Topic: DS1307 RTC adjust drift automatically (Read 17919 times) previous topic - next topic
sbright33
Didn't know which category to put this in.  I wrote some code to adjust the drift of my RTC.  You only have to set it once.  Mine drifted about 6 seconds per day.  That's not good enough for me.  Now it's less than 0.1 seconds.  This works especially when the clock is powered off.  Not sure how it works during extreme temperatures.  It's simple check it out.  It's only a few lines more than the original example.  You only need to change the first 3 constants, and calculate the 4th constant over time.  Any improvements?  Any ideas how I can adjust the day overflow?  The way it is now you can use since12 for logging.
Code: [Select]
#include "Wire.h"
#define DS1307_ADDRESS 0x68
const int setyearago=1;  //when was the RTC set?
const int setmonth=10;
const int setday=4;
const int spdx100=580;  // secs/day slow error measured over 11 months 580
int second,minute,hour,weekDay,monthDay,month,year;
int errsec,i,j;
long since12,since12wrong;
void ferrsec(){
long t=setyearago*365;
t+=(month-setmonth)*30;
t+=(monthDay-setday);
errsec=t*spdx100/100;
//Serial.println(errsec/60.0);
since12wrong=long(hour)*60*60+minute*60+second;
since12=since12wrong+errsec;
//since12%=(24*60*60); untested and wrong let it overflow
//return;  //skip adjusting
second+=errsec%60;
if(second>=60){
  minute++;
  second-=60;
minute+=errsec/60;
while(minute>=60){
  hour++;  //could overflow past 23
  minute-=60;
if(hour>=24){
  monthDay++;  //still not good enough could overflow monthDay
  hour-=24;
void setup(){
  Wire.begin();
void loop(){
  printDate();
byte bcdToDec(byte val){
  return ( (val/16*10) + (val%16) );
void printDate(){
  Wire.beginTransmission(DS1307_ADDRESS);
  Wire.send(0);
  Wire.endTransmission();
  Wire.requestFrom(DS1307_ADDRESS,7);
  second = bcdToDec(Wire.receive());
  minute = bcdToDec(Wire.receive());
  hour = bcdToDec(Wire.receive() & 0b111111); //24 hour time
  weekDay = bcdToDec(Wire.receive()); //0-6 -> sunday - Saturday
  monthDay = bcdToDec(Wire.receive());
  month = bcdToDec(Wire.receive());
  year = bcdToDec(Wire.receive());
  ferrsec();
  Serial.print(month);
  Serial.print("/");
  Serial.print(monthDay);
  Serial.print("/");
  Serial.print(year);
  Serial.print(" ");
  Serial.print(hour);
  Serial.print(":");
  Serial.print(minute);
  Serial.print(":");
  Serial.println(second);
sbright33
Has anyone tried this?  I thought it would be useful for all DS1307 users.  Is there a problem with the code?  Improvements?
BlueJakester
#2
Aug 23, 2012, 04:47 am Last Edit: Aug 23, 2012, 04:48 am by BlueJakester Reason: 1
OK, in this thread now, thanks. :)
I'd like to give this code a try. Can you give me more directions please?
Say I set my ds1307 to the correct time right now. How would I set the first three params of your sketch before uploading? Like this maybe?
Thanks!
const int setyearago=0;  //when was the RTC set?
const int setmonth=8;
const int setday=22;
sbright33
You got it.  The 4th constant is a little tricky.  You have to calculate it!  Using your old original sketches to read time, measure how far off it is from the PC time today, and again in 10 days.  Let's say it's 45 seconds slower than it was today.  Divide by the number of days (10), then multiply by 100.  The answer is 450.  That's what you put for spdx100.  That stands for Secs/day x 100 that it is slow.  -450 if it's faster after 10 days running.  Let me know!  The error seems consistent to me, so now there is much less error per day.
Constantin
Nice work.
I imagine the DS1307 drift is going to be quite dependent on temperature. But as long as the temperature is relatively constant, you should be good to go.
Some day I'll try to do something similar with an Arduino, a radio receiver for the US time signal and the Chronodot... and then create a auto-correct function for the aging trim in the DS3231.
BlueJakester
#5
Aug 24, 2012, 01:35 pm Last Edit: Aug 24, 2012, 01:37 pm by BlueJakester Reason: 1
OK, I'll setup the clock and load the sketch this weekend. It will be at least 10 days plus a few more to monitor results before I post back to this thread with my results, but I will.
Thanks for writing and sharing this code!
Jake
sbright33
You could guess after 2 days.  I also wrote some code which is related to this.  It uses GPS to measure and calibrate millis() and the Arduino clock within hours, no need to wait 100 days.  So long as you keep it inside where the temperature is 60-80 degrees it is easy to obtain accuracy of 1ppm, which is about 1 seconds every 11 days.  Or even 10ppm with some effort which is 1 second every 100 days, or 3 seconds per year.  The only hardware you need for this code is GPS.  I also have code which uses Wifly to do the same thing with NIST server.
If you've got the time, I can help you keep it!
BlueJakester
Sounds good. I need to put the ds1307 on a breadboard this weekend and set the time. I'll let you know how it goes.
Thanks!
Constantin
#8
Aug 24, 2012, 04:33 pm Last Edit: Aug 24, 2012, 04:35 pm by Constantin Reason: 1
...Or even 10ppm with some effort which is 1 second every 100 days, or 3 seconds per year....
Pardon my ignorance. I thought lower PPMs were better than higher PPMs re: clock drift. Why would an increase to 10PPM drift be preferable to 1PPM? Did you perhaps mean 0.1PPM or 100PPB?
I thought the whole point of adjusting the aging trim in the DS1307 or DS3201 was to minimize the clock drift.
sbright33
BlueJakester
sbright,
I have my cheap ds1307 setup. I'll be installing your code either tonight or tomorrow and will let you know how it works out.
Jake
Constantin
Looks like I'll have to use a GPS receiver since sourcing the radio-based receivers appears difficult, plus I get the benefit of a GPS system, if I want it. The breakout board from adafruit appears enticing, it'll be interesting to see to what extent trimming the oscillator will work. What is the minimum time you think you need to trim with reasonable perfection? For something as accurate as the DS3231, I figured I'd need at least a month.
sbright33
Using PPS pin you can measure 1us drift each second.  So you get 1ppm in about...
1 second!
It makes more sense to wait 20 minutes and use 1ms drift method instead.
http://arduino.cc/forum/index.php/topic,120288
BlueJakester
Sbright,
I have your code installed and it appears to be working :D  I'll monitor it for a few days.
Thanks,
Jeff
howardlim
Hi Guys,
I have modified the Time and DS1307RTC Libraries to do drift correction and store the drift info in the RTC battery backed memory. I've also included an Arduino sketch to do the RTC time setting and drift calibration. Take a look at the link below if you're interested.
Howard
http://limchonghan.wordpress.com/driftcorrectedds1307/
