Hi
Any skin is OK with me, but colour, when applied correctly, does aid in visual comprehension, so it could be win-win. Designers use colour all the time to organize information.
This is excacly what I asked for: If someone is able to come up with a comprehensive grouping for the information on the wiki, I don't mind any semantic markup with using colors.
The only group of information I can currently come up with is code and therefore I suggested a little markup with a (boring) lightgray background (that even makes sense on a printer output).
The other thing that concerns me is the use of images on the wiki. I mimic transparency with a white background for the images. If the default background is changed to some other color I will either use PNG-images or have to setup some kind of frame for my images.
Apart from that I don't care if the sidebar uses green text on a pink background,
Look at your operating system, for example.
Am I the only one who changes the system colors first thing after a fresh install :-?
Can I suggest that we just try the new layout with two or three different skins "live", and then put that to a vote in the forum? That way users can give it a spin .
Someone has got to do the administrative work for this, so he/she should have a say at this I think
@wayoda, skins don't usually require any additional coding; they just "are".
Yes, I understand.
Cheater
I'll chuck together a demo tomorrow and get a sample of syntax highlighting and code formatting going.
Here is my opinion on syntax highlighting :
When I present a piece of code on a website, I usually add a comment to mark the points of interest to the reader.
I my case, documenting an additional library, syntax highlighting is counter-productive. I assume automatic syntax highlighting will be applied only to the standard Arduino keywords, so the reader will rather be distracted from the function-calls that are introduced with the library code.
Syntax highlighting is fine for programming in an IDE as it prevent misspellings, but I don't think it makes code more readable.
Eberhard
