Topic: Data Logger SD, String stops earlier than expected (Read 3190 times) previous topic - next topic
simplytuff
i am trying to  log voltage & current of battery on SD card, the programme terminates before going thru complete loop of 20 readings each after 0.5Sec, if i remove current and voltage string from the code it prints ID upto 20 readings fine, but if i add voltage and/or current to string it stops randomly! some times after 6 readings some times after 13 etc.....
Code: [Select]
  File logFile = SD.open("LOG.csv", FILE_WRITE);
  while (id<=20)
  //Main battery Voltage
  int voltage = analogRead(1);
  //Sense Resistance/ Current Drawn
  int current = analogRead(2);
  //Create Data string for storing to SD card
  String dataString = String(id)+ ", " +String(voltage)+", "+ String(current);
  if (logFile)
    logFile.println(dataString);
    Serial.println(dataString);
    Serial.println("Couldn't open log file");
  //Increment ID number
  id++;
  logFile.close();
wanderson
Probably a result of the well documented memory leaks in the string library.
simplytuff
any solution to this problem? or alternate function to use instead of string?
dxw00d
There's no need to create Strings at all.
Instead of:
Code: [Select]
  if (logFile)
Use:
Code: [Select]
if (logFile)
    logFile.print(id);
    logFile.print(",");
    logFile.print(voltage);
    logFile.print(",");
    logFile.println(current);
    Serial.print(id);
    Serial.print(",");
    Serial.print(voltage);
    Serial.print(",");
    Serial.println(current);
fat16lib
Looks like String corrupts the heap.  I added freeMemory() to a simplified version of the program and the result makes no sense.  The problem seems to be with the free list.
Here is the simple program that fails:
Code: [Select]
#include <MemoryFree.h>
  Serial.println(freeMemory());
  int id = 0;
  while (id <= 20)
    int voltage = 20*id;  //analogRead(1);
    int current = 30*id;  //analogRead(2);
    String dataString = String(id)+ ", " +String(voltage)+", "+ String(current)+", "+String(freeMemory());
    id++;
Here is the printout.  The last column is the value returned by freeMemory() which is nonsense.
Quote
0, 0, 0, 1742
1, 20, 30, 1740
2, 40, 60, 13050
3, 60, 90, 24360
4, 80, 120, -29868
5, 100, 150, -17534
6, 120, 180, -3919
7, 140, 210, 10464
8, 160, 240, 23056
9, 180, 270, -29120
If I comment out this line in freeMemory
Code: [Select]
//    free_memory += freeListSize();
I get this
Quote
1828
0, 0, 0, 1742
1, 20, 30, 1703
2, 40, 60, 1703
3, 60, 90, 1703
4, 80, 120, 1703
5, 100, 150, 1703
6, 120, 180, 1703
7, 140, 210, 1703
8, 160, 240, 1703
9, 180, 270, 1703
So a bug in String must write over the free list.
fat16lib
simplytuff
Thnks for the help, both solution works fine,  i found dxw00d's solution much simpler!
