in the range of 200 KHz appear the work just fine; in the range of 60 MHz, the change attempts often cause I2C errors.
I would definitely say that was a decoupling issue with your layout. Read this:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
That is a high frequency you are dealing with and it can get into the supplies. I would also include a 1nF ceramic decoupling capacitor as well as the normal ones.
Grumpy_Mike:
De-coupling
If you recall (reread some of your posts), we tried both large and small caps at the same time. There was no difference. However, I do believe you and I did read the article on decoupling (there are better descriptions). Unfortunately, I have had to put the project away for now. Perhaps in a few weeks we can try something more.
Sorry, but thanks for your help.
