Topic: Nokia 1202 LCD SPI Problem - Arduino UNO (Read 5786 times) previous topic - next topic
ankitmcgill
Jun 04, 2012, 09:26 pm Last Edit: Jun 04, 2012, 10:13 pm by ankitmcgill Reason: 1
Hello All,
I recently came into possession of a Nokia 1202 LCD with STE2007 controller (http://www.datasheetdir.com/STE2007+LCD-Drivers-Controllers) so naturally i hooked it up to my arduino uno to see if i could get it to work.
Being my first project with SPI and a proper LCD, it did not work and I cannot figure out why. Points to note ...
  • The STE2007 controller works with 3v3 levels so as a makeshift I fed the output of the arduino pins through a simple resistance voltage divider to get 3v3 level from 5v0
  • It expects 9 bits (data/control + 8 bit payload) and since SPI is limited to 8 bits I wrote my own manual SPI function
My code is :
Code: [Select]
#define CS_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
#define LCD_RESET_PIN 9
#define LED_PIN 8
#define write_spi_command(x) write_spi(x, 0);
#define write_spi_data(x) write_spi(x, 1);
 //set pin directions
 pinMode(CS_PIN, OUTPUT);
 pinMode(MOSI_PIN, OUTPUT);
 pinMode(MISO_PIN, INPUT);
 pinMode(SCK_PIN, OUTPUT);
 pinMode(LED_PIN, OUTPUT);
 pinMode(LCD_RESET_PIN, OUTPUT);
 //disable lcd to start with
 digitalWrite(CS_PIN, HIGH);
 digitalWrite(MOSI_PIN, LOW);
 digitalWrite(SCK_PIN, LOW);
 //turn on the led
 digitalWrite(LED_PIN, HIGH);
 //turn on serial debugging
 Serial.println("-----NOKIA 1202 LCD DEMO-----");
 //start the lcd
 LCD_init();
 write_spi_data(0xFF);
int write_spi(byte payload, byte dc)
 //select lcd
 digitalWrite(CS_PIN, LOW);
 //write dc bit
 if(dc==0){digitalWrite(MOSI_PIN, LOW);}
 else {digitalWrite(MOSI_PIN, HIGH);}
 digitalWrite(SCK_PIN, HIGH);
 //write payload 8 bits
 for(int i=7;i>=0;i--)
     digitalWrite(MOSI_PIN, (payload>>i)&1);
     //toggle clock
 //turn off lcd cs
 Serial.print("Written 9 bits ::: ");
 Serial.print(dc, HEX);
 Serial.println(payload, HEX);
void LCD_reset()
 digitalWrite(LCD_RESET_PIN, LOW);
 delay(5);
 digitalWrite(LCD_RESET_PIN, HIGH);
 delay(5);
 Serial.println("\nLCD Hardware Reset Complete");
void LCD_init()
 LCD_reset();
 write_spi_command(0xE2);  //reset
 delay(10);
 write_spi_command(0xA4);  //power save off
 write_spi_command(0x2F);  //power control set
 write_spi_command(0xB0);  //set page address
 write_spi_command(0x10);  //set col=0 upper 3 bits
 write_spi_command(0x00);  //set col=0 lower 4 bits
 write_spi_command(0xAF);  //lcd display on
 Serial.println("\nLCD Init Complete");
My serial output prints everything okay so i know the functions are getting executed properly yet i dont see anything on the LCD. any ideas? I am not sure at this point if its the display controller initialization that's not right or my SPI function ....
Thank you,
ankit
olikraus
Hi
The controller STE2007 seems to be compatible with the ST7565 controller. So maybe u8glib will work:
http://code.google.com/p/u8glib/wiki/device
Usually such displays require a much longer init sequence (I miss the charge pump setup in your code). Indeed, i have seen that different displays require different setup sequence. U8glib has included four different setups for four different display types with the same ST7565 controller:
So maybe one of the u8glib devices for the ST7565 is working for you. While testing u8glib may also need to change dimensions manually in the .c code of the corresponding device.
I would create an official Nokia 1202 device for u8glib if one of the ST7565 devices works, so that others can also use this display directly.
Note: U8glib requires 4 lines 8 Bit mode and expects a corresponding setup.
Oliver
ankitmcgill
Hi
Oliver
Hmm ... when starting working with this I came across this thread (http://dangerousprototypes.com/forum/viewtopic.php?f=19&t=3486) where people got this lcd working with a ucontroller. i just copied their init sequence as they seemed to have success with it.
while going through the datasheet for STE2007, I cannot figure out what these terms mean/their use:
  • Electronic Volume
  • Charge Pump multiple Factor
  • Bias Ratio
olikraus
By comparing the files from dangerousprototypes.com it seems that some init commands are missing in your code:
Code: [Select]
// v--- Likely these aren't needed...And might not be working :P ---v
lcdSpi(0xef); // Set refresh rate
lcdSpi(3); // 65 Hz
lcdSpi(0x3d); // Set Charge Pump multiply factor
lcdSpi(0); // 5x
lcdSpi(0x36); // Bias ratio 1/4
lcdSpi(0xad); // set contrast
lcdSpi(0x20 | 20); // 20/32
lcdSpi(0xe1);
lcdSpi(0);
I would at least try these commands. The charge pump controlls the on board voltage multiplier for the display. It is difficult to predict the exact value here, but for sure the LCD needs a much higher voltage than the arduino can provide.
Oliver
