Topic: Help with sketch - reading/decoding RF packets (Read 10662 times) previous topic - next topic
joshhawk
With the help of the forum we decoded some 434mhz packets from my Acu-rite weather station.  Here's the thread:
http://arduino.cc/forum/index.php/topic,110662.15.html
I'm now writing a sketch and can't seem to figure out why bits and entire packets are being missed.  I can see RF noise and that triggers the code, but my weather station packets are missed entirely.  I basically modified my sketch from another sketch I found for a weather station, measuring the bit lengths from my audacity captures (see above link to the thread for waveform downloads).  Anybody have any ideas for me to look into?
Here is my sketch:
Code: [Select]
* Modified from "Thermor" DG950R Weather Station receiver v 0.3
* Receives data from a Weather Station receiver, via
* a 433Mhz RF receiver connected to pin 8 of the arduino, and outputs
* to serial.
* Based on the Practical Arduino Weather Station Receiver project
* (http://www.practicalarduino.com/projects/weather-station-receiver).
* For more info:
* http://kayno.net/2010/01/15/arduino-weather-station-receiver-shield/
#define INPUT_CAPTURE_IS_RISING_EDGE()    ((TCCR1B & _BV(ICES1)) != 0)
#define INPUT_CAPTURE_IS_FALLING_EDGE()   ((TCCR1B & _BV(ICES1)) == 0)
#define SET_INPUT_CAPTURE_RISING_EDGE()   (TCCR1B |=  _BV(ICES1))
#define SET_INPUT_CAPTURE_FALLING_EDGE()  (TCCR1B &= ~_BV(ICES1))
#define WEATHER_RX_LED_ON()         ((PORTD &= ~(1<<PORTD6)))
#define WEATHER_RX_LED_OFF()        ((PORTD |=  (1<<PORTD6)))
#define WEATHER_RESET()             { short_count = packet_bit_pointer = long_count = 0; weather_rx_state = RX_STATE_IDLE; current_bit = BIT_ZERO; WEATHER_RX_LED_OFF(); packet_start = false; }
#define TIMER_PERIOD_US             4
#define WEATHER_PACKET_BIT_LENGTH   26
// pulse widths. short pulses ~500us, long pulses ~1000us. 50us tolerance
#define SHORT_PULSE_MIN_WIDTH       900/TIMER_PERIOD_US
#define SHORT_PULSE_MAX_WIDTH       1100/TIMER_PERIOD_US
#define LONG_PULSE_MIN_WIDTH        1900/TIMER_PERIOD_US
#define LONG_PULSE_MAX_WIDTH        2100/TIMER_PERIOD_US
#define BIG_PULSE_MIN_WIDTH        3400/TIMER_PERIOD_US
#define BIG_PULSE_MAX_WIDTH        3600/TIMER_PERIOD_US
// number of shorts in a row before the stream is treated as valid
#define SHORT_COUNT_SYNC_MIN        2
#define LONG_COUNT_SYNC_MIN         2
// states the receiver can be
#define RX_STATE_IDLE               0 // waiting for incoming stream
#define RX_STATE_RECEIVING          1 // receiving valid stream
#define RX_STATE_PACKET_RECEIVED    2 // valid stream received
#define BIT_ZERO                    0
#define BIT_ONE                     1
//byte locations of generic weather data in weather_packet[] array
#define WEATHER_STATION_ID          0
#define WEATHER_PACKET_TYPE         1
//types of packets
#define PACKET_TYPE_HUM             0
#define PACKET_TYPE_TEMP            1
#define DEBUG
// Type aliases for brevity in the actual code
typedef unsigned int       uint; //16bit
typedef signed int         sint; //16bit
uint captured_time;
uint previous_captured_time;
uint captured_period;
uint current_bit;
uint packet_bit_pointer;
uint short_count;
uint long_count;
uint weather_rx_state;
boolean packet_start = false;
// byte arrays used to store incoming weather data
byte weather_packet[(WEATHER_PACKET_BIT_LENGTH)];
byte last_weather_packet[(WEATHER_PACKET_BIT_LENGTH)];
// packet counter - 4 identical packets in a row means the packet is valid
int packet_count = 0;
/* Overflow interrupt vector */
ISR(TIMER1_OVF_vect){                 // here if no input pulse detected
/* ICR interrupt vector */
ISR(TIMER1_CAPT_vect){
  // Immediately grab the current capture time in case it triggers again and
  // overwrites ICR1 with an unexpected new value
  captured_time = ICR1;
  //immediately grab the current capture polarity and reverse it to catch all the subsequent high and low periods coming in
  if(INPUT_CAPTURE_IS_RISING_EDGE()) {
    SET_INPUT_CAPTURE_FALLING_EDGE();      //previous period was low and just transitioned high
    SET_INPUT_CAPTURE_RISING_EDGE();       //previous period was high and transitioned low
  // calculate the current period just measured, to accompany the polarity now stored
  captured_period = (captured_time - previous_captured_time);
  // Analyse the incoming data stream. If idle, we need to detect the start of an incoming weather packet.
  // Incoming packet starts with a big pulse and the sequence 101010.
  if(weather_rx_state == RX_STATE_IDLE) {
    if(((captured_period >= BIG_PULSE_MIN_WIDTH) && (captured_period <= BIG_PULSE_MAX_WIDTH))) {
      // received a big pulse - indicating the start of a packet
#ifdef DEBUG
      // Serial.println("packet start");
#endif
       packet_start = true;
    if(((captured_period >= LONG_PULSE_MIN_WIDTH) && (captured_period <= LONG_PULSE_MAX_WIDTH)) && packet_start) {
      // long pulse, continue counting long pulses
      long_count++;
#ifdef DEBUG
      if (long_count >= 2) { Serial.println(long_count); }
#endif
    } else if(((captured_period >= SHORT_PULSE_MIN_WIDTH) && (captured_period <= SHORT_PULSE_MAX_WIDTH)) && packet_start) {
      // long pulse. if there has been enough short pulses beforehand, we have a valid bit stream, else reset and start again
      short_count++;
#ifdef DEBUG
      if (short_count >= 2) { Serial.println(short_count); }
#endif
      // not a long or short pulse, therefore not a valid bitstream
      WEATHER_RESET();
#ifdef DEBUG
   //    Serial.println("reset");
#endif
    if((short_count >= SHORT_COUNT_SYNC_MIN) && (long_count >= LONG_COUNT_SYNC_MIN)) {
        weather_rx_state = RX_STATE_RECEIVING;
        Serial.println("receiving");
  } else if(weather_rx_state == RX_STATE_RECEIVING) {
    // incoming pulses are a valid bit stream, non manchester encoded.
    if(((captured_period >= SHORT_PULSE_MIN_WIDTH) && (captured_period <= SHORT_PULSE_MAX_WIDTH))) {
      // short pulse
    //    Serial.print("0");
        weather_packet[packet_bit_pointer] = 0;
        packet_bit_pointer++;
     else if(((captured_period >= LONG_PULSE_MIN_WIDTH) && (captured_period <= LONG_PULSE_MAX_WIDTH))) {
      // long pulse
   //   Serial.print("1");
      weather_packet[packet_bit_pointer] = 1;
    else if(((captured_period >= BIG_PULSE_MIN_WIDTH) && (captured_period <= BIG_PULSE_MAX_WIDTH))) {
      Serial.println("done");
     // got another long pulse, which marks a repeat of the bitstream
      weather_rx_state = RX_STATE_PACKET_RECEIVED;
    // check to see if a full packet has been received
/*    if(packet_bit_pointer >= WEATHER_PACKET_BIT_LENGTH) {
    // full packet received, switch state to RX_STATE_PACKET_RECEIVED
  // save the current capture data as previous so it can be used for period calculation again next time around
  previous_captured_time = captured_time;
  DDRB = 0x2F;   // B00101111
  DDRB  &= ~(1<<DDB0);    // PBO(ICP1) input
  PORTB &= ~(1<<PORTB0);  // ensure pullup resistor is also disabled
  DDRD  |=  B11000000;    // (1<<PORTD6);   //DDRD  |=  (1<<PORTD7); (example of B prefix)
  //ICNC1: Input Capture Noise Canceler         On, 4 successive equal ICP1 samples required for trigger (4*4uS = 16uS delayed)
  //ICES1: Input Capture Edge Select            1 = rising edge to begin with, input capture will change as required
  //CS12,CS11,CS10   TCNT1 Prescaler set to 0,1,1 see table and notes above
  TCCR1A = B00000000;   //Normal mode of operation, TOP = 0xFFFF, TOV1 Flag Set on MAX
                        //This is supposed to come out of reset as 0x00, but something changed it, I had to zero it again here to make the TOP truly 0xFFFF
  TCCR1B = ( _BV(ICNC1) | _BV(CS11) | _BV(CS10) );
  //Timer1 Input Capture Interrupt Enable, Overflow Interrupt Enable
  TIMSK1 = ( _BV(ICIE1) | _BV(TOIE1) );
  //  attachInterrupt(0, rise, RISING);
  WEATHER_RESET();
  Serial.println("\"joshhawk\" Weather Station receiver v0.01");
  Serial.println("Ready to receive weather data");
* main loop
  // weather packet ready to decode
  if(weather_rx_state == RX_STATE_PACKET_RECEIVED) {
#ifdef DEBUG
      for(int i = 0; i < ((WEATHER_PACKET_BIT_LENGTH)); i++) {
        Serial.print(weather_packet[i], BIN);
        Serial.print(" ");
#endif
  WEATHER_RESET();
DerekK19
I'm looking at exactly the same code. In my case I have a weather station simply called a WS1093, sold by Scientific Systems here in NZ. It broadcasts on 433 MHz and I'm trying to get data from it with an Arduino and an RF 434 receiver. Maybe that's my first problem 434 != 433 ! I've used a Packet Analyzer sketch and can see stuff coming to my Arduino, but it just looks like noise. One other thing I didn't do is put the 1K resistor between the RF card and port 8. Mostly I didn't do this because I don't have a 1K resistor, but is it really necessary - I tried 3x330 resistors in series and they didn't affect my results, which are still zilch.
Derek
Riva
Hi joshhawk,
I have looked for some info on 433mHz receivers but could you tell me what model device your using and a link to the devices datasheet would be great.
Don't PM me for help as I will ignore it.
joshhawk
Hey Riva and all,
I put the project down for a while and picked it up again last night, and I've made a little progress.  First of all, my timings were wrong, so I've fixed those.  I am now receiving the packets, but my unfamiliarity with Arduino programming and RF packets in general has me confused.  Per our discussion on the earlier thread (http://arduino.cc/forum/index.php/topic,110662.15.html) the stream is not manchester encoded, so I am just using simple code to try to read the bits into an array to get the same values that we saw when using Audacity.  I started by counting the "big" pulse as the packet start, long pulses as 1, short pulses as 0.  I begin reading packet data after the first 7 bits (1010101) have been received, which would leave 19 more bits in the stream to read and then decode (see Riva's post here: http://arduino.cc/forum/index.php/topic,110662.msg840578.html#msg840578 ).
Here is my simple code so far.  Can anyone point me in the right direction?
Thank you!!!
Code: [Select]
* to serial.
* For more info:
#define WEATHER_PACKET_BIT_LENGTH   19
#define SHORT_PULSE_MIN_WIDTH       420/TIMER_PERIOD_US
#define SHORT_PULSE_MAX_WIDTH       570/TIMER_PERIOD_US
#define LONG_PULSE_MIN_WIDTH        1420/TIMER_PERIOD_US
#define LONG_PULSE_MAX_WIDTH        1570/TIMER_PERIOD_US
#define BIG_PULSE_MIN_WIDTH        2920/TIMER_PERIOD_US
#define BIG_PULSE_MAX_WIDTH        3070/TIMER_PERIOD_US
#define SHORT_COUNT_SYNC_MIN        3
#define LONG_COUNT_SYNC_MIN         4
#define BIT_ZERO                    0
#define BIT_ONE                     1
//types of packets
#define DEBUG
uint captured_time;
uint current_bit;
uint last_bit;
uint short_count;
uint long_count;
volatile bool packet_start = false;
volatile bool packet_end = false;
volatile bool ignore = false;
  else {
    if( ((captured_period >= BIG_PULSE_MIN_WIDTH) && (captured_period <= BIG_PULSE_MAX_WIDTH))) {
    else {
        long_count++;
        short_count++;
      else {
        WEATHER_RESET();
  if(packet_bit_pointer > WEATHER_PACKET_BIT_LENGTH) {
  WEATHER_RESET();
* main loop
    //#ifdef DEBUG
      Serial.print(weather_packet[i]);
      Serial.print(" ");
    //#endif
    WEATHER_RESET();
joshhawk
Anyone?
Surely there has to be some coding geeks here...
Riva
Sorry joshhawk,
The code is a bit beyond me though I still think you only need to read rising or falling edge only and the timing between edges would determine start bit, 0 & 1 bits.
joshhawk
Sorry joshhawk,
Hey Riva,
Yeah, you're exactly right.  That was my problem, I just completely missed it at the beginning of the interrupt function!  Thank you again very much for your genius!  You have been so helpful.
johncc
Quote
Hey Josh,
Glad Riva's suggestion worked for you.  Exactly what did you then change to your code above to get it to work?
I'm doing something similar with an Accurite 00899.
Thanks,
John
