
elm_write: (ATSHDA10F1^M)
elm_read: (OK)
elm_write: (0100^M)
elm_write: (0120^M)
elm_read: (41 20 80 1D B0 11 )
elm_write: (0140^M)
elm_read: (41 40 7A D0 00 00 )
elm_write: (010C^M)
elm_read: (41 0C 00 00 )
elm_write: (010C^M)
Hi there and thanks for your time and effort testing the code, I very much appreciate it!
The protocol will be fixed for the moment as it will going on 1 particular car, but it would be good to make it "universal".
Would there be anyway of sharing your code with me at all?
Thanks.
Which one? Your's adapted by me to include debugging output or my version of the OBDuino?
Your version of OBDuino.
Here is my version of OBDuino from their code:
char rxData[20];
char rxIndex=0;
int vehicleSpeed=0;
int vehicleRPM=0;
void setup(){
delay(1500);
// turn echo off
Serial1.print("ATE0\r");
// send 01 00 until we are connected
do
getResponse(); //This is only called once since the schoecho has been turned off using ATE0\r
Serial.print("0100 Response: ");
Serial.print(rxData[0]);Serial.print(rxData[1]);Serial.print(rxData[3]);Serial.print(rxData[4]);Serial.print(rxData[6]);Serial.print(rxData[7]); Serial.print(rxData[9]);Serial.print(rxData[10]);
Serial.println("");
while(ELM_CHECK_RESPONSE("0100", rxData)!=0);
Serial1.flush();
getResponse();
Serial.print("Protocol: ");Serial.print(rxData[0]);Serial.print(rxData[1]);Serial.println("");
// str[0] should be 'A' for automatic
// set header to talk directly to ECU#1
if(rxData[1]=='1') // PWM
Serial1.print("ATSHE410F1\r");
else if(rxData[1]=='2') // VPW
Serial1.print("ATSHA810F1\r");
else if(rxData[1]=='3') // ISO 9141
Serial1.print("ATSH6810F1\r");
else if(rxData[1]=='6') // CAN 11 bits
Serial1.print("ATSH7E0\r");
else if(rxData[1]=='7') // CAN 29 bits
Serial1.print("ATSHDA10F1\r");
Serial1.flush();
void loop(){
Serial1.flush();
getResponse();
delay(20);
Serial1.flush();
getResponse();
delay(50);
byte ELM_CHECK_RESPONSE(const char *cmd, char *str)
// cmd is something like "010D"
// str should be "41 0D blabla"
if(cmd[0]+4 != rxData[0]
|| cmd[1]!= rxData[1]
|| cmd[2]!= rxData[3]
|| cmd[3]!= rxData[4])
return 1;
return 0; // no error
char inChar=0;
rxIndex=0;
else{
Hi Pylon,
Did you ever manage to test my code at all?
Thanks.
Not yet, I'm currently running my own software on the device. I try to find time the end of the week to change that again.
Thank you.
