Topic: Timing question (Read 2047 times) previous topic - next topic
vpapanik
Hello !
I have two different codes that read a 512 byte buffer from an SD card using SPI. The first one is mine and the second is taken from sdfatlib. They appear to be equivalent, however :
in the first one, the pause between SPI reads is 2.75 ?s :
Code: [Select]
for (uint16_t i = 0; i < 512; i++) {
    SPDR = 0xFF;
    while (!(SPSR & (1 << SPIF)));
    buffer[i] = SPDR;
and in the second one, time drops to 1.75 ?s, which means 8 less clock cycles on my Arduino Pro 8 MHz. That is some difference !
Code: [Select]
SPDR = 0xFF;
for (uint16_t i = 0; i < 511; i++) {
    buffer[i] = SPDR;
    SPDR = 0xFF;
// wait for last byte
buffer[511] = SPDR;
Still, I can not explain the above difference, so I would really appreciate any help :)
nickgammon
#1
Jul 12, 2012, 01:00 am Last Edit: Jul 12, 2012, 09:02 am by Nick Gammon Reason: 1
It's a good question, and I can reproduce your results. I checked the generated machine code and it contains the same instructions (albeit in a different order). So, we ask ourselves, "how come the same instructions take longer in one case than the other?".
I timed 6 clock cycles difference.
The answer is here:
Code: [Select]
   SPDR = 0xFF;   // <---- send
   while (!(SPSR & (1 << SPIF)));  // <---- immediately wait for buffer empty
Since the default SPI transfer rate is 1/4 of the system clock, we expect it to take 4 clock cycles to send that byte. So the while loop will wait for at least 4 cycles.
(edit) See below: At least 32 cycles (8 x 4).
Compare to:
Code: [Select]
   buffer[i] = SPDR;
   SPDR = 0xFF;
Extra work is done here after setting SPDR, namely:
Code: [Select]
11e: 82 e0       ldi r24, 0x02 ; 2
120: ef 3f       cpi r30, 0xFF ; 255
122: f8 07       cpc r31, r24
124: b1 f7       brne .-20     ; 0x112 <loop+0x12>
In other words, the "end of loop" test. This is 5 cycles here. So the 5 cycles are being used during the SPI transfer. So when we go back to the start of the loop the transfer is over, basically.
This accounts for 5 cycles, not 6, but the difference is probably that the loop here:
Code: [Select]
... would take at least 4 cycles, so the SPI transfer probably finishes half-way through that test.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
My explanation above is a little incorrect. The SPI clock frequency is (by default) 1/4 of the system clock, but that is per bit.
So an SPI transfer will actually take 32 (4 x 8) clock cycles, not just 4.
However my conclusion stands, that of those 32 cycles, we have used up 5 in the "end of for loop" test, thereby accounting for a reduction of 5 cycles.
The 6th cycle would be accounted for by the fact that the test for the SPIF flag takes 4 cycles, so the test must conclude on a boundary of 4 cycles (so we won't save exactly 5 cycles).
vpapanik
Dear Nick, your explanation makes perfect sense and I thank you very much indeed :)
vpapanik
just noting that I've set the SPI frequency to the highest possible, i.e 1/2 system frequency. However, the difference lies only on the fact that the while command takes advantage of the for-loop overhead.
Thanks a lot again !
